This reference covers factory-documented 2001–2006 light-duty GMT800 L18 pickup and SUV systems. Medium-duty information is shown only for comparison. Express/Savana, Workhorse, marine, and industrial systems require separate documentation.
⚠ Technical and safety notice: This guide is a research-based reference for factory 2001–2006 light-duty GMT800 L18 applications. GM wiring varies by model year, platform, transmission, RPO, calibration, and connector orientation. Confirm the donor VIN, PCM/TAC/pedal/throttle family, circuit numbers, and terminal-face orientation using the applicable factory documentation. Perform continuity testing before applying power. Incorrect wiring can cause a no-start, Reduced Engine Power, component damage, or unsafe operation. FullSizeChevy.com is not responsible for damage or injury resulting from incorrect wiring or use of unverified components.
If you are searching for “the” 8.1 Vortec DBW pinout, start here: there isn’t one. The GM 8.1L Vortec (RPO L18) used more than one drive-by-wire architecture, and the differences are big enough to cause a no-start or a truck stuck in reduced engine power if you wire the wrong year. Before you move a single terminal, you have to know which family your donor is.
Quick answer box
- There is no universal L18 DBW pinout. Identify the donor family first.
- 2001–2002 light-duty L18 is the pre-MCE system: P01 blue/red PCM, split throttle motor + 6-way TP connector.
- 2003–2006 light-duty L18 is the MCE system: P59 blue/green PCM, integrated 8-way throttle body (PN 15326836).
- Cam/crank cavities are year-specific. On 2001–2002, the outer cam/crank cavities are reversed relative to the compared Gen III LS truck layouts. On 2003–2006 MCE, they match.
- The donor year, platform, PCM family, TAC system, pedal, throttle hardware, transmission, and calibration must all be identified before terminals are moved or a standalone harness is built.
Building an L18 harness or identifying a donor? Join the FullSizeChevy forum discussion, post your PCM label and connector photos, and compare your setup with other 8.1L owners. The forum thread carries the deepest technical detail and ongoing donor-identification help.
1. The direct answer
Is the L18 nearly the same as an LS? At the architecture level, yes — enough that an experienced LS/GMT800 harness builder will recognize most of it. At the connector and component-family level, no. Wiring it like a generic LS harness is how trucks end up in limp mode.
Is there one universal L18 DBW pinout? No. GM built at least two light-duty DBW families in this window, plus separate medium-duty, van, Workhorse, marine, and industrial systems that do not belong in the same table.
What changed between 2002 and 2003? GM applied a model-year 2003 Mid Cycle Enhancement (MCE) to the light-duty full-size electrical system. The 2001–2002 trucks use the pre-MCE P01 architecture with split throttle hardware. The 2003–2006 trucks use the MCE P59 architecture with an integrated throttle body.
Which systems does this article cover? Factory-documented 2001–2006 light-duty GMT800 pickups and SUVs only. Medium-duty is shown for comparison so you can see why commercial hardware does not casually mix with pickup/SUV hardware. New to the 8.1? See our 8.1L vs 6.0L comparison. Vans, Workhorse, marine, and industrial are out of scope.
2. What “nearly the same as LS” actually means
The reason the “8.1 is basically an LS” idea keeps circulating is that a lot of the architecture genuinely overlaps. What is similar:
- P01/P59-era GM powertrain PCM architecture
- Class 2 (J1850 VPW) serial diagnostics
- Coil-near-plug ignition strategy
- Sequential fuel injection
- Hall-effect cam and crank sensing
- Familiar underhood relay and fuse strategies
That overlap is real, and it is why your LS standalone harness workflow transfers. But “similar architecture” is not “interchangeable connector.” What is not safely interchangeable:
- Connector cavity placement (the cam/crank outer-cavity difference below is the classic trap)
- TAC and pedal families (pre-MCE and MCE circuit assignments differ)
- Throttle hardware (split vs. integrated)
- Calibration (the OS has to match the engine, transmission, emissions and security strategy)
- Platform integration and exact PCM circuit use
One more important boundary: when this article compares the L18 to “LS,” the comparison is against specific Gen III LM7/LQ4/LQ9-family truck service data (the comparator connector views used in the research), not every LS engine ever made. Do not stretch it into a universal “all LS” rule.
3. The real 2003 change (Mid Cycle Enhancement)
GM’s own light-duty electrical documentation identifies a major model-year 2003 electrical change called the Mid Cycle Enhancement. That is the clean dividing line for light-duty trucks.
Two things matter here:
- This is a model-year change, not a calendar breakpoint. No factory evidence was found for a vague “late-2003” light-duty split. If someone tells you there is a mid-year 2003 DBW change on pickups, ask for the VIN breakpoint — none was documented.
- Do not mix this with medium-duty or Workhorse timelines. Commercial chassis followed their own documentation. A 2003 medium-duty L18 is not the same electrical system as a 2003 light-duty L18.
| Feature | 2001–2002 pre-MCE light-duty | 2003–2006 MCE light-duty |
| PCM family | P01 blue/red | P59 blue/green |
| Throttle hardware | Split motor + 6-way TP connectors | Integrated 8-way throttle body |
| Pedal family | 15318071 | 15318071 with MCE circuit changes |
| TAC family | Pre-MCE light-duty | MCE light-duty |
| Cam/crank outer cavities | Reversed from compared LS truck layouts | Match compared LS truck layouts |
| Exact PCM service number | Verify donor | Verify donor |
Factory source: GM Upfitter Integration, 2003 & Beyond Light Duty C/K Full-Size Truck Electrical (rev. 04/2006), MCE overview and L18 pages. 2003 & Beyond Light Duty C/K Full-Size Truck Electrical (GM PDF) · GM light-duty archive.
