Index of Chevrolet Silverado and GMC Sierra diagnostic trouble code guides on FullSizeChevy, showing all 22 covered P-codes including P0300, P0420 and P0455
Chevy Silverado Trouble Codes
Every diagnostic trouble code guide on FullSizeChevy, grouped by system. Pull the code first with a scanner, then work the guide — most of these have a cheap, common cause that gets skipped because somebody guessed at parts instead.
Unless a guide says otherwise, these codes read the same across the GM full-size range. A P0420 means the same thing on a 1999 Silverado as it does on a 2021. Where a fix is genuinely platform-specific, it is called out in its own section further down.
Misfire codes
P0300 is a random or multiple-cylinder misfire. P0301 through P0308 name the exact cylinder. If you have a cylinder-specific code, start there — it narrows the job enormously.
Code What it means Guide
P0300 Random / multiple cylinder misfire P0300 diagnosis and fix
P0301 Cylinder 1 misfire P0301 diagnosis and fix
P0302 Cylinder 2 misfire P0302 diagnosis and fix
P0303 Cylinder 3 misfire P0303 diagnosis and fix
P0304 Cylinder 4 misfire P0304 diagnosis and fix
P0305 Cylinder 5 misfire P0305 diagnosis and fix
P0306 Cylinder 6 misfire P0306 diagnosis and fix
P0307 Cylinder 7 misfire P0307 diagnosis and fix
P0308 Cylinder 8 misfire P0308 diagnosis and fix
Fuel trim codes
P0172 System too rich, Bank 1 P0172 diagnosis and fix
P0175 System too rich, Bank 2 P0175 diagnosis and fix
Catalytic converter codes
A catalyst code is not automatically a converter. Both guides work through the upstream causes before the expensive part.
P0420 Catalyst efficiency below threshold, Bank 1 P0420 diagnosis and fix
P0430 Catalyst efficiency below threshold, Bank 2 P0430 diagnosis and fix
EVAP and emissions codes
EVAP work starts at the gas cap and moves outward. Do it in order and most of these never cost more than a solenoid.
P0442 Small EVAP leak P0442 diagnosis and fix
P0449 EVAP vent solenoid circuit P0449 diagnosis and fix
P0455 Large EVAP leak P0455 diagnosis and fix
P0496 EVAP high purge flow P0496 diagnosis and fix
Camshaft timing codes
P0011 Intake camshaft position timing — over advanced P0011 diagnosis and fix
P0014 Exhaust camshaft timing — over advanced P0014 diagnosis and fix
Cooling, sensor and idle codes
P0118 Engine coolant temperature sensor, high input P0118 diagnosis and fix
P0128 Coolant temp below thermostat regulating temperature — usually a stuck-open thermostat P0128 diagnosis and fix
P0507 Idle air control — idle speed higher than expected P0507 diagnosis and fix
Platform-specific code guides
These cover the same codes but on one platform, where the fix or the failure point is specific enough to be worth its own guide.
Warning lights and symptoms that are not a code
Not everything that lights the dash sets a P-code you can look up. These are the common ones.
Still stuck?
Post the code, your year and engine, and what the truck is actually doing in the FullSizeChevy forum. Somebody there has chased the same code on the same platform. Freeze-frame data and fuel trim numbers help more than anything else you can post.
