How I Restored the Oxidized Headlights on My 2007 Avalanche
Oxidized 2007 Chevy Avalanche headlight before and after wet sanding and protective coating
An oxidized headlight lens can be structurally sound and still look finished. The damage is on the outside surface, which means it can often be sanded back and re-protected instead of replaced.
I wet-sanded the OEM lenses on my 2007 Chevy Avalanche through five abrasive stages and finished them with Meguiar’s Keep Clear Headlight Coating G17804. This article records what I actually did, corrects a grit I misspoke on camera, and adds the application, cure and hazard guidance from Meguiar’s technical bulletin and current safety data sheet.
The truck is a 2007 Chevy Avalanche, but nothing here is Avalanche-specific — the same method applies across the GMT900 generation, and to most oxidized polycarbonate lenses.
Before and after on the same lens, same vehicle, same job. Neither half is colour-graded.
What this restoration does — and does not prove
The lenses were heavily oxidized — cloudy on the outside, with the reflector bowls showing through the haze. This is an on-vehicle exterior correction using staged wet sanding and an aerosol coating.
I did notice better light output once the lenses cleaned up, and that is worth saying plainly. But it is an owner’s impression, not a measurement — I ran no controlled light-output or beam-pattern test, so this article does not put a number on it. It also does not establish a coating lifespan, because there is no exposure history yet.
Exterior sanding will not repair:
  • cracks in the lens
  • broken mounting tabs
  • failed housing seals
  • condensation or haze inside the assembly
  • a burned or damaged reflector
  • electrical, bulb or aiming faults
Confirm which side of the lens the defect is on before you buy any sandpaper. Internal haze is a sealing problem, not a surface problem, and no amount of exterior work will reach it.
Parts, materials and PPE
Item Purpose Source Notes
400-grit wet/dry paper Heavy correction Used in the video Used because these lenses had heavy oxidation. Not a universal starting grit.
1000-grit wet/dry paper Second correction stage Used; corrected at 2:44 This is the actual second grit, not 800.
2000-grit wet/dry paper Refine 1000-grit marks Used in the video I mention skipping it on camera, but the job I filmed includes it.
2500-grit wet/dry paper Further refinement Used in the video Keep masking and nearby paint under constant inspection at this stage.
3000-grit handheld abrasive pad Final sanding stage Used in the video Left over from a Cerakote kit. I ran three passes with it.
Spray bottle Keep the work wet Used in the video I used Pine-Sol and water as the sanding lubricant. Plain water also works.
Masking tape and rags Protect paint and bumper Used in the video Stop immediately if wet tape lifts. I used rags along the lower edge where wet tape would not hold.
Glass cleaner Remove residue before coating Used in the video I cleaned the lenses and housings three times before coating. The lens must be clean, cool, dry and residue-free.
Meguiar’s Keep Clear Headlight Coating G17804 Protective coating Product page, TDS and SDS Two medium wet coats with 50% overlap.
Protective gloves Skin protection Current G17804 SDS Select gloves suitable for the exposure.
Eye protection Eye protection Current G17804 SDS Section 8 identifies indirect-vented goggles.
Outdoor / well-ventilated area Vapor control Current G17804 SDS Respiratory protection is required when ventilation is inadequate.
Disclosure: Some product links may be affiliate links. As an Amazon Associate, FullSizeChevy earns from qualifying purchases at no additional cost to the reader.
Correct headlight wet-sanding sequence of 400, 1000, 2000, 2500 and 3000 grit
The sequence was 400 → 1000 → 2000 → 2500 → 3000. The second stage was 1000 grit, not 800.
Before sanding: inspect the housing and choose a starting grit
Confirm the defect is on the outside of the lens. Interior condensation, internal haze, damaged reflectors and structural failures require diagnosis or replacement — exterior sanding cannot reach them.
The 400-grit paper used here was an aggressive choice for heavy oxidation. Do not convert that project-specific decision into a universal instruction. Start only as coarse as the actual defect requires. Coarse abrasives remove material quickly and leave scratches that every later stage then has to remove — starting too coarse creates work, not results.