4. Identify the donor before you cut the harness
The single biggest cause of avoidable no-start and reduced-power headaches on an L18 swap is cutting the donor loom before documenting it. A donor tag and a clear connector photo are stronger evidence than a model-year guess. Work this checklist first:
- VIN and complete donor vehicle identification
- Model year and door-jamb production date
- Platform: pickup/SUV light-duty, van, medium-duty, Workhorse, marine, or industrial
- Engine RPO (L18)
- Transmission RPO and controller arrangement (4L80E vs. Allison)
- Federal/California emissions label and certification family
- PCM service number and hardware number
- PCM connector colours (blue/red vs. blue/green)
- PCM operating-system number and calibration IDs (read with a scan/tuning tool)
- TAC module service number and connector part numbers
- Pedal assembly part number
- Throttle-body or split motor/TP part numbers
- Cam and crank connector photos showing latch/key and cavity marks
- Underhood fuse-block label and every engine fuse/relay rating
- All engine harness part-number tags
- Ground eyelets, ground locations, splice packs, and splice identifiers
- The complete pedal-to-TAC firewall sub-harness, retained intact
Stop condition: do not cut the donor harness until the PCM/TAC/pedal/throttle family and the cam/crank connector orientation are identified. Before depinning, map continuity from each retained component cavity to its PCM/TAC/inline destination. Building one now? Post your donor evidence in the FullSizeChevy forum and we’ll help you ID it.
Connector orientation matters. A schematic cavity label is not automatically a physical terminal-face view. Confirm the latch, key, cavity marks, circuit number, and continuity on the actual donor connector before moving terminals.
5. 2001–2002 pre-MCE light-duty pinouts
These tables are the 2001–2002 Chevrolet/GMC light-duty L18 system. Orientation is stated per table; every table is drawn from a terminal-face or factory schematic source. Confirm the latch/key position on your actual donor connector before moving terminals.
Evidence note (2001–2002 tables): the pre-MCE connector-end-view detail below is drawn from professional reproduction of GM service information (CHARM, 2002 Chevrolet K2500 L18), corroborated against the exact L18 schematic set. GM Upfitter does not publish a free 2001–2002 light-duty connector-end-view package, so treat this family as separately verified Grade B and confirm on your donor connector. Factory context: GM light-duty archive.
5.1 Split throttle — TAC motor connector (PN 12077900)
View: terminal face; verify latch on donor.
| Cavity | Circuit | Colour | Function | Destination | Status |
| A | 582 | BRN | TAC motor 2 | TAC C1-8 | Required |
| B | 581 | YEL | TAC motor 1 | TAC C1-16 | Required |
5.2 Split throttle — 6-way TP connector (PN 12162261)
View: terminal face; keyed 6-way.
| A | 416 | GRY | TP1 5 V reference | TAC C1-2 | Required |
| B | 452 | BLK | TP1 low reference | TAC C1-3 | Required |
| C | 485 | DK GRN | TP1 signal | TAC C1-1 | Required |
| D | 1688 | LT BLU/BLK | TP2 5 V reference | TAC C1-9 | Required |
| E | 1704 | BLK/WHT | TP2 low reference | TAC C1-10 | Required |
| F | 486 | PPL | TP2 signal | TAC C1-11 | Required |
2001–2002 split-throttle connectors — Grade B professional reproduction of GM service information (CHARM). Confirm on your donor.
5.3 Pedal connector (PN 15318071), pre-MCE
View: terminal face; cavities A–K.
| Cavity | Circuit | Colour | Function | TAC destination | Status |
| A | 1273 | GRY | APP/PPS 3 low reference | TAC C2-A | Required |
| B | 1272 | PPL | APP/PPS 2 low reference | TAC C2-B | Required |
| C | 1162 | LT BLU | APP/PPS 2 signal | TAC C2-C | Required |
| D | 1274 | TAN | APP/PPS 2 5 V reference | TAC C2-D | Required |
| E | 971 | BRN | APP/PPS 1 low reference | TAC C2-E | Required |
| F | 1161 | DK BLU | APP/PPS 1 signal | TAC C2-F | Required |
| G | 1164 | WHT/BLK | APP/PPS 1 5 V reference | TAC C2-G | Required |
| H | — | — | Factory unused | — | Do not populate |
| J | 975 | YEL/BLK | APP/PPS 3 5 V reference | TAC C2-J | Required |
| K | 1163 | DK GRN | APP/PPS 3 signal | TAC C2-K | Required |
Pre-MCE pedal — Grade B professional reproduction. Cavities E and J change function at the MCE (see §6 below).
5.4 TAC connector C1 (PN 12191065), pre-MCE
Terminal face; two factory images cover pins 1–16.
| Pin | Circuit | Colour | Function | Destination | Status |
| 1 | 485 | DK GRN | TP1 signal | TP C / split TP | Required |
| 2 | 416 | GRY | TP1 5 V reference | TP A / split TP | Required |
| 3 | 452 | BLK | TP1 low reference | TP B / split TP | Required |
| 4 | 84 | DK BLU | Cruise set/coast | Steering switch/PTO | Optional unless cruise/PTO retained |
| 5 | 87 | GRY/BLK | Cruise resume/accel | Steering switch | Optional unless cruise retained |
| 6 | 1320 | LT BLU | Brake/stop input | Stoplamp/CHMSL circuit | Retain for normal DBW logic |
| 7 | 1339 | PNK | IGN 1 feed | 15 A ETC fuse | Required |
| 8 | 582 | BRN | Motor 2 | Throttle motor | Required |
| 9 | 1688 | LT BLU/BLK | TP2 5 V reference | TP D / split TP | Required |
| 10 | 1704 | BLK/WHT | TP2 low reference | TP E / split TP | Required |
| 11 | 486 | PPL | TP2 signal | TP F / split TP | Required |
| 12 | 1061 | ORN/BLK | TAC serial data A (UART/ETCA label varies) | PCM | Required |
| 13 | 774 | DK BLU/WHT | TAC serial data B (UART/ETCB label varies) | PCM | Required |
| 14 | 397 | GRY | Cruise on/off | Steering switch/PTO | Optional unless cruise/PTO retained |
| 15 | 451 | BLK/WHT | TAC ground | Ground distribution | Required (family-specific circuit) |
| 16 | 581 | YEL | Motor 1 | Throttle motor | Required |
5.5 TAC connector C2 (PN 12177081), pre-MCE
Terminal face; cavities A–K (mirrors the pedal table). C2-A through C2-K land on pedal A through K; circuit E is 971 (BRN), circuit J is 975 (YEL/BLK).
5.6 Cam sensor (CMP PN 12129946) and crank sensor (CKP PN 15324165), pre-MCE
View: terminal face.
| Sensor | Cavity | Circuit | Colour | Function | PCM destination | Status |
| CMP | A | 631 | RED | 12 V sensor supply | PCM C2-39 | Required |
| CMP | B | 632 | PNK/BLK | Low reference | PCM C1-61 | Required |
| CMP | C | 633 | BRN/WHT | CMP signal | PCM C1-73 | Required |
| CKP | A | 1867 | LT GRN | 12 V sensor supply | PCM C1-2 | Required |
| CKP | B | 1868 | YEL/BLK | Low reference | PCM C1-21 | Required |
| CKP | C | 1869 | DK BLU/WHT | CKP signal | PCM C1-12 | Required |
Pre-MCE cam/crank — Grade B professional reproduction. On the pre-MCE connector, cavity A is supply and C is signal.
5.7 Core P01 factory-used PCM circuits (2001–2002)
This is a factory-used, build-relevant L18 circuit map compiled from exact L18 schematic sheets. It is not a complete 160-cavity terminal-face drawing — the official PCM end-view document was not recovered, so unlisted cavities must not be assumed unused.
| PCM cavity/group | Circuit | Colour | Function | Standalone status |
| C1-1, C1-40, C2-1, C2-40 | 451 | BLK/WHT | PCM grounds | Must not remove |
| C1-20, C1-57 | 440 | ORN | Constant battery feed (ECM B 20 A) | Required |
| C1-19 | 439 | PNK | Ignition 1 feed (ECM I 10 A) | Required |
| C1-75 | 1020 | PNK | Off/run/crank ignition state | Required for OE strategy |
| C1-14 | 1061 | ORN/BLK | TAC serial data A | Required (DBW) |
| C1-15 | 774 | DK BLU/WHT | TAC serial data B | Required (DBW) |
| C1-2 / C1-21 / C1-12 | 1867/1868/1869 | — | CKP supply / low ref / signal | Required |
| C2-39 / C1-61 / C1-73 | 631/632/633 | — | CMP supply / low ref / signal | Required |
| C2-32 | 432 | LT GRN | MAP signal | Required |
| C2-48 | 597 | GRY | 5 V reference | Required |
| C2-54 | 469 | ORN/BLK | Low reference | Required |
| C1-74 | 410 | YEL | ECT signal | Required |
| C1-25 | 472 | TAN | IAT signal | Required |
| C2-31 | 492 | YEL | MAF signal | Required for stock calibration |
| C2-20 / C2-21 | 822 / 821 | PPL/WHT / PPL | VSS low / high | Drivability/trans dependent |
| C1-58 | 1049 | DK GRN | Class 2 serial data | Required for diagnostics |
| C2-46 | 419 | BRN/WHT | MIL control | Recommended |
| C1-51 / C1-11 | 496 / 1876 | DK BLU / LT BLU | Knock sensors 1 / 2 | Required |
| Injector driver group | see exact sheets | — | Eight injector controls | Required (use exact sheet) |
| Ignition control group | see exact sheets | — | Eight coil triggers | Required (use exact sheet) |
| Fuel-pump relay control | see exact sheet | — | Fuel-pump relay command | Required |
Do not assign a terminal from a generic P01 chart — use the exact L18 schematic sheet for the donor. This is a factory-used circuit list, not a complete terminal-face map.
6. 2003–2006 MCE light-duty pinouts
This is the 2003–2006 light-duty GMT800 L18 system with the integrated throttle body. Do not label this “early light-duty,” and do not carry over the older report’s cam/crank cavity assignments — they were corrected here. Every table is terminal-face or factory schematic; confirm latch/key on the donor.
6.1 Integrated throttle body (PN 15326836)
View: terminal face; verify latch/key on GM view. GM Upfitter page D-118, schematic K33021a_010_01.
| A | 581 | YEL | Motor 1 | J1-16 | Required |
| B | 1704 | BLK/WHT | TP2 low reference | J1-10 | Required |
| C | 582 | BRN | Motor 2 | J1-8 | Required |
| D | 452 | BLK | TP1 low reference | J1-3 | Required |
| E | 1688 | LT BLU/BLK | TP2 5 V reference | J1-9 | Required |
| F | 486 | PPL | TP2 signal | J1-11 | Required |
| G | 485 | DK GRN | TP1 signal | J1-1 | Required |
| H | 416 | GRY | TP1 5 V reference | J1-2 | Required |
Factory source: GM Upfitter Integration, 2003 & Beyond Light Duty C/K Full-Size Truck Electrical (rev. 04/2006), 2003–2006 light-duty C/K L18, printed page D-118, PDF page 214, ETC schematic K33021a_010_01. 2003 & Beyond Light Duty C/K Full-Size Truck Electrical (GM PDF) · GM light-duty archive. Proves the integrated throttle-body assembly 15326836 (cavities A–H) and its J1 ETC destinations. Does not prove a complete PCM terminal-face map or light-duty/medium-duty system interchange.
6.2 Pedal connector (PN 15318071), MCE
View: terminal face; cavities A–K. Note E and J functions differ from pre-MCE.
| A | 1273 | GRY | PPS 3 return | TAC J2-A | Required |
| B | 1272 | PPL | PPS 2 return | TAC J2-B | Required |
| C | 1162 | LT BLU | PPS 2 signal | TAC J2-C | Required |
| D | 1274 | TAN | PPS 2 5 V reference | TAC J2-D | Required |
| E | 1271 | BRN | PPS 1 return | TAC J2-E | Required |
| F | 1161 | DK BLU | PPS 1 signal | TAC J2-F | Required |
| G | 1164 | WHT/BLK | PPS 1 5 V reference | TAC J2-G | Required |
| J | 1275 | YEL/BLK | PPS 3 5 V reference | TAC J2-J | Required |
| K | 1163 | DK GRN | PPS 3 signal | TAC J2-K | Required |
Watch cavity E: pre-MCE = circuit 971, MCE = circuit 1271.
Factory source: GM Upfitter, 2003 & Beyond Light Duty C/K Full-Size Truck Electrical (rev. 04/2006), printed pages D-120–D-121. 2003 & Beyond Light Duty C/K Full-Size Truck Electrical (GM PDF) · GM light-duty archive. Proves the light-duty pedal-position module 15318071 and its three-track circuit set; circuit assignment must match the MCE family table above.
6.3 TAC connector J1 (PN 12191065), MCE
Terminal face; pins 1–16. Only the ground circuit and connector role differ from pre-MCE C1.
| 1 | 485 | DK GRN | TP1 signal | Throttle G | Required |
| 2 | 416 | GRY | TP1 5 V reference | Throttle H | Required |
| 3 | 452 | BLK | TP1 low reference | Throttle D | Required |
| 4 | 84 | DK BLU | Cruise set/coast | Steering switch/PTO | Optional |
| 5 | 87 | GRY/BLK | Cruise resume/accel | Steering switch | Optional |
| 6 | 1320 | LT BLU | Brake/stop input | Stoplamp/CHMSL | Retain for normal DBW logic |
| 8 | 582 | BRN | Motor 2 | Throttle C | Required |
| 9 | 1688 | LT BLU/BLK | TP2 5 V reference | Throttle E | Required |
| 10 | 1704 | BLK/WHT | TP2 low reference | Throttle B | Required |
| 11 | 486 | PPL | TP2 signal | Throttle F | Required |
| 12 | 1061 | ORN/BLK | TAC serial data A (ETCA/UART label varies) | PCM | Required |
| 13 | 774 | DK BLU/WHT | TAC serial data B (ETCB/UART label varies) | PCM | Required |
| 14 | 397 | GRY | Cruise on/off | Steering switch/PTO | Optional |
| 15 | 550 | BLK | TAC ground | Ground distribution | Required (family-specific — note circuit 550, not 451) |
| 16 | 581 | YEL | Motor 1 | Throttle A | Required |
The identical circuit numbers 1061/774 carry UART labels in 2001/02 data and ETCA/ETCB labels in the MCE schematic. A label change alone does not prove a protocol change.
Factory source: GM Upfitter, 2003 & Beyond Light Duty C/K Full-Size Truck Electrical (rev. 04/2006), printed page D-119. 2003 & Beyond Light Duty C/K Full-Size Truck Electrical (GM PDF) · GM light-duty archive. Proves the light-duty MCE TAC/ETC connector family J1 12191065 and J2 12177081. The UART vs. ETCA/ETCB label on the same circuits 1061/774 is not by itself proof of a protocol change.
6.4 TAC connector J2 (PN 12177081), MCE
Same A–K layout as the MCE pedal table in §6.2 — J2-A through J2-K land on pedal A through K. Circuit E is 1271 (BRN), circuit J is 1275 (YEL/BLK).
6.5 Cam sensor (CMP PN 12059595) and crank sensor (CKP PN 15324165), MCE
| CMP | A | 633 | BRN/WHT | CMP signal | PCM J1-73 | Required |
| CMP | B | 632 | PNK/BLK | Low reference | PCM J1-61 | Required |
| CMP | C | 631 | RED | 12 V sensor supply | PCM J2-39 | Required |
| CKP | A | 1869 | DK BLU/WHT | CKP signal | PCM J1-12 | Required |
| CKP | B | 1868 | YEL/BLK | Low reference | PCM J1-21 | Required |
| CKP | C | 1867 | LT GRN | 12 V sensor supply | PCM J1-2 | Required |
On the MCE connector, cavity A is signal and C is supply — the reverse of pre-MCE. (An earlier draft had these reversed because it read schematic symbols instead of terminal-face views.)
Factory source: GM Upfitter, 2003 & Beyond Light Duty C/K Full-Size Truck Electrical (rev. 04/2006), L18 engine-control pages D-53–D-64 (CMP/CKP on D-63). 2003 & Beyond Light Duty C/K Full-Size Truck Electrical (GM PDF) · GM light-duty archive. Terminal-face cavity orientation corroborated by professional GM service reproduction (CHARM / GM SI 860180, Grade B). Confirm latch/key on the donor.
