OBS Chevy LS Swap Wiring Harness Guide: Standalone vs. OEM, Key Connections & Tune
The wiring harness is the piece of an LS swap that turns a running engine into a running truck. Get it wrong and you have a great-sounding paperweight in your driveway. This guide covers every wiring option for an OBS Chevy / GMC truck (1988–1998) LS swap — from standalone harnesses to full OEM harness modifications — with the specific connections, delete options, and tune requirements that apply to OBS builds specifically.
Planning an OBS LS swap? Track every wiring, fuel, and calibration step with our free printable LS Swap Checklist for Chevy & GMC trucks.
Why OBS LS Swap Wiring Is Different
OBS trucks (GMT400, 1988–1998) have a relatively simple factory electrical system — minimal body control modules, straightforward instrument clusters, and no CAN bus. This is an advantage for LS swaps because you don’t need to integrate the donor engine’s ECM with a complex factory network. The challenge is the LS ECM itself — it needs to manage fuel, ignition, and emissions without the vehicle it was designed for, and the donor harness has to be adapted to a truck that is significantly different from the donor.
Donor Engine and ECM Combinations
The wiring approach depends heavily on which LS engine you’re swapping. The most common OBS LS swap donors:
  • LM7 5.3L / LR4 4.8L (1999–2007 GMT800 truck): These are two different displacements — the LM7 is the 5.3L and the LR4 is the 4.8L; they share the Gen III truck architecture but are not the same engine, so match parts to the specific RPO. These Gen III truck engines use a P01/P59-era engine controller (the late version is often called the “0411” PCM), not the Gen IV E38 — always identify the controller by its service-number label and by the exact donor year, transmission and throttle type rather than by model year alone. Most 1999–2006 truck LM7/LR4 engines are drive-by-cable, which is the easiest route for an OBS build because the throttle links mechanically. Later drive-by-wire truck engines can be run in an OBS, but converting drive-by-wire to drive-by-cable is a hardware change — it requires a compatible cable throttle body, a matching TPS, an IAC-capable intake or adapter, harness changes and the correct PCM strategy. A tune alone cannot “delete” drive-by-wire; the cable hardware has to physically be there.
  • LQ4 / LQ9 6.0L (1999–2007 truck): Same Gen III truck controller family as the LM7/LR4 and the same wiring considerations. Preferred choice for towing builds.
  • LS1 5.7L (1997–2004 car — F-body or C5 Corvette): LS1 throttle type depends on the application, so don’t treat every LS1 the same. F-body LS1 packages (Camaro/Firebird) are commonly drive-by-cable, which makes them an excellent OBS swap candidate. C5 Corvette LS1 packages use drive-by-wire and need the matching pedal and controller strategy. Confirm the throttle body and pedal on your specific donor before buying — the controller and harness differ between the cable and wire cars.
Wiring Approach Options
Option 1: Standalone Wiring Harness (Recommended for Most Builds)
A standalone harness is a purpose-built harness that takes only the wires the engine needs to run and puts them in a clean, labeled loom. All body-specific wiring from the donor is eliminated. The result: a compact harness that connects the engine PCM to only what it needs — injectors, coils, sensors, cam/crank position, O2 sensors, and fuel pump relay.
Best standalone harness vendors for OBS LS swaps:
  • Speartech: Industry standard. Custom-built to your specific PCM and engine combination. Specifies OBD-II port location, fan relay wiring, and VSS hookup. Prices range $500–$900 depending on options. www.speartech.com. Highly recommended — Speartech harnesses are documented extensively on the FullSizeChevy.com forum.
  • Painless Performance: Pre-built standalone harness kits for common LS combinations. Less custom than Speartech but more widely available from parts stores. Painless catalogs separate kits by application — confirm the correct kit for your engine’s crank reluctor (24x vs 58x) and throttle type (cable vs drive-by-wire) against Painless’s current fitment listing before ordering, because the wrong kit will not match your PCM. Approximately $400–$600.
  • PSI (Performance Systems Integration): Good value. Offers complete stand-alone harnesses for most LS truck engines with clear instructions. Popular choice on budget builds.
  • DIY harness from OEM donor: Possible but time-consuming. Requires pulling the full engine harness from the donor and reworking it against the factory schematic — see the OEM-harness method below. Only recommended if you’re experienced with wiring and want to save $400+.
Option 2: Modified OEM Donor Harness
Take the complete engine harness from the donor truck and modify it to work standalone. This is the DIY version of a standalone harness. The OEM harness from a GMT800 Silverado donor (same engine family) contains all the connectors you need — the work is isolating the engine-run circuits from the body-side wiring and adding relay circuits for the fuel pump and fans.
