Squarebody Trim Level Guide for Buyers
If you have ever looked at two squarebodies parked side by side and wondered why one feels bare-bones while the other looks half a step from a luxury truck, this squarebody trim level guide is for you. Badge names like Custom Deluxe, Scottsdale, Cheyenne, Silverado, Sierra, and High Sierra get thrown around all the time, but the real story is a little messier. Years changed, options overlapped, and plenty of trucks on the road today have had parts swapped for decades.
That is exactly why trim level confusion is so common. On squarebodies, trim tells you a lot about how the truck was positioned when it was new, but it does not always tell you exactly what equipment is still on the truck today. For builders, buyers, and anyone trying to keep the culture alive, knowing the difference matters.
Squarebody trim level guide basics
When enthusiasts say “squarebody,” they are usually talking about GM’s full-size C/K trucks, Blazers, Jimmys, and Suburbans from the 1973 to 1987 model years, with crew cabs, Suburbans, and some related models stretching a bit farther in production. Chevy and GMC shared the same basic platform, but their trim naming was not identical. That is where a lot of confusion starts.
Chevrolet trims generally moved up from Custom Deluxe to Scottsdale to Cheyenne to Silverado. GMC, on the other hand, used names like Sierra, Sierra Grande, and High Sierra, depending on year and model. The exact ladder was not perfectly frozen across the whole production run. Some names came and went, some equipment packages shifted, and some regional or fleet-ordered trucks landed in odd combinations.
So the first rule is simple: trim level is a clue, not gospel. If you are buying a truck, restoring one, or trying to identify an original build, always look at the truck itself, not just the fender emblem.
Chevrolet squarebody trim levels
Custom Deluxe
Custom Deluxe was the work-truck side of the Chevy lineup. Think simpler interior materials, fewer bright trim pieces, and a more basic equipment set. These trucks were built to haul, tow, and get beat on without the owner worrying about plush door panels or extra chrome.
That said, “basic” in squarebody terms still leaves room for surprises. A Custom Deluxe could still be ordered with useful options like better engines, automatic transmission, power steering, or air conditioning. That is why two trucks wearing the same trim badge can feel very different from behind the wheel.
Scottsdale
Scottsdale sat in the middle and probably hits the sweet spot for a lot of enthusiasts today. It gave buyers a step up in trim and comfort without leaning too hard into the premium look. More brightwork, upgraded interior touches, and a slightly better-appointed cabin were common themes.
For many builders, Scottsdale trucks offer a strong middle ground. They have enough factory style to feel complete, but they do not carry the same expectation of preserving every upscale detail the way a top-trim truck sometimes does.
Cheyenne
Cheyenne moved the truck farther into comfort and style territory. Depending on year, it could mean better seat materials, more trim, nicer door panels, and a more finished look overall. On some years and body styles, Cheyenne occupied that upper-middle ground just below Silverado.
This is one of those trims where year matters a lot. A Cheyenne from one part of the squarebody era may not line up perfectly with another. If somebody says, “It’s a Cheyenne, so it should have this,” the right answer is usually, “Maybe – what year?”
Silverado
Silverado was the top dog in the Chevy truck trim lineup for much of the squarebody era. This was the premium package, with upgraded interior appointments, extra bright trim, and the kind of details that made a pickup feel more refined than strictly necessary for ranch duty.
A true Silverado usually carried the strongest factory visual identity. More chrome, fuller trim packages, and more comfort-oriented options were part of the appeal. Today, Silverado-badged squarebodies tend to get attention because they represent the higher-end side of the platform, especially if the truck still wears most of its original trim and interior pieces.
GMC squarebody trim levels
Sierra
Sierra was often the starting point in the GMC world, though exact hierarchy changed over time. Like Chevy’s lower trims, Sierra trucks could range from straightforward workhorses to surprisingly well-optioned rigs depending on how they were ordered.
That is the thing with GMC. Buyers often assume every GMC was automatically a little more upscale, but the reality depends on year and spec. Some were dressed up. Some were built to work and nothing more.
Sierra Grande
Sierra Grande usually represented a step up from base Sierra trim. It often added more exterior brightwork and a more finished interior appearance. If you are looking at a squarebody GMC and it has some extra visual punch without going fully premium, Sierra Grande is often the name you will see.
For enthusiasts, this trim lands in a nice middle zone. It has enough factory character to stand out, but it does not always bring the same replacement-part headaches or originality pressure as the highest trims.
High Sierra
High Sierra was GMC’s upscale trim and the closest match to a Chevy Silverado in spirit. Better trim, nicer materials, and more polished presentation were the point. These trucks were still built to work, but they wore their extra comfort and style with more confidence.
A real High Sierra in intact condition can be a strong find. The challenge is that after forty-plus years, trim swaps, repaint jobs, and interior changes can blur the lines fast. A badge alone does not make it authentic.
What trim level actually changed on a squarebody?
The biggest differences were usually visual and comfort-related, not structural. You were not buying a completely different truck underneath. You were buying a different level of finish.