6.6 Core P59 factory-used PCM circuits (2003–2006)
Official L18 engine-control pages D-53 through D-64 were recovered. This maps verified L18-used circuits; it is not a universal all-calibration list of every unused P59 cavity.
| PCM cavity/group | Function | Standalone status | GM page |
| J1-1, J1-40, J2-1, J2-40 | PCM grounds | Must not remove | D-64 |
| J1-57 + B+ pins | Constant PCM battery feed | Required | D-56/D-64 |
| J1-75 / J1-20 | Ignition feed/state (VIGN1 / VIGN0) | Required | D-56 |
| J1-2 / J1-21 / J1-12 | CKP supply / low ref / signal | Required | D-63 |
| J2-39 / J1-61 / J1-73 | CMP supply / low ref / signal | Required | D-63 |
| J1-74 | ECT signal | Required | D-53 |
| J2-32 | MAP signal | Required | D-53 |
| J1-48 / J1-54 | 5 V reference 1B / VREF return B | Required | D-53 |
| J1-26 | IAT signal | Required | D-55 |
| J1-56 / J1-11 | MAF signal / MAF low reference | Required for stock cal | D-55 |
| J1-60 | Engine oil pressure signal | Gauge/strategy dependent | D-53 |
| J1-58 / J1-59 | Class 2 TX/RX | Required for scan/reflash | D-56/D-58 |
| J1-47 | Fuel-pump relay control | Required | D-58 |
| J1-46 | MIL control | Recommended | D-58 |
| J2-55 to J2-62 region | Eight injector drivers | Required | D-61/D-62 |
| J1 ignition-control region | Eight coil triggers | Required | D-61/D-62 |
| J2-19/J2-20 | Knock sensors | Required | D-63 |
Factory source: 2003 & Beyond Light Duty C/K Full-Size Truck Electrical (GM PDF) · GM light-duty archive. This is a factory-used circuit map, not a complete physical terminal-face connector map; unlisted cavities are not implied to be unused.
7. Cam and crank sensor comparison
This is the section people search for, so here is the direct comparison. The connector cavity assignments differ by L18 year, and they differ from the compared Gen III LS truck sensors too.
| Engine / year | Sensor | Cavity A | Cavity B | Cavity C | Connector PN |
| 2001–02 L18 | CMP | supply (631) | low ref (632) | signal (633) | 12129946 |
| 2001–02 L18 | CKP | supply (1867) | low ref (1868) | signal (1869) | 15324165 |
| 2003–06 MCE L18 | CMP | signal (633) | low ref (632) | supply (631) | 12059595 |
| 2003–06 MCE L18 | CKP | signal (1869) | low ref (1868) | supply (1867) | 15324165 |
| 2002 LM7/LQ4/LQ9 truck (comparator) | CKP | signal | low reference | supply | application view |
| 2004 LM7 / LQ4 truck (comparator) | CMP/CKP | signal | low reference | supply | application view |
Verdict box
Swap the outer cam and crank cavities only when adapting the compared common Gen III LS truck connector layout to a verified 2001–2002 pre-MCE light-duty L18. Do not apply that instruction to 2003–2006 MCE L18 wiring.
A few things to keep straight, because they are not the same thing:
- Connector cavity — the physical hole (A/B/C) in the plug.
- Wire colour — a labelling aid, not proof of function. Do not wire by colour alone.
- Circuit function — supply, low reference, or signal. This is what actually has to line up.
- Terminal-face orientation — which way you are looking at the connector. A schematic symbol is not a terminal-face view.
- PCM destination — the cavity the circuit lands on at the computer.
Wire by function to function: supply to supply, low reference to low reference, signal to signal, confirmed against the correct terminal-face view and the PCM destination. Reversing supply and signal is not harmless — it can cause no-start, loss of sync, and cam/crank DTCs. The factory material here documents the faults, not any protection that makes miswiring safe, so do not power up a miswired sensor to “see what happens.”
Got a donor in front of you? Post your PCM label, connector colours, pedal and throttle part numbers, and cam/crank connector photos in the FullSizeChevy L18 DBW thread and we’ll help you confirm the family before you cut anything.
8. P01 versus P59
The fastest field identifier is the PCM connector colour:
- 2001–2002 light-duty L18 → P01, blue/red connectors.
- 2003–2006 light-duty L18 → P59, blue/green connectors.
That family-level mapping is solid. What is not solid — and where builders get burned buying parts online — is treating a service number as universal:
- 12200411 is a strong common P01 lead for 2001–2002 Gen III trucks, but it is not proven for every L18 VIN. Verify the donor label.
- 12576106 / HW12570558 is commonly documented for 2003 P59 trucks, but it is not proven universal for every MCE L18 VIN either.
Can a P59 from another application run an L18? Possibly — but only as a hardware base, and only after a complete, compatible L18 operating system and calibration are loaded. A blind “segment swap” was not proven sufficient. If you are considering a non-L18 P59, confirm the hardware supports a full L18-compatible OS/calibration before you flash it, and expect to verify exact compatibility rather than assume it. Do not buy a PCM by year alone.
Exact operating-system numbers require a VIN-based ACDelco/SPS lookup. This article deliberately does not publish OS numbers, because the evidence does not close them.
9. What must match
Here is the practical compatibility picture. “Must match exactly” means same part/family; “same verified family” means it can vary within a proven hardware/circuit family; “verify” means possible with confirmation; “not proven” means no evidence supports it.
| Item | Rule | Likely failure mode if mismatched |
| PCM hardware | Must support the complete L18 OS/calibration | No-start, wrong strategy, DBW faults |
| Operating system / calibration | Must match engine, transmission, emissions, security | Reduced power, no-start, poor running |
| TAC module | Same verified family (pre-MCE vs. MCE) | No throttle / reduced power |
| Pedal | Same verified family; mind cavity E/J circuit changes | APP correlation faults, reduced power |
| Pedal-to-TAC sub-harness | Preserve intact | Intermittent APP faults, limp mode |
| Throttle hardware | Match the exact motor/TP electrical layout the TAC expects | No throttle, TP correlation faults |
| Cam sensor wiring | Wire by function for the correct year | No-start, sync fault, CMP DTCs |
| Crank sensor wiring | Wire by function for the correct year | Crank/no-start, CKP DTCs |
| Transmission configuration | Match 4L80E vs. Allison strategy | Shift/idle/torque-management problems |
| Security/VATS strategy | Retain OE environment or handle in calibration | No-start |
Two rules do the heavy lifting: PCM hardware must support the complete L18 OS/calibration, and TAC + pedal + pedal-to-TAC sub-harness stay within one verified family. Same-donor is the safest way to guarantee that, but it is not always technically mandatory if every component is proven within the same family.
