A single-cylinder misfire on a GM 5.3L V8 usually comes down to the ignition side: the spark plug, the coil, the boot/wire, or the connector feeding that coil. The mistake most people make is throwing a full set of plugs and coils at it. This is how to work the problem in order on a 2014 GMC Sierra 1500 (5.3L L83 EcoTec3) and confirm the failed part before spending money. This was a real diagnosis with a flashing check engine light, a stored P0301 (Cylinder 1) code, and no spark on that cylinder. The result was a bad ignition coil — found by testing, not guessing. Watch the full diagnosis, then read the step-by-step below.
Which trucks this applies to
The exact truck here is a 2014 Sierra 1500 with the 5.3L L83, but the process is the same across:
2014–2018 Chevrolet Silverado and GMC Sierra 1500 with the 5.3L L83 or 6.2L L86 (K2XX)
Most GM 4.8L, 5.3L, 6.0L and 6.2L truck V8s use the same coil-near-plug layout and the same basic plug, wire, coil and wiring checks
Symptoms owners notice
Rough idle and a stumble under light throttle
A flashing check engine light — an active, damaging misfire, not a steady light
A single stored cylinder-specific misfire code, often with a dead or weak cylinder you can feel
Step 1 — Scan the ECM and find the cylinder
Pull the code first. On a GM V8, misfire codes are cylinder-specific: P0300 is a random/multiple misfire, while P0301–P0308 each point at one cylinder. This truck returned P0301 = Cylinder 1. For the wider rundown on that code — coil, plug, injector, compression and the AFM angle — see the P0301 cylinder 1 misfire guide.
Cylinder 1 is the front-most cylinder on the driver side (Bank 1). Knowing the layout keeps you from testing the wrong coil.
GM V8 cylinder numbering. P0301 = Cylinder 1, front driver side (Bank 1).
What you need
Nothing exotic: a scan tool, an inline spark tester, a 5/8″ spark plug socket, an extension and a ratchet, plus a known-good coil to swap in for testing.
Step 2 — Inspect the spark plug
Pull the plug on the dead cylinder and read it. A fouled, oil- or fuel-soaked, or worn plug can cause the miss on its own. Clean it up, check the gap, and reinstall — or replace it if it’s done.
Step 3 — Check for spark
Put an inline spark tester between the coil/boot and the plug and crank it. You want a strong, consistent blue spark. Weak, intermittent, or no spark means the problem is upstream of the plug — the boot/wire or the coil.
Step 4 — Test the wire, then swap the coil
Check the boot/wire for cracks, carbon tracking and resistance. If it’s good and spark is still weak or absent, swap the coil with a known-good one from another cylinder and re-scan. If the misfire follows the coil to the new cylinder, you’ve found it. That’s exactly what happened here — the coil was the failed part.
Step 5 — Don’t skip the connector and wiring
Before you call the coil bad, rule out the connection. A backed-out pin, a corroded terminal, or a broken wire under the insulation will mimic a dead coil.
Each coil connector has 12V power, a ground, and a signal (trigger) wire from the ECM. Confirm power and ground are present and that the signal is reaching the connector before condemning the coil. Pinout varies — verify yours for your specific truck.
A note on AFM — take a flashing misfire seriously
These L83/L86 engines run AFM (Active Fuel Management), which deactivates cylinders 1, 4, 6 and 7 under light load. A misfire is not automatically an AFM/DOD lifter failure — this whole job was an ignition-side fix. But if your check engine light is flashing, stop driving it. Continued driving on an active misfire risks cam and engine damage.
The order that works
Plug → spark → wire → coil → connector → wiring. Confirm the failed component before replacing it. Diagnose first, buy parts second.
FAQ
What does P0301 mean on a 5.3? A misfire detected specifically on Cylinder 1. P0302–P0308 indicate the other cylinders; P0300 is a random/multiple-cylinder misfire.
Can I keep driving with a misfire? Not with a flashing light. A steady light is less urgent, but a flashing misfire dumps raw fuel into the exhaust and can damage the catalytic converter and, on AFM engines, the cam and lifters.
Is a 5.3 misfire always the AFM lifters? No. Plenty of single-cylinder misfires are a plug, coil, boot or connector. Rule out the cheap ignition parts before assuming a lifter/cam failure.
Should I just replace all 8 coils? You can, but it’s not diagnosis. Swap-testing a known-good coil onto the dead cylinder confirms the fault for the price of a re-scan.
Discuss it / ask questions
The full write-up with photos lives on the FullSizeChevy forum, and that’s the place to post your own truck’s code, symptoms, mileage and what fixed it:
