GMT800 at a Glance
GMT800 is General Motors’ full-size truck and SUV platform, built for the 1999 through 2006 model years — pickups from 1999, the SUVs from 2000 — plus the 2007 Silverado and Sierra Classic, which carried the same chassis for one final year. It replaced the GMT400 (OBS) and carried the Chevrolet Silverado, Tahoe, Suburban and Avalanche, the GMC Sierra, Yukon and Yukon XL, and Cadillac Escalade. The GMT900 replaced it for 2007.
Buying a 1999–2006 Silverado or Sierra? The GMT800 is GM’s full-size truck and SUV platform built from 1999 through 2006 (plus the 2007 Silverado/Sierra Classic carryover) — and the 4.8L, 5.3L, 6.0L, and 8.1L Vortec V8s that came in these trucks are the reason owners, builders, and LS-swappers still want them two decades later.
This guide is the buying half of GMT800 ownership: the best and worst years, the engine comparison, common failure points by mileage, realistic pricing, and a 10-point inspection checklist you can run in 20 minutes. For the full platform overview — every model, engine, and repair guide in one place — start at the GMT800 hub.
In this guide
- GMT800 at a Glance
- GMT800 Years and Vehicles
- Best GMT800 Years to Buy
- Engines
- Common Problems
- Inspection Checklist
- GMT800 vs GMT900
- Pricing
- Maintenance and Parts
- Mods and Builds
- FAQ
- GMT800 Community
Platform Quick Reference
| Item | GMT800 Reference |
| Core truck years | 1999–2006 |
| Carryover model | 2007 Silverado / Sierra Classic |
| Predecessor | GMT400 / OBS |
| Successor | GMT900 |
| Core pickups | Chevrolet Silverado, GMC Sierra |
| Related SUVs | Tahoe, Suburban, Yukon, Yukon XL, Escalade variants |
| Common gas engines | 4.8L, 5.3L, 6.0L, 8.1L Vortec |
| Diesel option | Duramax diesel in HD models |
| Major appeal | Simple LS/Vortec powertrains, strong aftermarket, practical ownership |
Vehicles on the GMT800 Platform
- Chevrolet Silverado 1500 / 2500 / 3500
- GMC Sierra 1500 / 2500 / 3500
- Chevrolet Tahoe
- Chevrolet Suburban
- GMC Yukon
- GMC Yukon XL
- Chevrolet Avalanche
- Cadillac Escalade, Escalade EXT, Escalade ESV (applicable years)
The GMT800 (1999–2006), plus the 2007 Silverado/Sierra Classic carryover, is one of the best-used truck values on the market today. Not every GMT800 was built equal. The strongest years are 2003–2006 (refined 5.3, Vortec MAX availability, mature electronics); the years to be cautious about are 1999 (first-year issues) and any rusty Northeast example regardless of year.
Between 1999 and 2006, GM built well over five million GMT800-platform Silverados and Sierras, plus the Tahoe, Yukon, Suburban, Avalanche, and Cadillac Escalade variants. That’s a lot of trucks, and most of them are still on the road — which is exactly why this generation matters. The aftermarket is enormous, parts are cheap, and you can buy one for the price of a bad weekend at the casino. Junkyards and Pick-N-Pull lots still stock rows of GMT800s for parts.
This guide breaks down the best GMT800 years to buy, the worst to avoid, an engine-by-engine comparison, common failure points by mileage, and a 10-point inspection checklist you can walk through in 20 minutes before you ever hand over a check.
The 1999–2006 GMT800 run breaks into three main groups.
1999–2002 — Early Years
The 1999–2002 trucks are the original GMT800s. They came with the first run of the 4.8L, 5.3L, 6.0L, and 8.1L Vortec engines, and GM made small refinements year after year as the platform matured.
The 1999 model year had the most early-production quirks, so 2001–2002 trucks are usually the better picks if you want the early GMT800 style with a few more bugs worked out.