The only proven cross-family throttle-body electrical match in this research is integrated PN 15326836 between the 2003–2006 MCE light-duty system and the 2005 medium-duty system. That is an electrical pin-layout match on that specific part — it is not a generic LS throttle-body interchange claim, and two connectors fitting together does not prove physical interchange.
10. Minimum standalone harness circuits
Group the circuits by what they do, so you know what you can leave out and what will bite you if you do. This is a minimum-retained-circuit map for the verified family, not a universal plug-and-play standalone manual — exact needs are application-, transmission-, and emissions-dependent.
Required to start and run
- PCM constant B+ (separate fused feed)
- PCM ignition feed and state (switched, clean voltage)
- PCM grounds (multiple engine/block grounds — do not share sensor low reference)
- Crank sensor: supply, low reference, signal (correct year)
- Cam sensor: supply, low reference, signal (correct year)
- Injectors and injector feed (eight drivers, separate fused feed)
- Coils and ignition feed (eight triggers, separate fused feed)
- Fuel-pump relay control (PCM drives the coil; pump gets its own protected feed)
- TAC power (15 A ETC feed) and clean TAC ground
- TAC serial pair (both dedicated circuits, 1061/774)
- Pedal and throttle circuits (do not mix pre-MCE and MCE assignments)
- DLC (cavities 2, 4, 5, 16 minimum)
Required for proper drivability
- Brake/stop input to the TAC (circuit 1320) — retain factory logic and verify switch polarity
- MAF/IAT, MAP, ECT
- Front O2 sensors and heaters
- VSS (idle, torque, cruise, transmission logic depend on it)
- Range / park-neutral input
Transmission-dependent
- 4L80E controls (shift A/B, TCC, pressure, temp, range, VSS) — use the exact transmission schematic and calibration
- Allison interface — separate TCM serial/torque paths; do not treat as a 4L80E pinout
Emissions-dependent (remove only with calibration + legal review)
- Rear O2, EVAP, AIR
Optional
- A/C request/clutch, tach, gauges, fan outputs, PTO/cruise
Must not be casually removed
- Sensor low references — never tie directly to high-current motor or chassis grounds
- TAC brake and serial circuits (C1/J1-6, -12, -13) — missing or miswired, they trigger reduced power
The DLC feed should stay independent of the engine-run relay so you can scan and reflash key-off.
11. Fuse and relay plan
Only publish factory-supported ratings. The values below come straight from the recovered light-duty (and where noted, medium-duty) documentation. Everything not on this list has to come from your donor’s fuse block.
| Load | Factory fuse | Rating | Source application |
| PCM constant feed | ECM B (UH BEC) | 20 A | LD L18 / Allison feed |
| PCM ignition feed | ECM I | 10 A | 2001–02 LD L18 |
| Ignition state/control | IGN0 | 10 A | 2001–02 LD |
| Ignition state/control | IGN1 | 10 A | 2001–02 LD |
| TAC/ETC module | ETC / ETC_FD | 15 A | 2001–06 LD (MD also 15 A) |
| Cruise switch | CRUISE | 10 A | 2001–02 LD |
| Vehicle stop input | VEH STOP | 10 A | 2001–02 LD |
| Stop lamps | STOP LPS | 20 A | 2001–02 LD |
| Injector bank 1 | INJ1 | 15 A | 2003–06 MCE LD |
| Injector bank 2 | INJ2 | 15 A | 2003–06 MCE LD |
Donor-specific — do not invent a number: coils, O2 heaters, fuel pump, transmission, A/C, and cooling-fan feeds. The fuel pump must run through a PCM-controlled relay — do not power it directly through the ignition switch.
Factory source: Light-duty INJ1 15A / INJ2 15A and the ECM B (UH BEC) 20A PCM battery feed are shown in the 2003+ light-duty engine-control / power-distribution family — GM Upfitter, 2003 & Beyond Light Duty C/K Full-Size Truck Electrical (rev. 04/2006). 2003 & Beyond Light Duty C/K Full-Size Truck Electrical (GM PDF). Pre-MCE branch values (ECM I 10A, IGN0/IGN1 10A, ETC 15A, CRUISE 10A, VEH STOP 10A, STOP LPS 20A) are corroborated from the 2001 L18 schematic reproduction and must be confirmed against the exact donor fuse block. Coil, O2-heater, fuel-pump, transmission, A/C, and fan ratings remain donor-specific.
12. Reduced-engine-power and no-throttle troubleshooting
Reduced engine power is a system response, not a single DTC. Work it in this order: (1) confirm donor family and component pairing; (2) read all DTCs; (3) verify battery and charging voltage; (4) verify PCM and TAC feeds; (5) verify PCM and TAC grounds; (6) verify dedicated low-reference circuits; (7) verify TAC serial circuits 1061/774; (8) verify APP tracks; (9) verify TP tracks; (10) verify throttle-motor circuits; (11) verify brake input; (12) verify cam and crank wiring by function; (13) inspect connector tension and terminal damage; (14) confirm PCM OS/calibration compatibility; (15) confirm transmission, VSS, and range inputs. Exact DTC definitions vary by model year — use the donor-year service information; do not apply later DTC wording universally to 2001–2002 systems.
