An ABS light on a 1999–2006 GMT800 is most often a wheel speed sensor fault — and on the front axle, that sensor is built into the hub bearing assembly. Pull the codes, find the bad corner, and you’ll know whether you’re replacing a sensor, a hub, or chasing wiring. Guessing gets expensive fast.
Which trucks this covers
- 1999–2006 Silverado & Sierra, Tahoe, Suburban, Yukon, Avalanche
- Four-wheel ABS systems on this platform
Symptoms
- ABS warning light on (and sometimes the brake light)
- ABS may cut out or not function; base brakes still work normally
- On some trucks, false ABS activation at low speed just before stopping
Most likely causes, ranked
- Front wheel speed sensor — integrated into the hub bearing. A bad sensor usually means replacing the hub/bearing assembly. Very common.
- Corroded sensor connector or damaged wiring at a wheel — cheap fix if that’s it.
- Rear wheel speed sensor or reluctor issue.
- Tone/reluctor ring damage (rust buildup or physical damage) throwing off the signal.
- ABS module / EBCM faults — least common, diagnose last.
Diagnosis in the right order
- Scan for ABS/chassis codes — a proper scan tool (not just a basic engine reader) will show a wheel-speed-sensor code that points to the specific corner.
- Inspect that corner’s connector and wiring for corrosion or damage before condemning the sensor.
- Compare wheel-speed data live if your tool supports it — the faulty corner reads erratically or drops to zero while rolling.
- Check the tone ring for rust or damage while you’re in there.
Tools
- Scan tool that reads ABS/chassis codes and, ideally, live wheel-speed data
- Hand tools for the hub/sensor; a hub job needs typical suspension tools
Parts guidance
Front hub bearings with the integrated sensor vary in quality — a reputable or OEM-grade hub lasts far longer than the cheapest unit, and this isn’t a job you want to redo. Replace the corner the codes point to; don’t shotgun all four.
Common mistakes to avoid
- Replacing parts without pulling the ABS code. The code names the corner.
- Buying the cheapest hub bearing — the sensor is inside it.
- Ignoring a corroded connector that would’ve been a cheap fix.
Verify the repair
Clear the codes and drive above the ABS activation speed; the light should stay off and wheel-speed data should read cleanly at all four corners.
FAQ
Is it safe to drive with the ABS light on? Your normal brakes still work, but ABS may be disabled — fix it, especially before winter.
Can I replace just the sensor up front? On these trucks the front sensor is part of the hub bearing, so it usually means a hub.
Discuss it on the forum
ABS light on your GMT800? Post the exact chassis code and corner in the FullSizeChevy GMT800 forum. Related: GMT800 common problems. See the GMT800 hub for the full platform overview — every model, engine and repair guide in one place.
Talk GMT800 with other owners
Open the GMT800 Forum →GMT800 Gear
Shop all GMT800 gear →Find every repair, buying, maintenance, and troubleshooting guide in the GMT800 Owner’s Hub.
