Full-Size Chevy Truck Maintenance Checklist: Squarebody, OBS (GMT400), and GMT800
You’re juggling a beast of a Chevy truck that demands more than just an oil change. Squarebody, OBS, or GMT800, these rigs aren’t simple anymore—they’ve got quirks that bite if you skip the right service. This full-size Chevy truck maintenance checklist breaks down what your truck really needs, with no fluff, just straight talk and solid tips you can use today. Print it, track it, and hit up forum.fullsizechevy.com to swap notes with guys who know their way around these trucks.
Squarebody Maintenance Checklist
So, you’ve got a Squarebody Chevy truck. These classics have their own set of needs. Let’s dive into what keeps them running smooth.
Key Inspection Points
First off, give your Squarebody a solid look-over. Check the frame for rust. This is a biggie; rust can make or break your ride. Look at the suspension bushings too. Worn-out bushings can mess with your handling. Lastly, don’t forget the steering components. Keep an eye out for any play or wear.
Fluid and Filter Changes
Old oil can hurt your engine, so change it every 3,000 miles. Don’t skimp on the transmission fluid either. A change every 30,000 miles keeps shifts smooth and avoids costly repairs. The fuel filter should be swapped every 15,000 miles to maintain fuel efficiency. These simple steps will save you headaches down the road.
Common Failure Areas
Squarebodies are known for certain weak spots. The fuel pump often gives up first. Listen for odd noises and replace it before it leaves you stranded. The radiator is another common issue. Keep an eye on coolant levels and replace the radiator before it leaks. Head over to Campway’s annual maintenance checklist for more tips.
OBS GMT400 Maintenance Schedule
Now, let’s talk about the OBS GMT400, the 1988-1998 model. These trucks have their own quirks that need attention.
Drivetrain and 4L60E Service
Start with the drivetrain. Regular checks here prevent big problems. The 4L60E transmission needs love too. Change its fluid every 30,000 miles to keep things running smoothly. A dirty transmission can lead to slipping gears. Don’t let that be your story.
Intake Manifold and Alternator Issues
The intake manifold gasket often fails on these models. If you see coolant leaks, it’s time to change it. And watch out for the CS130 alternator. This unit is known to fail, leaving you without power. Swap it out when you notice dimming lights or battery issues. This Reddit thread has insights from other owners.
Inspection and Torque Highlights
Regular inspections are key. Keep an eye on the torque specifications for critical bolts. Loose bolts can lead to nasty surprises. Make sure you’re checking the brake system as well. Brakes save lives, after all. Tighten everything to factory specs, and your truck will thank you.
GMT800 Maintenance Guide
The GMT800, spanning 1999 to 2006, requires some special attention. Here’s what you need to focus on.
For the broader GMT800 ownership picture — engines, model-year differences, common failures, inspection checklist, and pricing — see the GMT800 buyer’s and owner’s guide.
Brake Line and Steering Concerns
Check those brake lines. They corrode over time, risking failure. Replace them if you spot any rust. The intermediate steering shaft often makes a clunking noise. Lubricate or replace it to restore smooth steering.
NV261 Pump Rub and Hub Wear
The NV261 transfer case is prone to pump rub. Install a pump rub fix kit to prevent costly damage. Watch out for the hub bearings too. If you hear grinding or feel vibrations, it’s time for new bearings. This prevents further drivetrain issues.
Electrical and Knock Sensor Checks
Electrical problems can be a hassle. Check your knock sensor, as it often fails in these models, affecting engine performance. A faulty knock sensor triggers engine lights and poor fuel economy. Ensure all connections are secure and replace parts as needed.
The longer you wait, the worse things can get. Regular checks and maintenance keep your truck on the road and out of the shop. Join the conversation at Full Size Chevy’s Facebook group for more tips and tricks.
Join the Forum
If you sweat the details on your GMT800/GMT900, you'll like the gear. Built for Silverado, Sierra, Tahoe, Suburban, and Yukon owners who actually do the work.
Shop FullSizeChevy Gear →
Talk GMT800 with other owners
Open the GMT800 Forum →
Keep going: find every OBS/GMT400 guide, known problem and fix in the OBS / GMT400 Hub.
