GMT800 vs GMT900 Silverado: Which Generation to Buy
GMT800 (1999–2006) vs GMT900 (2007–2013) — these are the two most popular used Chevy truck generations on the market right now, and the debate comes up constantly. The right answer depends entirely on what you’re using the truck for. Here’s the real breakdown.
If you’re still deciding between generations, start with the platform-level deep-dives: the GMT800 buyer’s guide and the GMT900 complete guide. Bookmark both — this article is the head-to-head comparison.
GMT800 (1999–2006): The Case For
The GMT800 is the better choice if you want simplicity, maximum long-term durability, or the lowest maintenance cost. The 5.3L LM7 iron-block V8 in GMT800 trucks is one of the most durable truck engines GM ever built. No cylinder deactivation means no AFM lifter failure — the #1 expensive problem on GMT900 trucks. A well-maintained GMT800 5.3L regularly hits 250,000–300,000 miles without internal engine work.
The GMT800 also benefits from the 4.8L LR4 option — the most underrated Chevy truck engine. It’s slightly less powerful than the 5.3L but equally durable and almost always available at lower prices because buyers gravitate toward the 5.3L.
Parts are cheap, mechanics know these trucks inside and out, and the 4L60E transmission (while not bulletproof under heavy towing) is simple to rebuild. GMT800 trucks are currently in the sweet spot of age vs. value — old enough to be inexpensive, new enough to have OBD-II diagnostics and modern safety features.
Full details: GMT800 platform reference.
GMT900 (2007–2013): The Case For
The GMT900 is a meaningfully better truck in almost every measurable category except engine simplicity. Better interior quality, more refined ride, stronger body structure, improved aerodynamics, more standard safety features, and more power. The GMT900 5.3L L96/LC9 makes 315 hp vs the GMT800’s 285 hp. The 6.0L LY6 (available in HD and fleet GMT900s) is a bulletproof engine with no AFM.
The 6-speed 6L80E transmission that came with the 6.2L and some other GMT900 configurations is substantially more durable than the GMT800’s 4L60E — better for towing, longer service life, more gear choices. The GMT900 also has a more modern look that ages better on the road in 2026.
Full details: GMT900 complete guide.
The AFM Problem: GMT900 Asterisk
The GMT900 5.3L has one serious issue that directly affects the GMT800 vs GMT900 decision: AFM (Active Fuel Management) lifter failure. GMT900 5.3L trucks built 2007–2013 are equipped with collapsible AFM lifters that fail — typically between 80,000–140,000 miles. Repair cost: $2,000–4,500. The fix is an AFM delete kit and tune, which runs $800–1,500 and eliminates the problem permanently.
If you buy a GMT900, budget for an AFM delete before you hit 80,000 miles. With the AFM deleted, the GMT900 5.3L is as reliable as the GMT800 5.3L going forward. If you don’t want to deal with it, buy the GMT800 and skip the issue entirely. See our AFM delete guide.
Head-to-Head Comparison
Engine reliability (stock): GMT800 wins — no AFM, simpler, proven longer. GMT900 with AFM deleted is equal.
Drivetrain: GMT900 wins — 6L80E transmission is stronger than 4L60E. GMT800 with 4L80E (HD only) is equally strong.
Interior quality: GMT900 wins — cleaner design, better materials, more comfortable.
Ride quality: GMT900 wins — more refined suspension tuning and body structure.
Purchase price: GMT800 wins — typically $3,000–6,000 cheaper for comparable mileage.
Repair costs: GMT800 wins — cheaper parts, more shops familiar with the platform.
Fuel economy: GMT900 wins slightly — improved aerodynamics and engine tuning.
Towing capability: GMT900 wins — higher ratings, better transmission.
Looks (subjective): GMT900 wins for most buyers — the boxy GMT800 is loved by enthusiasts but the GMT900 is more universally liked.
GMT800 or GMT900: which to buy
Buy GMT800 if: You want maximum simplicity and lowest long-term cost, you’re doing an LS swap or major build anyway, you’re buying a project truck, or budget is tight.
Buy GMT900 if: You want a daily driver with better comfort and more capability, you’re willing to budget $1,000 for an AFM delete, or you want better towing with the 6-speed transmission.
Either generation will serve you well. The GMT900 is the better truck overall — the GMT800 is the simpler truck. For most buyers who plan to maintain the truck properly, the GMT900 with an AFM delete is the better long-term investment.
Ready to commit to one? Read the GMT800 buyer’s guide or the GMT900 complete guide for the platform-specific buying checklist and pricing.
If you sweat the details on your GMT800/GMT900, you’ll like the gear. Built for Silverado, Sierra, Tahoe, Suburban, and Yukon owners who actually do the work.
Shop FullSizeChevy Gear →
Keep going: find every GMT800 guide, known problem and fix in the GMT800 Hub and the GMT900 Hub.
Talk GMT800 with other owners
Open the GMT800 Forum →