| Symptom / DTC family | System | Common causes |
| Reduced-engine-power message | All DBW | APP/TP correlation, TAC comm loss, motor control, reference fault, family mismatch |
| No throttle response | TAC/throttle | Wrong TAC/pedal family, motor circuit, calibration mismatch |
| P1120 / P1125 family (APP) | All DBW | Wrong pedal family, open/short, 5 V/low-reference error, cavity swap |
| P1220 / P1221 family (TP/APP correlation) | All DBW | Wrong throttle/TAC family, TP signal or low-reference error |
| P1516 (TAC throttle-position performance) | Documented L18 DBW | TAC motor/TP mismatch, binding throttle, voltage/ground, wrong calibration |
| P2101 / P2119-class | Later MCE/related strategies | Motor circuit, throttle body, TAC module, calibration mismatch |
| TAC communication codes | Separate-TAC systems | Open/short on 1061 or 774, wrong TAC, PCM/TAC family mismatch |
| 5 V reference codes | All | Shorted APP/TP/MAP branch, high-current ground tied to low reference |
| P0335 / P0336 (CKP) | All | Outer cavities wired for wrong year, open/short, reluctor issue |
| P0340 / P0341 (CMP) | All | Outer cavities wired for wrong year, open/short, target issue |
| P0016 / P1345-class (cam/crank correlation) | Cal/year dependent | Miswired sensor, timing/reluctor, CASE-learn condition |
| P0500 / P0502 / P0503 (VSS) | Street/trans | Missing or wrong VSS source, wrong reluctor/calibration |
| Brake-switch rationality | DBW/cruise/trans | Missing circuit 1320, switch polarity, stoplamp feed |
| P0705 / P0850-class (range) | Transmission | Missing range switch or incorrect calibration |
On a fresh L18 swap, the usual culprits behind reduced power or no throttle are not exotic: wrong TAC/pedal family; wrong operating system or calibration; cam/crank cavities wired for the wrong year; missing brake input, VSS, or range input; a shared low-reference/ground mistake; a 5 V reference on the wrong cavity; or a lost splice-pack or ground structure from cutting the harness too early. Read all DTCs before replacing parts.
13. Systems not covered by these pinouts
The tables above are light-duty GMT800 pickup/SUV only. These other 8.1L L18 systems share the engine code but not the wiring, and they need their own documentation:
- Express/Savana — van DBW timeline and pinout not recovered to a build-ready standard; excluded.
- Kodiak/TopKick medium-duty — shown for comparison only. The 2003/04 system uses split throttle hardware, a commercial TAC (25311787), J2 connector 12065425, and pedal 15326842; the 2005 system uses integrated 15326836 with pedal 15326842 shown with tool-line pins. Different from light-duty and from each other.
- Workhorse — separate chassis architecture; do not apply pickup/SUV tables.
- Marine (MEFI-4) — a separate control ecosystem, not P01/P59.
- Industrial/stationary — separate OEM ECM, fuel and emissions system.
A shared engine code or a connector that physically plugs in does not prove wiring compatibility. The medium-duty data is here to show why: same throttle-body part number (15326836 in 2005 MD), completely different TAC/pedal architecture.
Factory source (comparison only): 2003/04 medium-duty — GM Upfitter, 2003 & 2004 Medium Duty C Series Electrical, printed pages D-192–D-193, PDF pages 260–261 (TAC 25311787, J2 12065425, pedal 15326842, split throttle): 2003 & 2004 Medium Duty C Series Electrical (GM PDF). 2005 medium-duty — GM Upfitter, 2005 Medium Duty C Series Electrical, printed pages D-127–D-128, PDF pages 202–203 (integrated 15326836, pedal 15326842 with tool-line pins): 2005 Medium Duty C Series Electrical (GM PDF). The shared throttle assembly 15326836 proves only that one assembly’s electrical layout, not full ETC-system interchange.
14. Frequently asked questions
1. Is the 8.1 Vortec wiring the same as an LS? At the architecture level, yes — same PCM/TAC/DBW era, Class 2 diagnostics, coil-near-plug, sequential injection, Hall-effect cam/crank. Pin-for-pin and component-family, no. Use LS experience as a workflow, not a pin map.
2. What PCM does a 2001 L18 use? P01 blue/red architecture. 12200411 is a strong common lead, but verify the donor label.
3. What PCM does a 2002 L18 use? P01 blue/red architecture. Verify the exact service number and calibration by donor VIN/label.
4. What PCM does a 2003 L18 use? P59 blue/green architecture under the model-year 2003 MCE. 12576106/HW12570558 is commonly documented but not proven universal for every L18 VIN.
5. Was there a late-2003 DBW change? No documented light-duty mid-year breakpoint was found. GM describes the change as model-year 2003 MCE.
6. What PCM does a 2004–2006 L18 use? P59 blue/green family. Exact service numbers and OS/calibrations vary and require donor verification.
7. Are the cam sensor end pins swapped? On 2001–2002 pre-MCE L18 relative to the compared Gen III LS truck layout, yes — cavity A/C functions are reversed. On 2003–2006 MCE L18, no.
8. Are the crank sensor end pins swapped? Same verdict as the cam: yes for 2001–2002 pre-MCE relative to the compared LS truck layout, no for 2003–2006 MCE.
9. Can a P59 from another application run an L18? Potentially, as a hardware base, only after a complete compatible L18 OS/calibration is loaded. It is not a blind plug-in or a proven segment-only swap.
10. Can an LS throttle body be used? Not proven. The only proven cross-family electrical match is integrated PN 15326836 between MCE light-duty and 2005 medium-duty. Generic LS throttle-body interchange is not established. The 2001–02 split throttle is not plug-compatible.
11. Must the PCM, TAC, pedal, and throttle body come from one donor? No — they must come from a verified compatible family with the correct complete calibration. Same donor is simply the safest way to guarantee that.
