The No‑BS LS Swap Kit Guide for Squarebody, GMT400/OBS, GMT800, and GMT900
Most LS swap kits out there leave you guessing on fitment and missing key parts. You’re staring at a pile of components but still wondering if that oil pan clears your Squarebody or if those headers play nice with your GMT400 steering shaft. This guide breaks down what you really need for your chassis—from engine mount adapters to wiring harnesses—so you dodge the common traps and get your Chevy truck LS swap running right. Hit forum.fullsizechevy.com, start your build thread, and get the parts list dialed in with the community that’s done it before.
Before you order any kit: a “kit” is only right for a specific engine + chassis + 2WD/4WD combination. Confirm your donor first with how to identify an LS donor, understand the electronics with the Gen III vs Gen IV guide, and budget with the cost guide. Then match each component below to your truck — not a generic “LS swap kit.”
LS swap kit: component by component
ComponentHow to choose it (fitment factors)Watch-out
Engine mounts / adapterChassis-specific kit (ICT Billet, Dirty Dingo, Hooker Blackheart) that sets engine height and setback for steering-shaft and firewall clearance. Different part numbers for Squarebody vs GMT400.Mount geometry decides what oil pan and headers will clear — pick mounts first.
Oil panChosen for your crossmember, steering, engine/mount position and 2WD vs 4WD front-diff clearance — not a “front/rear-sump” label. The Holley 302-2 is a common rear-sump swap pan (Holley excludes LS7 and strokes over 3.62″).4WD front differential is the tightest constraint — verify the pan clears it.
Headers / exhaustPlatform-specific swap headers verified against your exact year, cab, 2WD/4WD and mount kit. Driver-side vs steering shaft is the #1 clearance point.Stock truck manifolds usually will not clear an older chassis.
Transmission crossmemberMatched to your trans (4L60E vs 4L80E vs 6L80E) and chassis; a 4L80E or six-speed usually needs a different mount location plus a driveshaft-length change.“Bolts up” isn’t enough — plan crossmember and driveshaft together.
Wiring harnessStandalone (Speartech, PSI, Painless) matched to your exact controller (P01/P59 vs E38, 24x vs 58x) and throttle type, or a modified OEM harness.Confirm the harness matches your controller and reluctor — see the wiring guide.
Fuel systemMatch rail style (return vs returnless) and pressure to your engine; older chassis need an EFI-capable in-tank pump or module.A factory carb/TBI pump cannot feed EFI.
Accessory driveTruck vs car/Corvette spacing changes clearance to frame, steering box and hood; truck spacing is usually easiest in a truck.Check steering-box and hood clearance for your layout.
Throttle + pedalCable (DBC) engines need a cable throttle body and bracket; drive-by-wire needs the matching electronic pedal (plus a TAC module on Gen III).You can’t “tune out” DBW — it’s a hardware match.
Calibration / securityAddress the donor security/VATS so it starts, plus injector, transmission, fan and emissions settings. A pre-programmed control package can arrive ready to run its hardware.Not always a blanket “VATS delete” — it’s application-dependent.
Emissions note: a swap’s legal road-use status depends on your jurisdiction (federal, state or provincial). Where inspections apply, retaining the donor’s emissions equipment and a compliant calibration matters — verify local rules before deleting emissions hardware.
Picking the Right LS Swap Kit
Getting the right kit for your truck is crucial. Let’s look at what you need for each Chevy truck model.
Squarebody LS Swap Essentials
Consider yourself fortunate if you’re working on a Squarebody. These classic trucks have ample space for LS swaps. You’ll want to start with Dirty Dingo mounts; they provide flexibility with engine positioning. Next, the Holley 302-2 oil pan is a solid choice, ensuring proper clearance. Don’t forget the exhaust: Speed Engineering headers can make a world of difference. They fit snugly and avoid those pesky clearance issues. For the wiring, a standalone harness is your best friend. Companies like PSI Conversion or BP Automotive offer options tailored to LS swaps. Lastly, plan your calibration: the donor PCM’s security/VATS has to be handled so the engine will start (application-dependent, not always a blanket “delete”), along with injector, fan, transmission and emissions settings.
