Published April 26, 2026 · Updated November 12, 2026 · How we source this
Best Exhaust for 5.3 Silverado: Borla vs. MagnaFlow vs. Flowmaster (GMT900, K2XX, T1XX)
If you own a Chevy Silverado 1500 with the 5.3L V8, you already know that engine has serious potential sitting under the hood. The problem is, from the factory, it sounds like it’s trying to be polite. A proper exhaust upgrade on the 5.3 Silverado is one of the first — and best — modifications you can make. It wakes up the sound, frees up a little power, and honestly just makes every drive more enjoyable.
But walk into any truck forum or search online and you’ll find a hundred different opinions. Borla or Flowmaster? Catback or axle-back? Aggressive or daily-driver friendly? This guide cuts through the noise. We researched the setups Silverado owners run most and put together this list of exhaust systems for the 5.3 Silverado — broken down by sound, budget, and use case.
Whether you’re building a weekend show truck or just want your commute to sound better, there’s a right answer here.
Catback vs. Axle-Back vs. Header-Back: What’s the Difference?
Before you spend a dollar, you need to know which type of exhaust system you’re actually buying. These terms get thrown around like everyone already knows what they mean — they don’t.
Axle-back exhaust replaces only the section of pipe from your rear axle back to the tips. It’s the cheapest and easiest to install — usually a 30-minute job with basic hand tools. The downside: you’re only changing the tail end of the system, so sound improvement is noticeable but limited. On the 5.3 Silverado, an axle-back will give you better exhaust note at idle and under light throttle, but you won’t hear much at highway speeds.
Catback exhaust replaces everything from the catalytic converter back — the mid-pipe, muffler, and tips. This is the sweet spot for most Silverado owners. You get a meaningful sound upgrade across the full RPM range, a slight power gain (usually 5–12 hp), and it’s still a bolt-on install that most DIYers can complete in 1–3 hours. This is what the majority of the products in this guide are.
Header-back exhaust replaces everything from the exhaust manifolds all the way back. Maximum sound and power gains, but you’re looking at a full day of work (or shop labor), more money, and potentially emissions issues depending on your state. Best left for dedicated performance builds, not daily drivers.
For most 5.3 Silverado owners, a catback is the right call. It’s the best balance of sound, power, and ease of installation.
The Best Exhaust Systems for the 5.3 Silverado
1. Borla S-Type Cat-Back Exhaust — Best Overall
If you want the best of everything — deep sound, zero drone, premium construction — the Borla S-Type is the exhaust most serious Silverado owners eventually land on. Made from T-304 stainless steel and backed by Borla’s million-mile warranty, this is a buy-it-once piece.
The S-Type hits what most 5.3 owners are looking for: a deep, authoritative rumble at idle that opens up into a strong growl under throttle, without droning at 70 mph on the highway. It’s the “refined aggressive” option. If you want to shake windows, look at the ATAK instead (more on that below). If you want something that sounds great without annoying your passengers on a road trip, the S-Type is your pick.
Fitment: 2014–2024 Silverado 1500 (5.3L) — check Borla’s fitment guide for cab/bed combinations.
| Pros | Cons |
| Zero highway drone | Premium price ($700–$900) |
| Deep, aggressive sound character | Professional install recommended |
| T-304 stainless — won’t rust | Not legal in all states for street use (check CARB) |
| Million-mile warranty | |
| Noticeable power gain at WOT |
Sound character: Deep rumble at idle → strong throaty growl under acceleration → settles to a refined burble at cruise.
Price range: $700–$900
Install difficulty: Moderate — 2–3 hours, professional recommended for best fit.
Bottom line: The Borla S-Type is the benchmark. It costs more, but you’re paying for sound quality, build quality, and a warranty that backs it up. If budget isn’t the primary concern, start here.
2. Borla ATAK Cat-Back Exhaust — Best for Maximum Sound
The ATAK (Acoustically Tuned Applied Kinetics) is Borla’s most aggressive street exhaust. Where the S-Type is a refined growl, the ATAK is a statement. Louder at idle, more raspy under acceleration, and genuinely aggressive on hard pulls. If you want people to hear your truck coming, this is it.