12. Does the TAC module require programming? No separate TAC programming procedure was found in the recovered factory material. That does not make TAC modules universally interchangeable.
13. Is a CASE relearn required? Only when the factory service procedure calls for it after relevant PCM/CKP replacement or DTC conditions. Do not assume every harness change forces a CASE learn.
14. Can the engine run without a BCM? Only when the security/body dependencies expected by the chosen PCM calibration are properly addressed. A stock unmodified OE calibration may not.
15. What causes reduced-engine-power mode after a swap? Usually wrong TAC/pedal family, wrong OS/calibration, cam/crank wired for the wrong year, a missing brake/VSS/range input, or a shared low-reference/ground mistake. Read all DTCs first.
16. What must be documented before cutting the donor harness? VIN, build date, platform, emissions and RPO labels, PCM service/hardware number/colours/OS, TAC service number, pedal/throttle part numbers, connector-face photos, grounds, splice packs, fuse labels, inline connectors, harness tags, and the pedal-to-TAC sub-harness.
15. Final builder checklist
- Donor identified: 2001–02 pre-MCE or 2003–06 MCE — and confirmed light-duty pickup/SUV
- PCM colours + service number recorded (blue/red P01 vs. blue/green P59)
- TAC and pedal confirmed within one family; pedal-to-TAC sub-harness retained
- Throttle hardware matches the family (split vs. integrated 15326836)
- Cam/crank wired by function for the correct year (A/C reversed only on pre-MCE)
- Sensor low references kept off actuator/chassis grounds
- Brake, VSS, and range inputs retained
- Fuse plan uses only documented ratings; donor-specific loads pulled from the donor block
- DLC feed independent of engine-run relay
- Complete L18-compatible OS/calibration + security strategy sorted with a competent tuner
- All DTCs read before replacing any part
Factory documentation and how to verify this yourself
Every table above is anchored to official GM Upfitter Integration body-builder electrical manuals or to professional reproductions of GM service information. Open the source, find the printed page, and confirm it against your own donor before you cut anything.
Primary factory references:
- GM Body Builder Manuals archive — GM Body Builder Manuals
- Light-duty (prior to 2013) archive that lists the C/K Full-Size Electrical 2003 & Beyond manual — GM light-duty archive
- 2003 & Beyond Light Duty C/K Full-Size Truck Electrical (rev. 04/2006) — the primary 2003–2006 light-duty L18 source — 2003 & Beyond Light Duty C/K Full-Size Truck Electrical (GM PDF). Key printed pages: D-118–D-121 for ETC (D-118 = PDF page 214, schematic K33021a_010_01) and D-53–D-64 for L18 engine controls.
- 2003 & 2004 Medium Duty C Series Electrical (comparison only) — 2003 & 2004 Medium Duty C Series Electrical (GM PDF). Printed pages D-192–D-193, PDF pages 260–261.
- 2005 Medium Duty C Series Electrical (comparison only) — 2005 Medium Duty C Series Electrical (GM PDF). Printed pages D-127–D-128, PDF pages 202–203.
Evidence grades: Grade A = official GM (Upfitter / Body Builder / Service Information / ACDelco). Grade B = licensed reproduction of GM service information (CHARM, Mitchell, ALLDATA) used for the 2001–2002 connector-end views. Build-ready tables here rest on Grade A/B only. Forums, marketplace listings, and social posts are not used as proof.
Still open (not treated as closed): exact donor PCM service number / OS / calibration by VIN, complete physical P01/P59 terminal-face maps, and Express/Savana, Workhorse, marine, and industrial applications. See the forum thread for the running list of unresolved items and member-verified corrections.
16. Sources and evidence grades
Build-ready tables here rest on Grade A/B sources only. Grade A = official GM; Grade B = licensed reproduction of GM service information. The 2001–2002 connector-end views are Grade B (professional reproduction) because GM Upfitter does not publish a free 2001–2002 connector-end-view package. This article does not reproduce copyrighted service-manual pages; connector data is redrawn from verified cavity information.
- GM Upfitter — 2003 & Beyond Light Duty C/K Full-Size Truck Electrical (rev. 04/2006). Primary 2003–2006 light-duty L18 source: MCE overview, ETC D-118–D-121 (D-118 = PDF page 214, schematic K33021a_010_01), engine controls D-53–D-64. Grade A.
- GM Upfitter — 2003 & 2004 Medium Duty C Series Electrical. Comparison only: D-192–D-193 (PDF 260–261). Grade A.
- GM Upfitter — 2005 Medium Duty C Series Electrical. Comparison only: D-127–D-128 (PDF 202–203). Grade A.
- GM Upfitter — Body Builder Manuals archive and the Light-Duty (prior to 2013) archive that lists the manual above. Grade A.
- 2001–2002 Chevrolet K2500 L18 connector-end views (CMP 12129946, CKP 15324165, APP 15318071, TAC C1/C2, TP 12162261, motor 12077900) and the 2002/2004 Gen III LS comparator views — professional reproduction of GM service information (CHARM). Grade B.
- P01/P59 hardware-family identification — ACDelco TDS and community hardware mapping used only for corroboration. Grade C–D (corroboration only).
Build one? Post your donor evidence in the FullSizeChevy forum — VIN, PCM label photo, TAC label photo, pedal part number, throttle connector photo, and any confirmed factory diagram corrections. The more verified donor data the community posts, the tighter this reference gets.
Talk GMT800 with other owners
Open the GMT800 Forum →GMT800 Gear
Shop all GMT800 gear →Find every repair, buying, maintenance, and troubleshooting guide in the GMT800 Owner’s Hub.
Keep going: find LS swap kits, wiring, costs and engine picks in the LS Swap Hub.