Steps for modifying an OEM truck harness:
  • Remove the full engine harness from the donor. Label every connector before unplugging.
  • Work from the factory wiring schematic and connector views for your specific donor — not from subsystem names. It is tempting to “cut everything for the HVAC, ABS, cluster and body,” but a donor engine harness routes shared power feeds, grounds, splice packs, serial data (Class 2 / GMLAN), brake-input, VSS and transmission circuits through those same areas. Cutting by subsystem label instead of by documented circuit can remove a wire the ECM still needs. Isolate the engine-run circuits against the factory diagram, verify each removed wire’s function, and preserve every shared power, ground and data circuit.
  • Keep: all engine sensor wiring (MAF, MAP, IAT, ECT, CKP, CMP), all injector and coil wiring, all O2 sensor wiring, the PCM connectors, the fuel-pump control/relay circuit, and the A/C compressor clutch wire (if keeping A/C).
  • Add: an ignition (key-on) power source from the OBS ignition switch, a relay for the fuel pump, a relay for cooling fans (electric fan swap required), and a clean constant 12V feed for the PCM.
Key Connections: OBS-Specific Notes
Ignition and Power
The LS PCM needs two power sources: constant 12V (battery feed for PCM keep-alive memory) and key-on 12V (to power the PCM when the ignition is on). On OBS trucks, tap the key-on 12V from the ignition switch feed wire (pink/black wire on the OBS fusebox) or add a dedicated relay triggered by the ignition circuit. The constant 12V goes directly to battery or a fused junction block. Ground the PCM to a dedicated chassis ground point — use a clean, paint-free bolt directly to the firewall or chassis rail. A bad PCM ground is the #1 cause of unexplained LS swap electrical gremlins.
Tachometer Signal
The OBS tachometer expects a low-voltage square-wave reference signal typical of the pre-LS GM system, which does not match the LS PCM’s tach output directly. Two solutions: (1) use a tach signal adapter (Dakota Digital SGI-5E or equivalent — $50–$80), or (2) tune the PCM’s tach output to match the OBS cluster (possible with HP Tuners or EFILive on most LS PCMs). The Dakota Digital adapter is the plug-and-play approach and is the most reliable on OBS trucks.
Vehicle Speed Sensor (VSS)
The LS PCM needs a vehicle-speed (VSS) signal for transmission control and speedometer calibration. Don’t assume your OBS has a cable-only speedometer — GMT400 instrument clusters and speed sensing changed over the 1988–1998 run and by powertrain, and many of these trucks already use an electronic VSS on the transmission or transfer case rather than a speedometer cable. Identify what your specific truck (year, cluster, transmission) actually uses before you wire anything. Most GM 4L60E and 4L80E transmissions from the LS era provide an electronic VSS signal the PCM can read. If your build uses an older TH350 or TH400 with no electronic output, add an aftermarket VSS sender (Lokar or similar), or configure the PCM/transmission calibration for the sensor arrangement you actually have. Confirm speedometer drive against the factory service information for your year rather than a blanket “OBS is mechanical” rule.
Fuel System
LS engines require higher fuel pressure than the carburetor or TBI setups of the OBS era. A typical LS wants roughly 55–62 PSI on a returnless rail or 48–58 PSI on a return-style rail — confirm the spec for your specific rail. OBS fuel system options:
  • In-tank EFI pump conversion: Best long-term solution. Tanks Inc. and Aeromotive both make OBS-specific in-tank EFI pump modules that fit the factory tank location. ~$200–$350. Feeds the LS fuel rail directly with correct pressure and volume.
  • External inline pump: Walbro 255 LPH inline pump mounted on the frame rail near the tank. Cheaper ($60–$90 for the pump) but more exposed and requires careful mounting away from heat sources. Acceptable for builds but not preferred for long-term reliability.
  • Return line: Don’t assume your OBS has no return line — GMT400 fuel systems changed across the run and by engine. The 1988–1995 TBI trucks run a lower-pressure system that already has a return, while the 1996–1998 Vortec (CSFI) trucks use a higher-pressure, returnless-style arrangement; the tank, sender, pump module and plumbing differ between them. Identify what your specific year and engine actually have before planning the LS fuel system. A return-style LS fuel rail needs a return path back to the tank (Tanks Inc. EFI tank modules include the return fitting), while a returnless LS truck rail — most Gen III/IV truck rails are returnless — can simplify the plumbing. Match the pump module, pressure and return/returnless arrangement to your rail and your existing tank.
Cooling System / Electric Fans
Most OBS swaps retain the mechanical fan, which works with LS engines — especially truck builds where cooling capacity and simplicity matter more than hood clearance. If you go electric fans (common in performance and restomod builds), the LS PCM can control them via the fan relay output wires. Wire a dual-fan relay pack to the PCM fan output (switched ground from PCM) and the electric fan 12V feed through a suitably rated relay. The PCM controls fan on/off based on coolant temp — typically around 220°F on / 235°F off in a stock tune, adjustable with HP Tuners.
Oxygen Sensors
Use the O2 sensors from the donor engine or install new equivalents in the exhaust. LS engines use heated wideband (AFR) or narrowband O2 sensors depending on the controller — match the sensor type to what your PCM expects. OBS headers and manifolds need a bung welded at the correct location — roughly 6–18″ downstream of each exhaust manifold exit. Running without O2 sensors requires a tune that disables O2 monitoring (open-loop fuel control — not recommended for daily drivers).
Tune Requirements
Most OBS LS swaps need calibration work, but what “a tune” actually covers depends on your donor and controller. At minimum the calibration usually must:
  • Disable VATS/PassLock (the donor security system) — a donor PCM is keyed to the donor vehicle, so without the security change the truck may crank but not run.
  • Remove or disable trouble codes for components you’re not using (EVAP, EGR, AIR pump if deleted).
  • Set correct injector data for your specific injectors (if changed from stock).
  • Set the correct MAF transfer function if the MAF housing diameter changed (or switch to speed-density if you delete the MAF).
  • Configure the transmission segment, gear ratio and tire size for your drivetrain.
  • Adjust tach signal output if not using an external tach adapter.
Tune source options: HP Tuners MPVI-series with a custom tune from a GM specialist is the professional route. For a basic running calibration, many standalone harness vendors (Speartech, PSI) supply a base operating tune with their harness that handles the security and emissions deletes — enough to start and drive to a tuner for a full custom tune. A correctly matched, pre-calibrated control package can also arrive ready to run its specified hardware, so confirm what your specific combination needs rather than assuming a full custom tune is always required.
Related Guides
Building your OBS from scratch? The OBS Build Planning Guide covers the complete phase order — wiring and electrical come after rust/structure, drivetrain, and suspension are sorted. Use it as your master roadmap before committing the harness installation.
For full LS swap budget planning: LS swap cost breakdown — complete guide.
Running an LS in your Chevy or GMC?
Wear the swap. FullSizeChevy gear for Squarebody, OBS, GMT800, and GMT900 builders — clean designs, no mall-brand clip art.
Shop the Gear →
Keep going: find LS swap kits, wiring, costs and engine picks in the LS Swap Hub and the OBS / GMT400 Hub.
Open the OBS / GMT400 Forum →
OBS GMT400 Chevy Truck T-Shirt – Orange Route 66 Gas Station (1988-1998 Silverado) | OBS Legends Price range: $28.86 through $35.61
OBS GMT400 Chevy Truck T-Shirt – White Palm Trees & City (1988-1998 Silverado) | OBS Legends Price range: $28.86 through $35.61
Keep it Fullsize FSC Retro | Flame Logo Vinyl Sticker Price range: $1.98 through $12.57
OBS GMT400 Chevy Truck T-Shirt – Ice Blue City (1988-1998 Silverado) | GMT400 Crew Price range: $28.86 through $35.61
OBS GMT400 Chevy Truck Hoodie – Keep It Full Size (1988-1998 Silverado) | Keep It Full Size Price range: $47.73 through $54.50
OBS GMT400 Chevy Truck T-Shirt – Green Graffiti Neon II (1988-1998 Silverado) | OBS Legends Price range: $28.86 through $35.61
OBS GMT400 Chevy Truck T-Shirt – Green Sunset Neon Skyline (1988-1998 Silverado) | OBS Legends Price range: $28.86 through $35.61
Keep It Fullsize | OBS Chevy Vinyl Sticker Price range: $1.98 through $12.57
OBS GMT400 Chevy Truck T-Shirt – Green Neon City Sunset (1988-1998 Silverado) | OBS Legends Price range: $28.86 through $35.61
Keep It Full Size OBS Chevy Truck Poster | Classic 88-98 Chevy Pickup Garage Wall Art | Full Size Truck Enthusiast Decor Price range: $34.18 through $112.27
OBS GMT400 Chevy Truck T-Shirt – Red City (1988-1998 Silverado) | GMT400 Crew Price range: $28.86 through $35.61
OBS GMT400 Chevy Truck T-Shirt – Purple Neon Beach Sunset (1988-1998 Silverado) | OBS Legends Price range: $28.86 through $35.61
