LS Swap Guide for Chevy & GMC Trucks
The LS swap is the most popular engine swap in history, and full-size GM trucks are the easiest place to do one. This hub organizes the FSC LS content by what you’re actually trying to figure out — how the engines and electronics differ, how to identify a donor, cost, kits, engine choice, wiring, mechanical systems, and buying a used LS — so you’re not piecing it together across a dozen posts. For platform-specific buying and build notes, see the Squarebody, OBS/GMT400, GMT800, and GMT900 hubs.
Latest LS Swap Content
Turbo 6.0L LS Chevy — Listen to It Rip
A turbocharged 6.0L LS-based Chevy on boost. If you’re planning a boosted LS swap, this is the kind of sound you’re chasing.
▶ Watch the Video
Show Your LS Build →
Start here
Choosing the engine
What it costs
Kits & parts
Mechanical systems
Wiring
Buying a used LS
Owner tools for your swap
Free, no sign-up. The decoder in particular earns its keep when you are identifying a donor.
  • GM RPO Decoder — if the donor is still a complete vehicle, photograph the SPID label and decode it before you hand over money. The RPO is the engine’s real name, and it beats a seller’s description or a valve cover every time.
  • GM RPO Code Database — every option code we hold, searchable by code or by plain description, and filterable to model year. Useful for pinning down the donor’s transmission and axle as well as the engine.
  • MPG Calculator — miles, gallons, engine. Worth a baseline before and after a swap.
Still on the bench: a tire, gear and speedometer calculator for working out how far off your speedo reads after a size change and what it did to your effective gearing, and quick identifiers for engine RPO, axle code, transfer case and AFM/DFM — the things you need standing at a parts counter.
See all FullSizeChevy owner tools →
Show your swap
Post your LS-swapped build in the FullSizeChevy forum →
Talk LS swaps with other builders
Post your swap combination, wiring problem, tuning issue, or build progress. FullSizeChevy members can help with the parts, wiring, drivetrain, and troubleshooting details.
Open the LS Swap Forum →
TECHNICAL INFORMATION NOTICE
Repair, modification, compatibility and specification information on FullSizeChevy.com is provided for general informational purposes only. Always verify procedures, torque values, parts fitment and safety requirements for your exact vehicle using factory service information before performing work. Repairs and modifications are performed at your own risk.