The 1999–2002 trucks used different electronics, wiring, and BCM setups than the later 2003–2006 trucks. The HD models had the earlier “Bubble Eye” front end, which still has a strong following today. These trucks could also be optioned nicely, with leather, a sunroof, power accessories, and heated seats depending on trim.
The 1999–2002 trucks were also more likely to have small convenience features like underhood lighting, under-dash courtesy lights, cabin air filters, and serviceable inline fuel filters. Around the 2003 refresh, GM began deleting several of these items on many trucks, so 2003–2006 models may not have them depending on build date, trim, and options.
The 1999–2002 trucks also used a 1.5-DIN stereo, not a true double-DIN setup like the 2003–2006 trucks. Don’t let that scare you off — a double-DIN swap is still doable. See the full 99–02 GMT800 Double-DIN Installation Guide.
2003–2006 — Late Years
The 2003–2006 trucks are the best overall pick for most buyers. They got the refreshed front fascia, updated interiors, more mature electronics, and a more refined feel overall.
The 2003+ trucks are usually the better choice for buyers who want the newer GMT800 look, improved cabin layout, and fewer early-production quirks.
The HD trucks also got the “Cat Eye” front end, and 2500HD/3500 models commonly had hydroboost brakes, which are a meaningful real-world improvement for towing, hauling, and hard stops.
For the heavy-duty crowd, the LBZ Duramax is one of the big highlights of the later GMT800 years. To this day, the LBZ is regarded as a strong workhorse engine, especially among diesel truck buyers who want power, reliability, and pre-emissions simplicity compared with newer trucks.
The tradeoff is that many 2003–2006 trucks lost some of the small convenience features found on earlier 1999–2002 models, like cabin air filters, underhood lights, under-dash courtesy lights, and inline fuel filters. The good news is that some of these can be added back. If cabin air filtration matters to you, check out the GMT800 2003–2006 cabin air retrofit guide.
2006–2007 Classic — Sweet Spot of the Sweet Spot
The 2006–2007 Classic trucks are the most refined GMT800s. By this point, GM had years to sort out the platform, and you’re getting the final version of one of the most durable modern GM truck generations.
The 2007 Classic models were sold alongside the new GMT900 trucks, giving buyers one final year to get the proven GMT800 platform. Plenty of them are still on the road today, which says a lot about how durable these trucks were.
For gas trucks, a clean 2006 or 2007 Classic is one of the safest GMT800 buys. For diesel buyers, the 2006–early 2007 LBZ Duramax trucks are especially desirable. AFM, lifter tick, emissions, and DEF were not a thing yet.
Recommended pick for daily use: 2003 or 2004 5.3L LM7 4×4 extended cab with a known-good 4L60E rebuild already done. That’s the highest-value, lowest-pain version of the platform.
For the deep year-by-year breakdown — spider injector years, intake gasket guidance, and the specific 5.3L/6.0L year combinations worth chasing — see the best year GMT800 Silverado: year-by-year breakdown.
Engine Comparison: 4.8 vs 5.3 vs 6.0 vs 8.1
| Engine | Years | RPO | HP | Torque | Reliability | Best for | Avoid if |
| 4.8L V8 | 1999–2006 | LR4 | 270–285 | 285 lb-ft | Bulletproof, with the lightest valvetrain wear | Daily drivers, commuters, and parts-truck builds | You regularly tow more than 5,000 lb |
| 5.3L V8 | 1999–2006 | LM7 | 270–295 | 315 lb-ft | Strong; watch for piston slap on early engines | The best all-around balance | You want maximum torque right off idle |
| 5.3L Flex-Fuel | 2002–2006 | L59 | 285–295 | 325 lb-ft | Uses the same basic internals as the LM7 | E85 availability and lower-cost fuel | E85 is not readily available locally |
| 6.0L V8 | 1999–2006 | LQ4 | 300–325 | 360 lb-ft | Stout iron block and a popular LS-swap engine | Towing under 10,000 lb, plowing, and hauling | Daily fuel economy is a priority |
| 6.0L HO | 2002–2006 | LQ9 | 345 | 380 lb-ft | LQ4-based block with flat-top pistons and a hotter cam | Performance and towing combined | You do not want to run premium fuel |
| 8.1L V8 Vortec 8100 | 2001–2006 | L18 | 340 | 455 lb-ft | Large, thirsty, and more expensive to repair, but durable | Heavy towing over 10,000 lb, fifth-wheel RVs, and snow plowing | You do not regularly tow heavy loads |
For the engine-by-engine deep dive — block details, head castings, oil-system notes, and what to listen for at purchase — see every GMT800 Vortec engine explained. For the matching rear-end gear ratio reference, see the GM Rear Axle RPO Codes & Gear Ratios reference.