Mask substantially beyond the lens. Protect the bumper and any adjoining painted or trimmed surface. Water weakens tape adhesion, so inspect the masking continuously. If tape lifts, stop before the abrasive reaches exposed paint.
Masking tape protecting the paint around the headlight during wet sanding
Mask well past the lens edge. Stop sanding as soon as wet masking lifts and exposes adjacent paint.
The exact wet-sanding sequence I used
This is the sequence exactly as I ran it on the truck.
400 grit: heavy correction
Fold the paper into quarters and use the flat of your palm across the broad sections, keeping the surface wet. Plan on a minimum of three passes at this stage. If the lens is badly gone, it will take more. The objective is to remove the heavy exterior oxidation and establish an even surface before any finer grit touches it.
Use controlled pressure and avoid rolling an abrasive edge into paint or trim. Clean the abrasive repeatedly — trapped debris cuts scratches deeper than the grit you are working with, and those scratches have to come out later.
1000 grit: the spoken correction
I say “800” at 2:12 and again at 2:34 before correcting myself at 2:44. The abrasive I actually used for the second stage was 1000 grit.
Repeat the wet process with even support. Corners need more controlled finger pressure than the broad flat section. The purpose of this stage is to replace the coarse 400-grit pattern with a finer, uniform one.
2000 and 2500 grit: refine the scratches
The job I filmed uses both stages. I mention on camera that 2000 might be skipped, but I did not test that shortcut, so I am not presenting it as verified.
At each stage, rinse or wipe away the slurry, inspect the surface, and confirm the previous grit’s deeper scratches are gone before moving finer. Moving on early means every remaining scratch is still there under the coating.
3000 grit: the lens may still look dull
I used a small handheld 3000-grit pad, three passes.
A uniformly dull or frosted surface at this stage is expected and is not the finished appearance. The coating supplies the final gloss. Two cautions when judging this stage: a wet lens always looks better than it is, and a colour-graded photo always looks better than the lens. Assess it dry, in daylight.
Clean, dry and re-mask before coating
After the last sanding stage I removed the tape, washed the lens, and cleaned the headlights and housings three times with glass cleaner.
Meguiar’s technical bulletin requires a clean, cool, dry headlight in the shade. Mask around the headlight, avoid breezy application conditions, and remove overspray immediately. Dry the lens completely before coating.
Apply Meguiar’s G17804 coating
In the video I used two passes and a medium coat with 50% overlap. The instructions state a 3–5 minute dry time and a 24-hour cure. Meguiar’s technical bulletin gives the full sequence:
  1. Shake the product well.
  2. Apply one medium wet coat over the entire lens.
  3. Overlap the previous pass by 50%.
  4. Allow the first coat to dry for 3–5 minutes.
  5. Apply the second coat to seal the lens.
  6. Allow 3–5 minutes to dry to the touch.
  7. Allow 24 hours for full cure.
Do not invent a repair procedure for a run, sag or dry-spray defect. Stop adding uncontrolled coats and consult the current label or Meguiar’s support.
Safety requirements for applying Meguiar's G17804 aerosol headlight coating
Masked and ready to coat. G17804 application requires ventilation, gloves, eye protection and strict control of ignition sources.
Aerosol safety the video should have stated
The current G17804 SDS assigns the signal word Danger and identifies the product as an extremely flammable aerosol. It also warns that the pressurized container may burst if heated.
  • Keep away from heat, hot surfaces, sparks, open flames, smoking and all other ignition sources.
  • Do not spray on an open flame or other ignition source.
  • Do not breathe vapor or spray.
  • Use only outdoors or in a well-ventilated area.
  • Wear protective gloves and eye protection.
  • Use suitable respiratory protection when ventilation is inadequate.
  • Protect the can from sunlight and excessive heat.
  • Read the complete current label and SDS before use.
