Classic Chevy Truck Restoration Mistakes: 12 Pitfalls to Avoid
Most stalled truck builds don’t die from one big failure. They die from a handful of avoidable mistakes made early — a truck bought on emotion, a job done out of order, a budget with no contingency. Here are the 12 that cost people the most time and money on Squarebody, OBS/GMT400, and GMT800 restorations, and how to dodge each one. For the full build sequence, start with the classic Chevy & GMC truck restoration guide.
1. Buying on emotion instead of frame and cab condition
The truck you start with sets your whole budget. A clean, complete work truck beats a “rare” trim with a rotted cab every time. Inspect the frame rails, cab mounts, and cab corners before you fall in love. Rust repair is the most expensive, most skilled work on the list — buy away from it, not into it.
2. Underestimating the rust
Bubbled paint hides scale. Map every rust spot before you cost the project out, then add to the estimate — it always finds more. On Squarebody and OBS it’s cab corners, rockers, floors, lower doors, and bed sides; on GMT800 add the rear wheel arches. The Squarebody rust repair guide shows what the real repair areas look like.
3. Starting with wheels, a lift, or a stereo
The fun parts will still be there after the truck is solid. Money spent on cosmetics before the structure is fixed is money you’ll disturb — or redo — later.
4. No written plan or budget
Decide what the truck is for — daily, weekend, work, or show — before you spend a dollar. Those are four different parts lists. Write the plan, set a budget, and add a contingency for rust and wiring. A build without a plan turns into endless scope creep.
5. Not deciding the drivetrain before teardown
Stock rebuild or LS swap? Decide before you’re deep into the truck. The engine choice changes mounts, cooling, wiring, fuel system, and the transmission. Deciding to swap halfway through paint means redoing all of it. Weigh it with the LS swap guide up front.
6. Throwing parts at electrical problems
These trucks collect hacked-in stereo wiring and corroded grounds. Chase the ground and check the harness before you buy a module. On OBS trucks especially, most gremlins are grounds and previous-owner “fixes” — the OBS wiring guide is where to start.
7. Ignoring the brakes on a driver
If you actually drive the truck, the brakes matter more than the wheels. Drum-brake Squarebodies benefit hugely from a front disc brake conversion — it’s a safety upgrade, not a show mod. OBS and GMT800 trucks still need hoses, calipers, rotors, and fluid on a project.
8. Reusing an old fuel system after a long sit
Old fuel systems are a fire and reliability risk. On anything that’s been parked, plan on the tank, pump, lines, and filter as a system — not a “we’ll see if it runs” gamble.
9. Skipping the cooling system
While you’re in there, refresh the radiator, hoses, thermostat, and water pump. An overheating engine ruins a fresh build fast, and it’s cheap insurance compared to a warped head.
10. Cheap no-name parts where they matter
Bargain-bin sensors, ignition parts, and suspension components fail early and cost you twice. For critical, fitment-sensitive parts, spend on OEM, GM Genuine, or ACDelco. Save the budget cuts for trim and bolt-on cosmetics.
11. Not labeling and bagging parts during teardown
Six months into a build, nobody remembers which bracket came from where. Bag, label, and photograph as you disassemble. It’s the cheapest time-saver in the whole project.
12. Painting before the body is truly solid and straight
Paint is the reward, not the first step. Do it after the rust is fixed and the body is straight. Paint over filler-hidden problems and you’ll be sanding it off next year. If you’re keeping existing paint, a proper detailing process can bring it back without burning through thin old clear.
The Short Version
Buy solid, plan the build, fix structure and safety before cosmetics, decide the drivetrain early, and diagnose instead of guessing. Do that and you’ll be one of the guys who actually finishes.
Compare Notes With Other Owners
Every one of these mistakes has been made — and fixed — by someone on the FullSizeChevy forum. Post your build, your platform, and where you’re stuck, and get real feedback before you cut, weld, or buy.
