Most GMT800 V8s take 6 quarts of 5W-30 with a filter change — but the 8.1L big block and some high-mileage engines are their own story. Here’s the quick reference for oil type and capacity across the 4.8, 5.3, 6.0 and 8.1 Vortec, plus when a heavier oil is worth considering.
Which trucks this covers
- 1999–2006 Silverado & Sierra, Tahoe, Suburban, Yukon, Avalanche, Escalade
Oil capacity by engine (with filter)
- 4.8L (LR4): ~6 quarts
- 5.3L (LM7/L59): ~6 quarts
- 6.0L (LQ4/LQ9): ~6 quarts
- 8.1L (Vortec 8100 / L18): ~6.5 quarts
Always confirm against your owner’s manual or the oil-fill cap, and set the final level by the dipstick — capacities vary slightly by year and configuration.
Factory oil weight
The factory fill for the LS Vortec V8s (4.8/5.3/6.0) is 5W-30. Stick with that for normal use and to keep the dash oil-pressure reading where the sender expects it. The 8.1L also ran a conventional multigrade from the factory — verify your engine’s exact grade in the manual.
When a heavier oil makes sense
On a high-mileage or noisy engine, some owners step up to a heavier grade to quiet startup rattle or firm up hot oil pressure — for example, moving an older 8.1L from 5W-30 to a 15W-40 has helped cold-start valvetrain chatter for some owners. Do this as a deliberate choice on a worn engine, not as a blanket rule, and in hot climates or towing duty rather than sub-zero starts.
Filter and interval
- Use a quality filter — ACDelco is the safe default on these engines.
- Change interval depends on use and oil type; shorten it if you tow, idle a lot, or run conventional oil.
Common mistakes to avoid
- Overfilling. Set the level at the dipstick, not by pouring in a fixed number.
- Running a random heavy oil on a healthy engine “just in case” — factory weight is right for a good engine.
- Cheap filters on an engine you want to keep past 200k.
Verify
After a change, run the engine, shut it off, wait a minute, and confirm the level at the dipstick. Watch for leaks at the filter and drain plug.
FAQ
Can I run synthetic? Yes — a quality 5W-30 synthetic is fine and often preferred for longer intervals and cold starts.
My 8.1 chatters on cold start — oil? A heavier grade has helped some owners; see the dedicated 8.1L startup-chatter write-up before changing anything else.
Discuss it on the forum
What weight are you running and at what mileage? Compare notes in the FullSizeChevy GMT800 forum. Related: hot-idle oil pressure and the GMT800 engine guide. See the GMT800 hub for the full platform overview — every model, engine and repair guide in one place.
Talk GMT800 with other owners
Open the GMT800 Forum →GMT800 Gear
Shop all GMT800 gear →Find every repair, buying, maintenance, and troubleshooting guide in the GMT800 Owner’s Hub.
