NBS Chevy Lowering Kit: What to Know
A clean NBS stance can make or break the whole truck. Get it right, and your Silverado or Sierra looks planted, aggressive, and finished. Get it wrong, and you end up fighting tire rub, rough ride quality, bad alignment numbers, or a truck that just looks off. That is why picking the right nbs chevy lowering kit matters more than most guys think.
For the 1999-2006 GM full-size crowd, lowering is one of the most popular mods for a reason. These trucks respond well to a drop, parts support is solid, and the final look can go in a few different directions. You can build a mild daily with a factory-like ride, a street truck with a serious stance, or a more aggressive setup that trades some comfort for looks and handling. The trick is knowing what each kit actually changes.
What an NBS Chevy lowering kit really does
A lot of people talk about lowering kits like they are one single thing. They are not. An nbs chevy lowering kit can be as simple as shackles and torsion key adjustment, or as complete as spindles, springs, hangers, shocks, and hardware meant to keep the truck driving right after the drop.
On NBS GM trucks, the front and rear need different solutions. Up front, most 2WD trucks use drop spindles, springs, or a combination depending on how low you want to go. Torsion bar trucks and 4WD trucks have a different set of limits, and not every cheap solution plays nice with alignment or suspension travel. Out back, the drop usually comes from shackles, hangers, or flip kits. The bigger the drop, the more likely you are to need shock relocation, notch work, or attention to pinion angle.
That is where a lot of builds go sideways. Guys buy a number on a box, like 4/6 or 5/7, without thinking through how the truck is used. A weekend cruiser can tolerate things that a daily driver, tow rig, or road-trip truck cannot.
Picking the right drop for your truck
The best-looking setup is not always the lowest one. On an NBS truck, the sweet spot for a lot of owners is a 3/5 or 4/6 drop. That usually gives the truck a strong stance without pushing every part of the suspension to its limit.
A 2/4 drop is the safe play if you want a noticeable change without turning the build into a project. It keeps more ground clearance, usually preserves ride quality better, and tends to be easier on wheel and tire fitment. If your truck still sees real street miles, rough pavement, or the occasional load in the bed, this kind of drop makes sense.
A 4/6 setup is where the classic sport truck look starts to show up. It is lower, more aggressive, and usually worth the extra work if stance is high on your list. But this is also where supporting parts matter more. You cannot just slam it down and expect factory ride and geometry.
Once you get into 5/7 territory, you need to be honest with yourself. That setup can look killer, but it is less forgiving. You are more likely to deal with frame clearance, rubbing, bump stop issues, and a ride that feels harsher unless the whole combo is sorted out correctly.
Front suspension choices matter more than people think
The front end is where most ride quality complaints start. A lot of that comes from using the wrong parts for the amount of drop.
Drop spindles are popular because they lower the truck while keeping spring travel closer to stock. That usually means a better ride than simply cranking everything down with springs or keys. But spindle quality matters, and so does brake and wheel compatibility. Some setups push track width out slightly, which can create tire clearance issues depending on wheel offset.
Lowering springs can work well, especially in moderate drops, but they shorten available travel. If the spring rate is too stiff or the shocks are wrong, the truck can get choppy fast. On torsion bar applications, turning keys or over-adjusting ride height is where many budget drops fall apart. It may sit lower, but suspension geometry and ride quality often pay the price.
If you care about how the truck drives, not just how it looks parked, spend time on front-end planning. A truck that sits right and still drives straight is always cooler than one that is all attitude and no manners.
Rear drop options and where problems show up
The rear is usually easier to lower, but it is also where people underestimate what a big drop does. Shackles and hangers are common for mild to moderate setups. They are simple, effective, and usually fine for a street truck if the rest of the suspension is healthy.
For deeper drops, axle flip kits become part of the conversation. A flip kit moves the axle relationship to the leaf spring and gets the truck down much farther than shackles alone. That can transform the look, but it often requires more supporting work. Shorter shocks, relocated mounts, better bump stop setup, and sometimes a C-notch are part of doing it right.
This is the point where the phrase bolt-on gets used a little too loosely. Sure, many kits are sold that way, but whether they work well after installation depends on shock travel, axle clearance, and how much suspension movement is left. If the rear bottoms out over every dip, the truck may look great in photos and still be miserable on the road.
