Published August 2, 2026 · Updated October 29, 2026 · How we source this
LS Swap Cost: How to Build a Real Budget (Not a Made-Up Number)
Every “LS swap costs $X” article is quoting a build — a specific engine, in a specific truck, with specific choices, at a specific time and place. Copy that number and you’ll be wrong, because your donor completeness, controller path, transmission, chassis and labor are different. This guide doesn’t hand you a total; it hands you the cost structure so you can build a realistic figure for your swap.
Ready to plan the whole build? Our free printable LS Swap Checklist for Chevy & GMC trucks includes a budget worksheet and every project gate from donor identification to road test.
About the dollar ranges below: they’re representative, U.S., and change constantly with the used market. Treat them as relative weightings, not quotes — and always re-price locally before committing. Every range should carry a mental asterisk: date, region and condition dependent.
The five things that actually set your budget
- Donor completeness — a long block vs. a complete “pull” (engine + harness + PCM + accessories + pedal) is the single biggest swing.
- Controller & wiring strategy — reuse the factory PCM with a modified harness, buy a standalone harness, or go aftermarket ECU.
- Transmission — reuse vs. rebuild vs. step up to a 4L80E or a 6-speed (which adds control-module cost).
- Chassis — mounts, oil pan, crossmember, driveshaft, fuel and cooling work vary a lot by platform and 2WD/4WD.
- Labor — DIY, or shop time on top of parts. This is often the largest line and the most variable.
1. The engine (donor completeness)
| What you’re buying | Representative range* | Notes |
| Iron 5.3 (LM7) long block | $400–$900 | cheapest entry; you’ll source accessories/harness separately |
| Iron 5.3 complete pull (engine, harness, PCM, accessories, pedal) | $900–$1,800 | best value — you get the wiring/PCM you’ll need anyway |
| Iron 6.0 (LQ4/LQ9) complete pull | $1,200–$2,500 | torque/tow budget engine |
| 6.2 (LS3/L92) complete | $2,500–$5,000+ | power tier; rec-port heads |
Buy the complete pull when you can. A cheap long block feels like a win until you’re separately buying the harness, PCM, pedal, accessory drive and coil packs — which usually costs more than the “expensive” complete pull would have. *date/region/condition dependent.
2. Wiring & controller strategy
| Path | Representative range* | Best for |
| Modify factory harness + reuse PCM + tune | $150–$500 + tune | DIY-capable, in-family upgrades (GMT800/900) |
| Standalone harness (Speartech/PSI/Painless) | $500–$1,800 | older platforms (Squarebody/OBS) with no EFI infrastructure |
| Aftermarket standalone ECU (Holley, etc.) | $1,000–$2,500+ | heavily modified / boosted / non-factory setups |
The controller choice drives this line. Reusing the engine’s original matched PCM is usually cheapest and safest. A drive-by-wire engine adds the pedal and (on Gen III) a TAC module to the bill. Don’t assume you can “delete” DBW to save money — that’s a hardware conversion, not a free tune.
3. Transmission
| Choice | Representative range* | Notes |
| Reuse donor 4L60E | $0–$300 (service) | good to ~400–450 hp |
| Built 4L60E | $1,200–$2,500 | adds capacity/reliability |
| 4L80E (used + swap costs) | $800–$2,500 | towing/high power; different crossmember + driveshaft |
| 6L80E/6L90E + control module | $1,500–$3,500+ | six-speed; must budget the T43/control strategy |
The six-speed’s hidden cost is control. A 6L80E isn’t just a used transmission price — it needs the T43 control-module strategy and network, plus possibly a different crossmember and driveshaft. Factor that before you fall in love with the six-speed.
4. Chassis-specific supporting parts
This is where two builds with the same engine diverge. Typical line items: motor mount adapter kit ($150–$400), swap oil pan chosen for your chassis and 2WD/4WD clearance ($200–$500), transmission crossmember ($100–$400), fuel system (in-tank EFI pump/return work, $200–$500), cooling (radiator/fans, $200–$700), headers/exhaust ($300–$1,200), driveshaft length/yoke work ($150–$500), and accessory-drive adjustments. On an older chassis (Squarebody/OBS) you’ll hit more of these; on a GMT800/900 upgrade, far fewer.
Separate required from optional. Mounts, pan, fuel, cooling and driveshaft are usually required. Headers, big intakes, and accessory upgrades are often optional power/appearance choices — don’t let them inflate your “swap cost” baseline.
5. Labor
DIY, and labor is your time. Shop-built, and labor is frequently the biggest single number — commonly $3,000–$8,000+ depending on platform complexity, region shop rates, and how much fabrication (mounts, exhaust, fuel, wiring) the build needs. A GMT800 in-family upgrade is a fraction of a from-scratch Squarebody swap. Get a quote against your specific plan; a generic labor figure is meaningless.
Putting it together: three honest scenarios
These are illustrative stacks, not quotes — build your own from the sections above.
- Budget DIY, older truck: complete iron 5.3 pull + standalone harness + reused 4L60E + mounts/pan/fuel/cooling, your own labor → parts commonly land in the $3,000–$6,000 range.
- Mid performance, DIY: 6.0 or 6.2 + standalone or modified harness + built 4L60E/4L80E + supporting parts → $6,000–$12,000 in parts.
- Shop-built performance: the above plus $3,000–$8,000+ labor on top.
All figures U.S., representative, and date/region/condition dependent — re-price locally.
Where costs hide
- The “cheap” long block that needs $1,000 of accessories/harness/PCM to become a complete engine.
- The six-speed bought without budgeting its control module and network.
- DBW “delete” assumed to be free — it’s a hardware conversion.
- Fuel system on a carb/TBI-era chassis — the factory pump can’t feed EFI; plan for it.
- Tune — most production-donor swaps need calibration work; a pre-programmed control package is the exception, not the rule.
Revision: draft v1 (2026-08-02). Cost structure is durable; dollar ranges are representative and require local, current re-pricing before use.
Keep going: pick the engine in Best LS Engine by Goal, then plan the build from the LS Swap Hub.
