FE9 is not an option you paid for. It is a certification — GM’s record that the truck was built to federal emissions requirements rather than California’s. Owners find it on the label, assume it is equipment, and go looking for a part that does not exist.
What it actually tells you is which emissions hardware and which service parts your truck takes, and that is worth knowing before you order a catalytic converter.
Where FE9 is documented
| Year | How GM described it | Source |
| 1993 | “Certification, emission, federal” | GM option master |
| 2007 | “Federal emissions certification” | 2007 Chevrolet Silverado Classic Truck Restoration Kit |
| 2020 | “Federal emissions. Use for ordering vehicles that will be registered in all states except California” | GM Upfitter police package specification guide |
| 2021, 2022, 2024 | “Emissions, federal requirements” | GM Upfitter specification guides |
| 2025–2026 | “Emissions — federal requirements” | GM Fleet order guides; 2026 police specification guides |
Thirty-seven GM-sourced records, which makes FE9 one of the best-documented codes in our database. The 2020 wording is the clearest statement GM ever put in print about what the code is for.
The emissions code family
FE9 never travels alone. Your label will carry one certification code and often an override code alongside it.
| Code | What it means |
| FE9 | Federal certification — registration anywhere except California |
| YF5 | California certification |
| NC7 | Federal emissions override |
| NB8 | California emissions override |
| NE1 | Geographically restricted registration |
Look them all up together in the code database — the combination is what describes the truck, not any one of them.
Why it matters when you buy parts
- Catalytic converters. A federal-certified truck and a California-certified truck of the same year can take different converters, and a federal part fitted to a CARB vehicle will fail an inspection even if it bolts on.
- EVAP components. Canister, vent solenoid and purge valve part numbers can split on certification.
- Registration. States that have adopted California standards may refuse a federal-certified vehicle under a certain mileage. That is a state-by-state question and it changes — check with your own DMV rather than with an internet table.
If you are chasing EVAP codes rather than shopping for parts, start with the GMT800 EVAP diagnosis order — the certification code tells you which part to buy, not which part failed.
What FE9 does not mean
- It is not a delete, a bypass, or a performance option. It adds nothing and removes nothing you can feel.
- It is not proof the truck is currently compliant. It records how the truck was certified when built.
- It does not describe the engine. The engine has its own RPO.
How to read yours
- Find the RPO label — glove box lid, console lid, or under the spare.
- Decode FE9 for your model year, and run the whole label so you catch the override code too.
- Cross-check against the emissions label under the hood. That sticker states the standard the truck was certified to, and it is the one an inspector reads.
- 2007 Chevrolet Silverado Classic Truck Restoration Kit, GM Heritage Archive
- 2020–2024 GM Upfitter police and special-service package specification guides
- 2025–2026 GM Fleet order guides and police package specification guides
- GM VPPS option master, November 2002