Fair warning: the ATAK is not a daily driver exhaust for everyone. Some owners report mild drone at specific RPM ranges (typically 1,800–2,200 RPM), though it’s far less than budget mufflers. On extended highway drives, it can be noticeable. If you’re building a show truck or a weekend performance rig, the ATAK is perfect. If the Silverado is your daily commuter, the S-Type is the smarter call.
| Pros | Cons |
| Maximum sound output | Some highway drone reported |
| Aggressive, raspy character | Premium price ($750–$950) |
| Same T-304 stainless build as S-Type | Too loud for some daily driver use |
Sound character: Loud, raspy idle → aggressive, head-turning growl under throttle → noticeable highway presence.
Price range: $750–$950
Install difficulty: Moderate — 2–3 hours.
Bottom line: Pick the ATAK if you want the most aggressive sound Borla offers. Pick the S-Type if you want aggressive sound with highway manners.
3. Flowmaster Super 44 Cat-Back Exhaust — Best Value
Flowmaster has been in Silverado exhaust bays since the 1990s, and the Super 44 remains one of the most popular choices for good reason: it delivers a classic American muscle truck sound at a fraction of the Borla price.
The Super 44 uses Flowmaster’s Delta Flow technology inside a straight-through muffler design, producing a deep, aggressive tone with a slight rasp that a lot of truck guys love. It’s louder than the S-Type and more traditional sounding — think old-school V8 muscle, not refined European performance. On the 5.3 Silverado, the Super 44 produces excellent sound from idle through mid-throttle.
The honest caveat: the Super 44 can drone on highway drives, particularly at steady-state RPMs between 1,500–2,000. It’s manageable for most, but if you’re sensitive to interior drone, either look at the 50 Series or step up to Borla.
Fitment: Multiple years — verify fitment by year, cab, and bed length at Flowmaster’s site.
| Pros | Cons |
| Excellent price ($250–$400) | Highway drone possible |
| Deep, aggressive classic truck sound | Not as refined as Borla |
| DIY-friendly install | Interior noise on long drives |
| Widely available | |
| Good power gains for the price |
Sound character: Deep, aggressive idle → classic V8 growl under throttle → noticeable cruise note.
Price range: $250–$400
Install difficulty: Easy — 1–2 hours, good DIY option.
Bottom line: The Super 44 is the best value pick for owners who want real sound improvement without the premium price. Ideal if you enjoy a classic, old-school truck sound and aren’t bothered by some cruise drone.
4. Flowmaster Super 10 — Best for Maximum Aggressive Sound on a Budget
If the Super 44 is a strong V8 growl, the Super 10 is what happens when you turn that up to eleven. Single-chamber straight-through design, minimal sound dampening, and one of the loudest options available at this price point. This is not a subtle exhaust.
The Super 10 is extremely popular with Silverado owners who want the loudest possible sound without spending Borla money. It’s raw, aggressive, and proud about it. It also has more drone than the Super 44, which is the trade-off for the sound level. This is a truck-show or weekend cruiser exhaust, not a quiet daily driver.
| Pros | Cons |
| Very aggressive, loud sound | Significant highway drone |
| Low price ($200–$350) | Very loud inside the cab |
| Easy DIY install | Not ideal for daily use |
Price range: $200–$350
Install difficulty: Easy — 1–2 hours.
Bottom line: The loudest option at a budget price. Great for show trucks and weekend builds. If you drive it every day, you might regret it after a week.
5. Magnaflow Street Series Cat-Back — Best Mid-Range with No Drone
Magnaflow splits the difference that a lot of 5.3 Silverado owners are looking for: noticeably better sound than stock, zero highway drone, and a price point that doesn’t require financing. The Street Series uses straight-through perforated cores that keep the exhaust note smooth and refined.