If you want one of these to keep forever: 6.0L LQ4 or 5.3L LM7. The LQ4 is the LS-swap engine of choice — even if you grenade one, replacements are everywhere for under $1,500 (see the no-BS LS swap kit guide). The 5.3L LM7 is the cheap-fuel daily-driver pick — pair it with the right exhaust for the 5.3 Silverado and you’ve got a truck you’ll keep for a decade.
Worst GMT800 Years to Avoid
Be cautious of:
- 1999 model year — first-year platform, fuel pump driver module failures, early-build gauge clusters known to lose backlighting. By 2000–2001 most of this was sorted.
- Any northeast / rust-belt example regardless of year. GMT800 cab corners, rocker panels, and rear-cab seam are infamous rust traps. A rust-belt 2005 truck can be worse than a southern 1999 truck. Always inspect (checklist below).
- 6.5L Diesel anything (in GMT800 cargo vans/Suburbans where it lingered). The IP (injection pump) failure rate is brutal and parts are getting scarce. If you want a diesel, skip the 6.5L entirely and look at the Duramax in HD trucks of the same era.
- Heavily modified 6.0L LQ9 examples without rebuild paperwork. Forced induction or nitrous on a stock LQ9 with high mileage is a grenade with the pin pulled. If you’re buying a built one, get the rebuild receipts.
Got a candidate truck you’re not sure about? Drop it in the GMT800 forum section — the community has eyes on most of the active listings.
Common Failure Points by Mileage
Under 100K miles
- Fuel pump (whining noise, hard hot starts) — replace the in-tank pump, $300 part plus a Saturday.
- Front diff actuator (4×4 won’t engage) — common, easy fix.
- HVAC blend door actuator (clicking sound, stuck temperature).
- 8.1L spark plugs — replace these every 25K miles.
100K–200K miles
- 4L60E transmission — the 3-4 clutch pack is the weak point. Symptoms: harsh 2-3 shift, slipping at WOT. A solid rebuild runs $1,800–$2,500 installed. For the full failure picture, see 4L60E failure modes and fixes.
- Steering shaft / intermediate shaft clunk — $80 part, well-known fix.
- Instrument cluster failure (gauges sweep, speedometer dead) — common; the stepper-motor repair kit is $30 and you can DIY in an afternoon.
- A/C compressor clutch / orifice tube clog.
- LM7 piston slap (cold-start tick that quiets in 30 seconds) — annoying, not catastrophic.
- Power window regulator (driver-side first).
200K+ miles
- Camshaft sensor on 5.3L and 6.0L — check engine light, easy fix.
- Oil-pan gasket weep (front edge of pan) — slow drip, monitor.
- Oil pickup tube O-ring — low oil pressure at hot idle that recovers with RPM. Diagnose before you replace anything: see the 5.3L hot-idle low oil pressure diagnosis. Do the O-ring at the same time as the pan gasket.
- Frame rust progression behind the rear cab mounts — watch the cab-frame seam annually.
- Heat-shield rattle on the catalytic converter (cosmetic — bend the tab and move on).
Anything past 250K miles: start expecting one major item per year. None of it is platform-killing; the GMT800 is the easiest GM truck to keep on the road past 300K because parts are everywhere and the design is mechanically simple. The full GMT800 problem list covers every common failure with diagnosis steps.
10-Point GMT800 Inspection Checklist
Run through these before you write a check. Should take about 20 minutes.
