Squarebody C10 Disc Brake Conversion: Best Kits and How to Do It
The factory front drum brakes on a Squarebody C10 were adequate in 1975. They’re not adequate now — especially if you’ve added any power to the drivetrain, increased the weight with a camper or gooseneck, or just want to stop reliably in traffic. A front disc brake conversion is one of the highest-return safety upgrades you can make on any Squarebody. Here’s exactly how to do it.
Why Convert? The Real Case for Disc Brakes
Drum brakes work via expanding shoes pressing outward against a drum. They fade under sustained use (heat causes brake fluid to vaporize), they self-servo in reverse (causing grab), and they require periodic adjustment. Disc brakes use calipers clamping against a rotor — they dissipate heat better, self-adjust, and provide more consistent pedal feel in emergency situations. On a 4,000 lb+ truck, the difference is meaningful. Front disc brakes provide approximately 70–80% of total stopping force — which is why front-only conversion delivers most of the benefit.
What You Need: Component Overview
A front disc brake conversion on a Squarebody requires: disc brake spindles, rotors and calipers, a proportioning valve (to balance front/rear braking force), and an upgraded master cylinder. Some kits also include brake lines and a booster spacer. You do not need to convert the rear drums to get 80% of the braking improvement — front only is the practical choice for most builds.
Best Bolt-In Conversion Kits
1. CPP (Classic Performance Products) — Best Overall
CPP makes the most comprehensive bolt-in disc brake conversion kits for Squarebody trucks. Their kit includes disc brake spindles, rotors, calipers, brake lines, proportioning valve, and a new master cylinder — everything you need in one box. CPP kits use factory-style spindle geometry, so steering and suspension geometry remain correct. Pricing: $600–900 for a complete front kit. CPP also offers front+rear conversion for $900–1,300. The gold standard for Squarebody disc brake conversions for 20+ years.
2. Wilwood Engineering — Best for Performance Builds
Wilwood makes high-performance disc brake kits using their forged aluminum calipers and slotted/drilled rotors. If your Squarebody has significant power or you want maximum performance braking, Wilwood is the choice. More expensive ($800–1,400 for front) but the Wilwood hardware is race-proven and significantly more heat-tolerant than CPP’s street-grade components. Wilwood also makes a 6-piston front big brake kit for builds with 17+ inch wheels.
3. Baer Brake Systems — Best for Show/Performance
Baer’s track-4 and EradiSpeed kits for Squarebody trucks are premium-grade hardware used on high-dollar builds. Large diameter rotors, multi-piston calipers, and stainless lines. Pricing: $1,200–2,000+. For a driver-quality daily or show truck, CPP is the better value. Baer is for the build where cost is secondary to quality and appearance.
Proportioning Valve: Non-Negotiable
If you’re converting only the front to disc while keeping rear drums, you must install a combination proportioning valve. Disc and drum brakes have fundamentally different pressure requirements — disc brakes need higher pressure, drums need a residual pressure check valve. Running front discs without the correct proportioning valve causes rear brake lockup (drums engaging too hard relative to the fronts) or inadequate front bite. Every quality conversion kit includes the correct valve — never skip it.
Master Cylinder Upgrade
Factory drum brake master cylinders are typically single-circuit and low-displacement. A disc brake conversion requires a dual-circuit master cylinder sized for disc/drum or disc/disc applications. CPP and Wilwood both include the correct master cylinder in their kits. If you’re sourcing components individually, a 1-inch bore master cylinder for disc/drum is the typical spec for a Squarebody 1500/2500.
Bleeding and Bedding Procedure
After installation: bleed all four corners starting at the furthest wheel from the master cylinder (typically right rear). Use a proper pressure bleeder or the two-person method — vacuum bleeders introduce air on these older caliper designs. After bleeding, bed the rotors: 10 moderate stops from 40 mph to 10 mph without stopping fully, then let cool for 10 minutes. This transfers an even layer of pad material to the rotor surface for consistent performance.
For Squarebody platform overview: Squarebody C10 complete guide. For LS swap planning on the same build: LS swap cost breakdown.
Shop FullSizeChevy Gear →
Keep going: find every Squarebody guide, from buying to restoration in the Squarebody Hub.
Talk Squarebody with other owners
Post your truck, your build, or the problem you are chasing. Real Squarebody owners in the FSC forum will tell you what actually worked on theirs.
Open the Squarebody Forum →
Find every repair, buying, maintenance, and troubleshooting guide in the Squarebody Owner’s Hub.
