Best Silverado Mods: The Upgrades Actually Worth Doing (GMT800 to T1XX)
There’s no shortage of parts you can bolt to a Silverado. The question is which ones are actually worth the money on your truck. The right answer depends on your generation and what you use the truck for — a GMT800 work truck and a T1XX 6.2L daily want different lists. Here’s how to spend smart, by category, with the in-depth guide for each mod. Start with the biggest-impact upgrades and skip the ones that just cost money without changing how the truck drives or works.
Stance: Leveling and Lift Kits
A level or mild lift is the most common Silverado mod, and it changes the truck’s whole look — but it also affects ride, alignment, and tire fitment, so it’s worth doing right. The approach differs by generation:
Decide leveling vs. full lift before you buy tires — the kit dictates what will clear.
Sound and Airflow: Exhaust and Intake
On the 6.2L EcoTec3 these are the classic “wake it up” mods — modest power, better sound, and on the intake side, better breathing on the big engine.
Set expectations: on a naturally aspirated truck, exhaust and intake are about sound and small gains, not a transformation. Budget accordingly.
Utility: Bed and Daily-Use Upgrades
The mods you’ll actually appreciate every day are the practical ones:
  • A tonneau cover — protects cargo, helps a little with MPG, one of the most useful Silverado accessories.
  • Cheap, high-value fixes that kill daily annoyances — grounds, wiring, small quality-of-life parts — covered in the under-$50 mods guide. These punch far above their cost.
Buy the Right Parts Where It Matters
Stance and cosmetics are fair game for budget parts. But for anything that affects safety, fitment, or how the truck drives — suspension components, sensors, ignition, electronics — cheap no-name parts fail early and cost you twice. Spend on OEM, GM Genuine, or ACDelco where it matters, and save the savings for the bolt-on cosmetics.
Which Silverado Should You Mod?
If you’re still shopping and want the best platform to build on, the best year Silverado to buy breakdown compares the generations. Match the truck to the build — a clean GMT800 is a different (and cheaper) starting point than a late T1XX.
Share Your Build
The best Silverado mod list is the one that fits your truck and how you use it. Post your generation, your goals, and your current setup on the FullSizeChevy forum and get real feedback from owners who’ve already done the mods you’re weighing.
If you sweat the details on your GMT800/GMT900, you'll like the gear. Built for Silverado, Sierra, Tahoe, Suburban, and Yukon owners who actually do the work.
Shop FullSizeChevy Gear →
Talk GMT800 with other owners
Open the GMT800 Forum →
Keep going: find every T1XX guide, known problem and fix in the T1XX Hub.