- Cab-corner rust — physically poke the rocker behind the rear door. If it crumbles, walk away.
- Frame rust at rear cab mount — look up under the truck where the cab bolts to the frame. Surface rust is fine; flaking, scale, or holes are deal-breakers.
- Cold start — listen for piston slap (LM7) at first start. Faint tick that goes away in 30 sec = normal. Sustained knock = walk.
- Trans dipstick — pull it. Smell it. Burnt = $2K problem in your near future.
- 4×4 engagement — shift into 4 Hi and drive 50 ft. If the front-axle actuator clicks but doesn’t engage, that’s a known fix ($60 part).
- Steering shaft clunk — turn the wheel lock-to-lock with the truck stationary. A clunk at the column = intermediate shaft.
- HVAC — cycle defrost, vent, floor. Listen for clicking blend doors.
- Test every window — driver-side is the first to fail.
- Read OBD codes with a $20 scanner — even stored/cleared codes tell you what’s pending.
- Title + service records — flood titles in the GMT800 era are a known issue. Run a Carfax for $40.
Pass on 7+ out of 10 with no deal-breakers, and you’ve got a buy.
GMT800 vs GMT900 — Which Should You Buy?
The GMT900 (2007–2013) is the direct successor. Quick comparison:
| Spec | GMT800 (1999–2006) | GMT900 (2007–2013) |
| Best engine | 5.3 LM7 / 6.0 LQ4 | 5.3 LMG / 6.2 L92 |
| Transmission | 4L60E / 4L80E / Allison (HD) | 6L80 / 6L90 |
| AFM / DOD | None | Yes — disable or delete |
| Fuel economy | 14–17 mpg | 15–18 mpg |
| Interior comfort | Workable | Improved, color selections were limited |
| Aftermarket size | Massive | Large but smaller |
| Best for | DIY wrencher who wants simple + cheap | Closer to a modern truck without the modern price |
For the side-by-side decision guide, see GMT800 vs GMT900: which generation to buy.
Realistic GMT800 Pricing
What you should be paying right now for well-cared-for, mid-mileage examples:
- 2WD regular cab, 4.8L LR4, 150K–200K mi: $4,500–$7,000
- 4×4 ext cab, 5.3L LM7, 150K–200K mi: $8,000–$13,000
- 4×4 crew cab, 5.3L LM7, 100K–180K mi: $13,000–$19,000
- 4×4 6.0L LQ4 ¾-ton 2500HD, 150K mi: $11,000–$16,000
- Heritage / Final Year / SS / NBS limited trims: premium ~25% over standard
- Cateye conversion (2003–2006 fascia on a 1999–2002 truck): value adds ~$2,000
Expect to pay $1,500–$3,500 more for a clean Southern truck vs. a rust-belt example. Worth every penny if you plan to keep it more than two years.
Where to Find Good GMT800s
In rough order of best→worst hunting grounds:
- Facebook Marketplace, filtered by southern/southwestern states — best price/quality ratio.
- Craigslist, owner-only, cash deals only — fewer scams, less competition.
- Local Chevy/GMC mechanics or body shops — they hear about trucks before they list.
- FullSizeChevy GMT800 forum section — community-vetted, often with build history.
- Wholesale auctions — only if you can inspect in person; lots of flood titles.
- Dealerships — pay a 20–30% markup for paperwork peace-of-mind.
Maintenance and Parts Reference
Two reference articles cover the day-to-day side of GMT800 ownership:
- Full-size Chevy maintenance checklist — service intervals, fluid specs, and inspection points across Squarebody, OBS (GMT400), and GMT800 trucks.
- GM full-size truck parts interchange master list — what bolts on across Squarebody, OBS, GMT800, and GMT900 — useful when sourcing rust-belt cab corners, axles, brake upgrades, or seats.
Mods and Builds
Three articles cover the most common GMT800 upgrade paths:
- Best lift kits for a GMT800 Silverado — leveling kits through 6-inch suspension lifts, with tire-fitment notes and UCA requirements.
