P0496 means the EVAP purge solenoid is flowing fuel vapor to the intake manifold when it shouldn’t be — or the flow rate is higher than expected during a commanded purge event. Unlike P0442 (a leak), P0496 is a performance fault in the EVAP control circuit. On Silverado and Sierra trucks it almost always points to the purge solenoid or its circuit.
What the Purge Solenoid Does
The EVAP purge solenoid is an electrically-controlled valve between the charcoal canister and the intake manifold. When the ECM commands a purge event (typically at cruise speed with the engine fully warm), it opens the solenoid and allows stored fuel vapors in the canister to be drawn into the intake and burned. When not purging, the solenoid should be closed. P0496 fires when the solenoid is stuck open (or leaking) during a period when it should be closed.
Symptoms
- Rough idle (a stuck-open purge solenoid causes an unmetered vacuum leak at the intake)
- Hard start after refueling (too much vapor dumped at once)
- Rich running condition at idle (fuel vapor adding to the air/fuel mixture)
- Check engine light — P0496 only (occasionally accompanied by P0171 lean code from the extra fuel vapor leaning the system out during certain conditions)
Diagnosis
- Locate the purge solenoid — on GMT900/K2XX trucks it’s mounted on or near the intake manifold, with a vacuum line to the intake manifold and a vapor line running to the charcoal canister.
- With the engine off and key out, disconnect the vacuum port from the purge solenoid. Apply vacuum to the solenoid port with a hand vacuum pump. A functioning (closed) solenoid should hold vacuum. If vacuum bleeds off, the solenoid is stuck open or has a failed internal valve — replace it.
- Check the electrical connector — corrosion at the connector can cause erratic solenoid behavior. Clean with electrical contact cleaner and apply dielectric grease.
- If the solenoid tests good mechanically, check the EVAP line from canister to solenoid for cracks or disconnection (a cracked line causes excess vapor flow).
Fix
Purge solenoid replacement is the most common fix — AC Delco 214-2146 or equivalent. Cost: $25–$60. DIY time: 15–30 minutes. The solenoid is accessible from the top of the engine on most GMT900/K2XX trucks — remove the air intake tube for better access. Clear codes after replacement and verify the P0496 doesn’t return after 2–3 complete drive cycles.
Related Guides
Also seeing P0442? If you have both codes, address P0496 (purge solenoid) first — a stuck-open solenoid can cause false P0442 readings by allowing vapor to flow when the system expects a sealed circuit during leak testing. Fix the solenoid, clear both codes, and run 2–3 drive cycles before chasing the P0442 separately. See our P0442 EVAP Leak Guide for the full leak diagnosis flow.