Ride quality, alignment, and wheel fitment
The best nbs chevy lowering kit is not automatically the one with the biggest drop. It is the one that fits your actual truck, your wheel setup, and how you drive it.
Ride quality comes down to more than springs and shocks. Tire sidewall, wheel width, offset, and even seat-of-the-pants expectations all matter. A truck on 20s with a moderate drop can drive well. A truck on oversized wheels with rubber-band tires and no suspension travel usually will not.
Alignment is another big one. Any time you change ride height, you change suspension angles. Some setups can be aligned back into spec without drama. Others fight you. If your camber, caster, or toe ends up out of range, the truck will let you know with wandering, uneven tire wear, or steering that never feels settled.
Then there is tire rub. On NBS trucks, wheel fitment gets tight quickly once the ride height comes down. Fender lips, inner liners, and frame contact all become part of the deal. A wheel and tire combo that worked at stock height may not work after a drop, especially if offset is aggressive.
Cheap kits versus complete kits
This is where money gets wasted. A cheap kit looks good until you add up the parts it does not include. Then you are chasing shocks, hardware, bump stops, alignment parts, and fixes for issues that should have been addressed from the start.
A more complete kit usually costs more up front, but it often saves money and frustration in the long run. Better kits are designed as a system. They take into account travel, geometry, and the parts needed to make the truck feel sorted instead of slapped together.
That does not mean every expensive kit is automatically worth it. Some are paying for a name. But if a kit seems too cheap for the amount of drop it promises, there is probably a reason.
What to ask before you buy
Before you commit to any lowering setup, be honest about a few things. Is the truck 2WD or 4WD? Is it a regular cab short bed, extended cab, or crew cab? What wheels and tires are you running? Do you still haul with it, or is this mostly a street truck? And how low do you really want to go?
Those answers matter because one-size-fits-all advice does not work well in the NBS world. Two trucks can both be 2004 Silverados and still need different parts based on weight, driveline, wheel setup, and intended use.
This is exactly why truck-specific communities still matter. A platform like FullSizeChevy exists because truck guys need real-world feedback from owners who have already tried these combinations, not just polished marketing photos and generic fitment claims.
The smart way to lower an NBS truck
If you want the truck to look right and drive right, build the drop around the whole package. Choose a realistic ride height, use quality front components, make sure the rear still has travel, and plan wheel fitment before the truck is sitting on the ground.
A lowered NBS done right has a timeless look. It sits with purpose, drives with confidence, and feels like somebody actually thought the build through. That is always better than chasing the lowest number and sorting out the problems later.
The right drop should make you want to keep driving the truck, not just keep staring at it in the driveway.
Talk GMT800 with other owners
Open the GMT800 Forum →
GMT800 Chevy Truck Hoodie – Bucks & Trucks Camo (1999-2006 Silverado) | Bucks & Trucks Price range: $47.73 through $54.50
Heartbeat of America | ’06 Chevy Silverado Metal Garage Sign Price range: $34.18 through $112.27
Built Not Bought Chevy Truck Sticker | Full Size Chevy Vinyl Decal | Garage Tool Box Laptop Truck Window FSC Logo Price range: $1.98 through $12.57
FullSizeChevy Red Truck Sun Shade | FSC Windshield Sunshade for Chevy Trucks | Interior Heat Protection$49.86
FullSizeChevy White & Red Truck Sun Shade | FSC Windshield Sunshade for Chevy Trucks | Interior Heat Protection$49.86
Heartbeat of America | ’02 Chevy Silverado Metal Garage Sign Price range: $34.18 through $112.27
GMT800 Chevy Silverado T-Shirt – ’06 (1999-2006 Silverado) | Heartbeat of America Price range: $28.86 through $35.61
Built Not Bought Chevy Garage Sign | Full Size Chevy Truck Poster | Mechanic Shop Wall Decor | Truck Builder Garage Art Price range: $34.18 through $112.27
GMT800 Chevy Silverado T-Shirt – ’02 (1999-2006 Silverado) | Heartbeat of America Price range: $28.86 through $35.61
Bucks & Trucks | GMT800 T-Shirt Price range: $28.86 through $35.61
GMT800 Chevy Silverado T-Shirt – ’00 Custom (1999-2006 Silverado) | Heartbeat of America Price range: $28.86 through $35.61
FullSizeChevy Truck Sun Shade | FSC Windshield Sunshade for Chevy Trucks | Interior Heat Protection$49.86