There is a real trade-off worth naming. I pulled the truck partly under cover to get out of the wind before spraying. Sheltering from wind also reduces ventilation, and the SDS is unambiguous about which of those matters more. Get out of the breeze, but do not spray this product in an enclosed space.
These are manufacturer safety requirements. They are not a claim that PPE or ventilation were discussed anywhere in the video — they were not.
Troubleshooting
Symptom Likely issue Response
Deep scratches remain after finer stages Coarse scratches were never fully removed, or debris contaminated the abrasive Stop, clean the surface, return only to the grit needed to remove the defect, then repeat every subsequent stage in order.
Mixed clear and frosted patches before coating Sanding pattern is uneven or residue remains Keep inspecting and cleaning until the surface is uniform. Do not coat over an uneven pattern.
Tape lifts while sanding Water weakened the adhesion Stop immediately, dry the edge, re-mask before continuing.
Lens looks dull and frosted after 3000 grit Expected at this stage Not a fault. Continue to cleaning and coating.
Coating appears dry or gritty Spray too light, too distant, or wind-affected Stop adding uncontrolled coats. Follow the current label or contact the manufacturer.
Coating runs or sags Coat too heavy or applied too close Do not apply a guessed fix. Consult the label or manufacturer support.
Haze is inside the housing Exterior sanding cannot reach the defect Diagnose the seal and moisture source; repair or replace the assembly.
Lens cracked, tabs broken, reflector damaged Structural or internal failure Replace or correctly repair the assembly. Restoration is cosmetic exterior correction only.
Mistakes and limitations from this job
Stated plainly, because the useful part of a real job is where it went sideways:
  • I named the second grit wrong on camera — 800 instead of 1000 — twice before correcting it.
  • Wet masking tape lifted and needed attention near the paint. I used rags where the tape would not hold.
  • My spoken recoat wait is inconsistent on camera. Meguiar’s 3–5 minute interval is the one to follow.
  • I gave no PPE or ventilation guidance on camera for a flammable aerosol. That is a fair criticism of the video.
  • I ran no controlled light-output, beam-pattern, nighttime-visibility, cost or durability comparison.
Result and follow-up
2007 Chevy Avalanche with the restored and coated headlights back together
The finished truck. Ungraded, shot the same day the work was done.
My conclusion is modest and I am keeping it that way: it is “definitely better than what it was”, and I was happy with it. It is a beater truck and this was a cheap fix, not a restoration to as-new condition.
I am hoping for two to three years out of the coating. That is a hope, not a spec — Meguiar’s publishes no lifespan figure and I have no exposure history yet. I will add a dated update here with comparable ungraded photos once there is something real to report.
Related FullSizeChevy resources
Frequently asked questions
Why does the lens still look cloudy after 3000 grit?
That is expected. The sanding stages leave a uniform dull or frosted surface, and the coating supplies the final gloss. Uneven patches or remaining deep scratches are a different problem and must be corrected before coating.
How long should G17804 dry between coats?
Meguiar’s technical bulletin specifies 3–5 minutes between the first and second coats.
How long does G17804 take to cure?
The bulletin states 3–5 minutes to dry to the touch and 24 hours for full cure.
Should every oxidized headlight start at 400 grit?
No. I used 400 because these lenses had heavy oxidation. Choose a starting grit based on the actual defect and avoid removing more material than you have to.
Can exterior sanding repair internal condensation or cracks?
No. Those are internal, sealing or structural defects, and exterior work cannot reach them.
Does restoring the lens improve how well the headlight lights the road?
I noticed better output once the lenses were clear, and that is worth saying. But I ran no controlled light-output or beam-pattern test, so treat it as an owner’s impression rather than a measured gain. If your lenses are hazy on the inside, or the aiming is off, restoration will not fix either.
Authoritative sources
Talk GMT900 with other owners
Post your truck, your build, or the problem you are chasing. Real GMT900 owners in the FSC forum will tell you what actually worked on theirs.
Open the GMT900 Forum →
Find every repair, buying, maintenance, and troubleshooting guide in the GMT900 Owner’s Hub.