That could include seat upholstery, carpet versus rubber flooring, door panel design, woodgrain-style interior accents, exterior moldings, chrome bumpers, wheel trim, and gauge presentation. In some cases, higher trims also made it more likely the truck was ordered with convenience options like power windows, power locks, tilt column, cruise, or factory air, but those were still options, not guaranteed trim-level equipment across every year.
This is where buyers get tripped up. They see a Silverado emblem and assume every premium feature was standard. Not always. GM’s ordering system let dealers and buyers mix trim and options in ways that create a lot of gray area today.
How to identify a squarebody trim level the right way
If you are serious about figuring out what a truck started life as, begin with the obvious stuff, then verify deeper. Emblems and glovebox or door-jamb information can help, but decades of paintwork and parts swapping mean you need to read the whole truck.
Look at the interior first. Door panels, seat pattern, dash trim, carpeting, and gauge cluster style often tell a more honest story than exterior badges. Then check the body trim holes and mounting points. A truck that now wears lower trim may show signs it once had wider moldings or higher-end brightwork.
Paperwork helps too. Build sheets, original sales documents, old registrations, and factory option labels can clear up a lot. If the truck has been restored, ask what was replaced and why. Some restorations aim for factory-correct detail. Others build a better-looking truck from mixed parts, and there is nothing wrong with that as long as it is represented honestly.
Which trim level is best?
That depends on what kind of truck guy you are. If you want a clean base for a custom build, lower trims like Custom Deluxe or Sierra can be perfect because you are not paying extra for rare trim pieces you plan to remove anyway. If you want a period-correct cruiser with real factory flavor, Scottsdale, Cheyenne, Sierra Grande, Silverado, and High Sierra all bring more visual payoff.
If resale matters, upper trims usually get more attention, especially when the truck keeps its original identity. But there is a trade-off. Premium trim pieces, interior panels, and model-specific details can be tougher and more expensive to source. A basic truck may be easier to finish and easier to enjoy without stressing over every missing molding clip.
That is why the best move is to buy for condition and honesty first, trim second. A solid, complete Scottsdale will beat a rough “Silverado” with swapped badges and missing parts almost every time.
Why this still matters in the squarebody world
Trim levels are more than badge trivia. They tell you how GM marketed these trucks, how owners used them, and why certain survivors feel different even when they share the same body lines. For restorers, trim level shapes the parts hunt. For buyers, it affects value and expectations. For the community, it keeps the details straight so the next generation of truck guys knows what they are looking at.
That is part of what makes squarebodies so good. A farm-spec truck with rubber floors has its own kind of attitude. A loaded Silverado or High Sierra brings a different kind of cool. Neither one is wrong. They just tell different stories.
When you are staring at a squarebody and trying to decode what it really is, slow down and read the whole truck. The badge matters, but the details matter more – and that is where the real fun starts.
Talk Squarebody with other owners
Post your truck, your build, or the problem you are chasing. Real Squarebody owners in the FSC forum will tell you what actually worked on theirs.
Open the Squarebody Forum →
Squarebody Chevy Heritage Badge Poster | 1973–1987 C10 Truck Garage Wall Art | Full Size Chevy Squarebody Decor Price range: $34.18 through $112.27
Squarebody Truck Phone Case — Tough Cases Vintage Pickup Design$24.86
Heritage Badge Squarebody | FSC Car Air Freshener$12.05
Squarebody Chevy Truck T-Shirt – Classic & Clean Neon (1973-1987 C10) | Squarebody Squad Price range: $28.86 through $35.61
Squarebody Chevy Truck T-Shirt – Built to Work (1973-1987 C10) | Fullsize Monster Truck Series Price range: $28.86 through $35.61
Keep It Full Size Squarebody Chevy Truck Poster | Classic Chevy Pickup Garage Wall Art | Full Size Truck Enthusiast Decor Price range: $34.18 through $112.27
Squarebody Chevy Truck Trucker Cap – Keep It Full Size, Embroidered (1973-1987 C10) | Keep It Full Size$31.52
Squarebody Chevy Truck T-Shirt – Rounded Rectangle Badge (1973-1987 C10) | Heritage Badge Price range: $28.86 through $35.61
Squarebody Chevy Truck T-Shirt – Rounded Cream Shield (1973-1987 C10) | Heritage Badge Price range: $28.86 through $35.61
Squarebody Chevy Truck T-Shirt – Old Iron, New Style (1973-1987 C10) | Squarebody Squad Price range: $28.86 through $35.61
Squarebody Chevy Truck T-Shirt – Monster Truck Badge, Mono (1973-1987 C10) | Fullsize Monster Truck Series Price range: $28.86 through $35.61
Squarebody Chevy Truck T-Shirt – Red Bowtie Shield (1973-1987 C10) | Heritage Badge Price range: $28.86 through $35.61
Find every repair, buying, maintenance, and troubleshooting guide in the Squarebody Owner’s Hub.