Navigating GMT400 LS Swap Kits
The GMT400, often called the OBS, requires attention to detail. Start with ICT Billet brackets for an easy fitment. The Holley 302-2 oil pan works wonders here too. Headers can be tricky: Speed Engineering is your go-to brand, but check for interference with the steering shaft. For the electronic side, BP Automotive harnesses are a great fit. They simplify the wiring process immensely. If you’re moving from a 4L60E to a 4L80E swap, don’t forget a new transmission crossmember. Also, a return-style to returnless fuel system upgrade might come in handy.
Tips for GMT800 LS Swap Success
For GMT800 trucks, clearance isn’t as much of a problem. Still, Dirty Dingo mounts will help with precise placement. You’ll want a custom drive-by-wire pedal setup, so ensure compatibility with your harness. For the exhaust, Speed Engineering headers remain a top choice. In terms of wiring, the standalone harness from PSI Conversion streamlines everything. Make sure your PCM tuning is ready for a drive-by-cable throttle if needed. Lastly, consider upgrading to electric fans for better cooling efficiency.
Common Pitfalls and Solutions
Even the most seasoned mechanics face challenges. Let’s go through the common problems and fixes.
Avoiding Engine Mount Adapter Issues
Engine mounts are the backbone of your swap. Dirty Dingo mounts are adjustable, providing flexibility in positioning. Some might suggest cheaper alternatives but beware: they often lead to alignment issues. If you’re noticing misalignment, double-check the mount’s placement. Also, ensure the transmission crossmember lines up correctly. This step often gets overlooked, causing headaches down the line.
Steering Clear of Header Conflicts
Headers can be a nightmare. The problem usually lies in clearance. Speed Engineering headers are designed to minimize this issue. However, always check fitment before fully securing them. Use a temporary installation to spot any conflicts with the steering or frame. If you encounter issues, minor adjustments or spacers can help. It’s all about getting the right angle.
Overcoming Fuel System Challenges
Fuel systems can be a stumbling block if not addressed early. Switching from a return-style to a returnless system is common in LS swaps. Start by replacing the fuel pump with a high-pressure model. Also, consider steam port routing to prevent overheating. Don’t forget about the radiator upgrade; a new one can improve cooling, especially if you add electric fans.
Forum FullSizeChevy: Your Go-To Resource
Forum FullSizeChevy built not bought
Now that you have the basics, let’s discuss how you can engage with a community that breathes this stuff daily.
Starting Your Build Thread
Your first step is to start a build thread on the forum. Share your goals and current setup. This opens the door for feedback and advice from seasoned members. Don’t underestimate the power of community input. Many have been in your shoes and can offer insights you might overlook.
Engaging with the Community
Being active is key. Ask questions, share updates, and show progress. The more you interact, the more support you get. It’s not just about seeking help; your experiences can aid others too. You’ll find a wide range of topics, from engine swaps to suspension tweaks.
Sharing Parts Lists and Tips
Sharing your parts list is invaluable. It helps others learn what works and what doesn’t. Whether it’s a unique solution you found or a product that didn’t deliver, your insights are gold. Plus, you’ll get recommendations on alternatives that might be more effective.
In summary, getting your LS swap right takes the right parts and a supportive community. Visit forum.fullsizechevy.com to start your journey today.
Building or buying the donor GMT800? The GMT800 platform and owner’s guide covers engines, years, common problems, inspection checklist, and pricing for the 1999–2006 Silverado and Sierra.
Join the Forum
Running an LS in your Chevy or GMC?
Wear the swap. FullSizeChevy gear for Squarebody, OBS, GMT800, and GMT900 builders — clean designs, no mall-brand clip art.
Shop the Gear →
Talk GMT800 with other owners
Open the GMT800 Forum →
Keep going: find every OBS/GMT400 guide, known problem and fix in the OBS / GMT400 Hub and the Squarebody Hub.
