GMT400 Torque Specs (1988–1998 Chevy & GMC): Validated Quick Reference
Most GMT400 trucks are 25–35 years old now. Threads are tired, hardware has been reused, and the last guy probably guessed. This is a garage quick-reference of torque values for the 1988–1998 Chevrolet and GMC C/K trucks and SUVs (Silverado, Sierra, Suburban, Tahoe, Yukon), pulled from published GM/small-block Chevy engineering specs.
Read this first. These figures cover the small-block gas engines (4.3L V6, 5.0L, 5.7L) and the wheels. The 7.4L (454) big-block and 6.5L diesel use different specs and are not listed here. For suspension, steering, brake, and axle fasteners, values change by series (1500 / 2500 / 3500) and by 2WD vs 4WD — pull those from the factory service manual for your exact truck. When a fastener uses a torque-angle procedure, follow it exactly.
The one that trips people up: head bolts (pre-Vortec vs Vortec)
This is where bad torque sheets go wrong, because GM changed the method mid-generation.
Engine / yearsCylinder head bolt procedure
1988–1995 TBI 5.0L / 5.7L (and 4.3L)65 ft-lb, in stages (about 30 → 45 → 65 ft-lb), criss-cross pattern, light oil on threads
1996–1998 Vortec 5.7L (L31) / 5.0L Vortec22 ft-lb first pass, then GM torque-turn: short bolts +55°, medium +65°, long +75° (torque-angle — not torque-to-yield; bolts are reusable)
Do not apply the 65 ft-lb figure to Vortec heads, or the 22 ft-lb + angle method to pre-Vortec heads. They are different systems.
Engine — small-block (4.3 / 5.0 / 5.7), standard SBC values
Values are for OEM-grade hardware with light engine oil on the threads unless noted.
FastenerTorque
Main cap bolts — 2-bolt (7/16″)70 ft-lb
Main cap bolts — 4-bolt inner (7/16″)70 ft-lb
Main cap bolts — 4-bolt outer (7/16″)65 ft-lb
Main cap bolts — 4-bolt outer (3/8″)40 ft-lb
Connecting rod bolts — 3/8″45 ft-lb
Connecting rod bolts — 11/32″35 ft-lb
Intake manifold — cast-iron heads (pre-Vortec)30 ft-lb (non-hardening sealer)
Intake manifold — aluminum25 ft-lb
Intake manifold — 1996–98 Vortec (L31) lower intake27 in-lb → 106 in-lb → 11 ft-lb final, in sequence
Exhaust manifold bolts25 ft-lb (anti-seize)
Rocker-arm studs (screw-in)50 ft-lb
Harmonic balancer / damper center bolt60 ft-lb
Flexplate / flywheel bolts60 ft-lb (thread locker)
Torque converter to flexplate35 ft-lb (thread locker)
Oil pump bolt65 ft-lb
Oil pan bolts12 ft-lb
Timing cover bolts6 ft-lb (~75 in-lb)
Water pump bolts — cast iron / aluminum30 / 25 ft-lb
Bellhousing (trans to block)25 ft-lb
Spark plugs (iron heads, gasket type)~20 ft-lb
Note: 1996+ Vortec engines use net-lash (non-adjustable) rockers with a torqued bolt rather than a screw-in stud — follow the Vortec rocker procedure, not the 50 ft-lb stud figure.
Wheels
ApplicationLug nut torque
1500 / 2500 light-duty, single rear wheel120 ft-lb
Dual-rear-wheel (DRW) 3500140 ft-lb
Torque in a star pattern, in stages, on clean dry studs unless your wheel maker specifies otherwise.
Two specs people quote wrong
These get repeated as single torque numbers, but they aren’t — and getting them wrong damages parts.
  • Rear pinion nut (GM 8.5″ 10-bolt / 9.5″ / 10.5″): there is no fixed pinion-nut torque. The nut crushes a collapsible spacer and is set to a rotating bearing preload (roughly 14–30 in-lb of turning torque with new bearings on the 8.5″). It takes a lot of force on the nut to get there, but the target is the preload reading — not a “220 ft-lb” number. Replace the crush sleeve whenever it’s apart.
  • Front hub / spindle nut: depends on the truck. 4WD sealed hubs land around 165–180 ft-lb (verify for your year). 2WD trucks with serviceable tapered bearings use an adjust-and-back-off procedure, not a single high torque value. Use the FSM procedure for your setup.
Before you trust these numbers
Torque specs vary with bolt grade, thread condition, and lubricant, and GM revised some values across the 1988–1998 run. Use these as a garage quick-reference, verify anything critical against the factory service manual for your exact year, engine, and drivetrain, and chase clean threads before final torque.
Got a spec to add or a correction from your FSM? Post it in the FullSizeChevy forum — year, engine, and where the number came from.