The Magnaflow sound profile is deeper and fuller than stock but stays on the controlled side — it’s not going to rattle windows. If you’re upgrading for a better sound character without crossing into “everyone can hear me coming” territory, Magnaflow nails that balance. It’s also a legitimate option for daily drivers who want improvement without sacrifice.
| Pros | Cons |
| Zero drone — genuinely quiet at cruise | Less aggressive than Borla or Flowmaster |
| Deep, refined sound | Not for owners who want max volume |
| Good build quality | |
| DIY-friendly |
Sound character: Mild-to-moderate deep tone at idle → smooth, refined growl under acceleration → near-silent at cruise.
Price range: $350–$550
Bottom line: The best option for daily drivers who want improved sound without any highway drone. The “sleeper” choice — it sounds better than stock without announcing itself.
6. Corsa Sport Cat-Back — Best for Daily Drivers Who Want It All
Corsa uses patented Reflective Sound Cancellation technology, which is exactly what it sounds like: the exhaust system actively cancels drone frequencies while preserving the performance sound you actually want. The result is an exhaust that sounds aggressive under throttle and near-silent at cruise.
It’s the most engineered option on this list and priced accordingly. But if you drive your Silverado every day and want the best of both worlds — great sound when you’re on it, no drone when you’re not — Corsa is worth every dollar.
| Pros | Cons |
| Zero drone — patented RSC technology | Premium price ($600–$900) |
| Aggressive sound under throttle | Less raw character than Borla ATAK |
| Ideal daily driver | |
| Excellent build quality |
Price range: $600–$900
Install difficulty: Moderate — 2 hours.
Bottom line: The smartest choice for owners who put real miles on their Silverado and refuse to compromise on either sound or comfort.
Budget Tier Comparison Table
| Brand / Model | Price Range | Sound Level | Highway Drone | Install DIY? | Best For |
| Flowmaster Super 10 | $200–$350 | Very Aggressive | High | Yes | Weekend/show truck |
| Flowmaster Super 44 | $250–$400 | Aggressive | Moderate | Yes | Best value daily/weekend |
| Magnaflow Street Series | $350–$550 | Mild–Moderate | None | Yes | Quiet daily driver |
| Borla S-Type | $700–$900 | Aggressive | None | Pro Rec. | Best overall |
| Corsa Sport | $600–$900 | Aggressive | None | Moderate | Best daily driver |
| Borla ATAK | $750–$950 | Very Aggressive | Low–Moderate | Pro Rec. | Max sound, premium build |
Sound Character Guide: Picking the Right Level for You
Not every 5.3 Silverado owner wants the same thing. Here’s how to match the exhaust to your actual driving life.
Mild — Daily Driver Refined
Sound: Deeper and fuller than stock. You’ll notice the difference, but your passengers won’t complain and your neighbors won’t hate you. Minimal to zero drone at highway speeds. Best picks: Magnaflow Street Series, Corsa Sport What it sounds like: “Sounds like a V8 should — not stock, but not a race truck.”
Moderate — Weekend Warrior Balance
Sound: Clear, aggressive growl under throttle. Noticeable at idle. Opens up well during acceleration. Manageable drone at highway speeds for most owners. Best picks: Flowmaster Super 44, Borla S-Type What it sounds like: “People notice it in a parking lot but it doesn’t rattle your fillings at 70 mph.”
Aggressive — Show Truck / Performance Build
Sound: Loud, raw, and proud of it. You will be heard. Significant interior volume on the highway. Built for trucks that turn heads, not quiet commutes. Best picks: Flowmaster Super 10, Borla ATAK What it sounds like: “It starts, and your neighbor’s dog starts barking.”
Fitment by Generation: 5.3L Silverado 1500
One of the most common mistakes buyers make: ordering an exhaust without checking cab and bed length fitment. Most manufacturers offer multiple part numbers for the same model year depending on whether you have a regular cab, extended cab (double cab), or crew cab, and whether you have a standard bed, short bed, or long bed.
| Generation | Years | Key Notes |
| Gen 1 (GMT800) | 1999–2006 | Fewer aftermarket options available. Verify carefully. Flex pipe condition is a common issue on older trucks before buying. |
| Gen 2 (GMT900) | 2007–2013 | Strong aftermarket support. Most major brands offer multiple options. Check cab/bed combo. |
| Gen 3 (K2XX) | 2014–2018 | Best aftermarket support. Most products in this guide are primarily designed for this generation. |
| Gen 4 (T1XX) | 2019–Present | Growing aftermarket support. Confirm fitment — some Gen 3 exhausts do not fit Gen 4 without modification. |
Always verify your exact part number using the manufacturer’s fitment tool before purchasing. When in doubt, call the manufacturer’s tech line — Borla and Flowmaster both have knowledgeable reps who can confirm fitment in two minutes.