- The no-BS LS swap kit guide — mounts, oil pans, headers, harnesses, and PCM tuning across Squarebody, OBS, GMT800, and GMT900.
- GMT800 overland Suburban example build — a real-world build approach for owners using the long-wheelbase GMT800 SUVs for camping, dirt-road travel, and long-distance use.
FAQ
What is a GMT800?
GMT800 is GM’s full-size truck and SUV platform built primarily from 1999 through 2006, used on the Chevrolet Silverado and GMC Sierra (1500/2500/3500), Tahoe, Suburban, Yukon, Yukon XL, Avalanche, and Cadillac Escalade variants. It introduced the Gen III LS/Vortec V8 family in a full-size truck.
What years are GMT800 trucks?
The GMT800 was built from 1999 through 2006. The 2007 Silverado and Sierra Classic carried the same GMT800 body and chassis for one extra year while the new GMT900 was launching alongside it.
Is a 2007 Silverado Classic a GMT800?
Yes. The 2007 Silverado Classic and Sierra Classic are GMT800-platform trucks. They share the body, chassis, drivetrain, and parts catalog with the 1999–2006 GMT800 generation. The non-Classic 2007 Silverado and Sierra are the new GMT900-platform trucks.
What engines came in GMT800 trucks?
The 1500 lineup used the 4.3L V6 (LF6), 4.8L V8 (LR4), 5.3L V8 (LM7/L59), and 6.0L V8 (LQ4/LQ9). The 2500HD and 3500 added the 8.1L Vortec V8 (L18) and the 6.6L Duramax diesel (LB7, LLY, LBZ depending on year). The 5.3L LM7 is the most common; the 6.0L LQ4/LQ9 is the most desirable gas engine for towing and LS builds.
What is the best year GMT800 to buy?
For most buyers, a 2003–2006 truck with the 5.3L LM7 or 6.0L LQ4/LQ9 is the GMT800 sweet spot. 2005–2006 trucks are the most refined years. Avoid early 1999 trucks unless the price reflects known first-year issues, and avoid rust-belt examples regardless of year unless you can confirm clean frame and cab corners.
What are common GMT800 problems?
The most common GMT800 failures are intake manifold gasket leaks on 1999–2001 trucks, 4L60E transmission wear (3-4 clutch pack and TCC shudder) on high-mileage trucks, front wheel bearing hub wear around 120K miles, fuel pump failure at high mileage, EVAP system codes from aged plastic components, and rust on the cab corners, rocker panels, and frame on northern trucks.
What is the difference between GMT800 and GMT900?
The GMT800 (1999–2006) is the simpler, cheaper-to-maintain platform with no AFM (Active Fuel Management), four-speed automatics (4L60E or 4L80E), and a massive aftermarket. The GMT900 (2007–2013) has a more refined interior, a stronger six-speed automatic on most configurations (6L80E/6L90E), and more modern features — but its 5.3L engines came with AFM, which is the platform’s most expensive common failure. GMT800 wins on simplicity and long-term cost; GMT900 wins on capability when properly maintained.
GMT800 Community
If you’re actively wrenching, building, or shopping a GMT800, the FullSizeChevy community is where the conversations happen. Bring your year, engine, mileage, and what the truck is doing.
- Join the GMT800 community on FullSizeChevy — community landing page with the active build, repair, and discussion threads.
- GMT800 (1999–2006) NBS Discussions on the FSC Forum — the dedicated GMT800 forum category.
Ready to pull the trigger? If you’re shopping a GMT800 right now, drop your candidate in the GMT800 forum section — the community has eyes on most of the active listings, and someone has probably already inspected the exact truck you’re looking at. Pick up some Squarebody Squad / NBS gear to support the site if it’s useful to you.
If you sweat the details on your GMT800/GMT900, you’ll like the gear. Built for Silverado, Sierra, Tahoe, Suburban, and Yukon owners who actually do the work.
Talk GMT800 with other owners
Open the GMT800 Forum →GMT800 Gear
Shop all GMT800 gear →Find every repair, buying, maintenance, and troubleshooting guide in the GMT800 Owner’s Hub.
