OBS Chevy Door Hinge Repair Done Right
A sagging OBS truck door will tell on itself fast. You hear the click when it drops, you feel it fight the striker, and before long you’re lifting the door with your knee just to shut it clean. It is one of those jobs every GMT400 owner should understand – not because it is glamorous, but because letting it slide beats up the latch, the striker, the hinges and eventually the door shell itself.
On these trucks, the problem usually starts small. The bushings wear out, the hinge pins loosen up, and the door begins to sag just enough that you ignore it for a while. Then the rear edge starts kissing the striker wrong, the body lines drift, and the whole thing goes from annoying to expensive. The good news is that most hinge issues are fixable in the garage if you catch them early and support the door properly.
Which trucks this covers
The GMT400 door hinge design runs the full 1988-1998 truck line and carries into the SUVs built on the same platform – the 2-door Blazer, the 2-door Tahoe, the 4-door Tahoe and Yukon, and the Suburban. If it is an OBS-era GM full-size, the hinge story is the same one.
Heavier doors make it worse, not different. Extended-cab and crew-cab front doors, and any door carrying power windows, power locks and a full trim panel, put more load through the same pins and bushings than a base regular-cab door does. The driver’s door almost always goes first regardless of configuration, because it gets cycled the most.
What usually fails on an OBS Chevy door
Most of these jobs come down to hinge pins and bushings. The factory bushings wear, especially on the driver door because it gets the most use. Once that slop shows up, the heavy truck door starts moving in ways it shouldn’t. Every time you open and close it, the hinge holes, striker, and latch take more abuse.
That doesn’t mean every sagging door needs a full hinge replacement. Sometimes fresh pins and bushings bring it right back. Sometimes the hinge itself is worn out, cracked, or egg-shaped where the pin rides, and then you’re beyond a basic repair. That’s where guys get tripped up – they throw bushings at a hinge that’s already too far gone and wonder why the door still drops.
You’ll also want to look at the striker and latch before blaming everything on the hinge. A worn striker can make the door feel loose even after the hinge is repaired. If the door has been sagging for a long time, the latch may already be worn from catching the striker low and hard.
Signs your hinges need attention now
If you can lift the open door and feel movement at the hinge, that’s the classic sign. Another giveaway is paint wear around the striker or latch area. Some trucks will show a door that sits low at the rear when closed, with a body line that no longer matches the cab or fender.
Listen to it, too. A healthy OBS door has a solid truck-door close. A worn hinge setup sounds cheap and clunky, and that’s not how a GMT400 should feel. If you need to slam it, lift it, or shoulder it shut, don’t keep forcing it. You’re just spreading the damage.
Before you start the repair
This job is straightforward, but the door is heavier than it looks. Support matters. A floor jack with a block of wood works, and a second set of hands makes the whole thing easier. If you try to muscle it solo without supporting the weight, you can tweak the hinge alignment or chip paint where you didn’t plan to.
Pulling the front fender is not always required, but access can depend on which hinge you’re working on and how clean you want the job to be. Some guys can swap pins and bushings with the fender on. Others would rather create more room than fight tight access and risk scratching up old paint. If your truck still wears nice original panels, take the cautious route.
Have your replacement pins and bushings in hand before you tear into it. Cheap hardware can work, but this is one of those places where bargain parts can turn a solid fix into a short-term patch. The door gets used every day. Use parts that can handle it.
Working through the repair, step by step
Start by checking alignment before taking anything apart. Look at the gap at the cab, fender, and rocker. If the door already sits low, note how bad it is. That gives you a reference point when you put it back together.
Support the door from underneath so the jack is carrying the weight, not the hinges. Remove the spring if needed, then drive the old hinge pins out carefully. Once the pins are out, you can pull the old bushings and inspect the hinge bores. This is the moment that tells you whether you’re doing a real repair or chasing a bigger issue.
If the old bushings are destroyed but the hinge itself still looks round and solid, you’re in good shape. Press in the new bushings, install the new pins, and keep the door supported as everything goes back together. Don’t rush this step. If the door shifts while you’re installing the pin, you can nick a bushing or fight alignment more than necessary.
Once it’s reassembled, test the door slowly. Don’t just slam it shut and hope for the best. Bring it into the latch gently, check how it meets the striker, and watch the body lines. A repaired hinge should let the door close cleanly without needing extra lift or force.
When pins and bushings are not enough
This is where experience matters. If the hinge holes are worn out, the hinge is cracked, or the mounting area has been stressed from years of abuse, new bushings will only hide the problem for a minute. Some trucks need a full hinge replacement. Others need striker adjustment after the hinge work because the old worn setup had the latch meeting the striker in the wrong place for years.
If your truck has been hit, or the door was allowed to sag for a very long time, you may also be dealing with alignment beyond the hinge itself. A bent door shell, worn latch, or shifted fender can muddy the diagnosis. That’s why the smart move is to inspect the whole closing system, not just the hinge pin kit.
There’s also a difference between a work truck fix and a clean restoration-level fix. If it’s your shop truck and you just want it shutting right, fresh pins, bushings, and a striker check may be enough. If it’s a clean sport truck, Tahoe, or C1500 you actually care about showing off, spend the extra time getting the gaps right. It changes how the whole truck feels.
The mistakes that make the job harder
The biggest one is not supporting the door correctly. That turns a routine repair into a wrestling match. The second is assuming every sagging door just needs bushings. A worn hinge will eat up new parts fast.
Another mistake is skipping the striker inspection. If the latch has been misaligned for years, you can repair the hinge and still have a door that closes rough. That doesn’t mean the repair failed. It means the rest of the system needs attention too.
And don’t ignore the little details. Watch the harness, weatherstrip, and paint edges while moving the door around. OBS parts are getting older, and replacing broken trim or cracking original paint is a bad trade for rushing a hinge job.
The upgrade path, and why people take it
Replacing worn pins and bushings with the same factory-style parts puts the door back where it belongs, but it also puts you back on the same wear curve. On a truck you drive every day, that is a job you will do again.
That is why a lot of OBS owners go to an upgraded hinge pin and bushing setup instead – Cunningham Machine is the name that comes up most often in GMT400 circles for exactly this. It is the same repair, done once, with hardware built to outlast the original design. If the truck is a keeper, it is worth the difference.
Check the door bottoms while you are in there
Door sag and door rust show up on the same trucks, and you are already in position to look. The bottom of the door is on every OBS rust checklist, along with rockers, cab corners, bed wheel arches and the windshield pinch seam. A door with a rotted lower edge is a heavier door and a weaker mounting structure, which is part of why the hinges gave up.
If you are still working out whether this truck is worth the sheet metal, the OBS buyer’s guide walks the full rust and body inspection. Every OBS guide, known problem and fix lives in the OBS / GMT400 hub.
Is this a DIY job or a shop job?
For a lot of truck guys, this is a fair garage repair. If you’re comfortable supporting a door, driving pins, checking alignment, and making small adjustments, you can absolutely handle it. It’s not a mystery job. It just takes patience.
But if the truck has nice paint, if the hinge looks severely worn, or if the door alignment is already way off, paying a good body or restoration shop can make sense. Especially on cleaner OBS builds, the labor cost may be worth avoiding chipped paint and panel gap headaches. It depends on the truck and your standards.
That is the real point of the job. It is not just about stopping a sag. It’s about protecting the fit, feel, and character of a truck that deserves better than being slammed shut for another five years. Built by truck guys, for truck guys means fixing the small stuff before it turns into the big stuff – and a door that closes right is one of those details you appreciate every single time you drive it.
Open the OBS / GMT400 Forum →