Does Exhaust Add Horsepower to the 5.3 Silverado?
Yes — with realistic expectations. A catback exhaust system on the 5.3L V8 Silverado typically produces 5–15 horsepower gains, with most gains appearing in the upper RPM range where airflow restriction matters most. Dyno results from Borla, Flowmaster, and Magnaflow systems on the 5.3 commonly show 8–12 hp at peak, with slightly better torque numbers throughout the mid-range.
That said, the numbers depend on your specific setup, tune, and whether you pair the exhaust with other airflow improvements like a cold air intake. If you’re chasing big horsepower numbers, an exhaust alone won’t get you there. But if you’re looking for a bolt-on that improves throttle response, adds 5–12 hp, and makes the truck sound genuinely better — a catback is one of the best value modifications you can make to the 5.3.
Frequently Asked Questions
Does the 5.3 Silverado exhaust drone on the highway? It depends on the muffler. Straight-through single-chamber mufflers like the Flowmaster Super 10 or Super 44 can produce noticeable cabin drone at highway cruise RPMs (typically 1,500–2,200 RPM). Corsa Sport uses patented technology to actively cancel drone. Borla S-Type and Magnaflow Street Series both have minimal to no drone. If highway driving is important to you, prioritize those options.
Borla vs. Flowmaster for 5.3 Silverado — which is better? Depends on what you’re optimizing for. Borla wins on build quality, sound refinement, drone elimination, and warranty — but costs 2–3x more. Flowmaster wins on price, classic truck sound character, and easy DIY installation. If budget isn’t the issue, Borla. If you want the best sound-per-dollar and don’t mind some drone, Flowmaster Super 44.
What’s the best exhaust for a 5.3 Silverado under $300? The Flowmaster Super 44 is the strongest option under $300, offering real sound improvement, decent power gains, and a straightforward DIY install. The Super 10 is also under $300 if you want maximum aggression at the cost of more drone.
Will a cat-back exhaust pass emissions on a 5.3 Silverado? In most states, yes — a catback system does not modify or remove catalytic converters, so it typically passes emissions testing. However, California (CARB) has stricter rules, and some exhausts are not CARB-compliant. Always verify CARB compliance if you’re in California or states that follow California emissions standards.
How long does it take to install a cat-back exhaust on a Silverado? Most DIYers with basic hand tools and a floor jack complete a catback installation in 1–3 hours. The main variable is how corroded or seized the factory hardware is — on older trucks (pre-2014), plan extra time to deal with rusted clamps and hangers. New trucks (2014+) usually go smoothly. A lift makes the job significantly easier.
Which exhaust fits how you drive
The best exhaust for your 5.3 Silverado comes down to one honest question: how are you actually going to drive it?
- Daily driver, zero drone: Corsa Sport or Magnaflow Street Series
- Best overall sound and quality: Borla S-Type
- Maximum aggressive sound: Borla ATAK
- Best value: Flowmaster Super 44
- Loudest budget option: Flowmaster Super 10
Any of these upgrades will wake up the 5.3’s sound in a way the factory exhaust never could. Pick the one that fits your driving style and budget — and enjoy the drive home after install day.
Have a 5.3 exhaust setup you love? Drop your experience in the comments — the FSC community wants to hear what’s working on your truck.
Talk GMT900 with other owners
Post your truck, your build, or the problem you are chasing. Real GMT900 owners in the FSC forum will tell you what actually worked on theirs.
Open the GMT900 Forum →GMT900 Gear
Shop all GMT900 gear →Find every repair, buying, maintenance, and troubleshooting guide in the GMT900 Owner’s Hub.
Keep going: find every K2XX guide, known problem and fix in the K2XX Hub and the T1XX Hub.
