Best Cold Air Intake for 6.2L Silverado (K2XX and T1XX)
The 6.2L EcoTec3 responds well to a cold air intake — the big engine breathes better with less restriction than the factory airbox allows. But not all intakes are worth the money, and on the 6.2L specifically, the choice of intake affects how much the tune can extract. Here’s what actually works.
What a Cold Air Intake Actually Does on the 6.2L
The 6.2L EcoTec3 (L86/L87) has a decent factory air intake but it’s restrictive at high RPM — stock is designed for noise reduction as much as performance. A quality cold air intake pulls cooler, denser air from outside the engine compartment and removes the resonator/air box restriction, freeing up the MAF and throttle body to flow more air. On a stock, untuned 6.2L, you’ll gain 5–10 hp. After a tune that optimizes the fuel and ignition tables for the new airflow, gains of 15–25 hp are realistic.
The intake works best as part of a combo: intake + cat-back exhaust + tune = 25–40 hp combined. Install the intake before your tune so the tuner optimizes everything together. See our complete Silverado tuning guide.
Best Intakes for the 6.2L Silverado
1. S&B Filters Cold Air Intake — Best Overall
S&B makes arguably the best bolt-on intake for GM trucks. Their 6.2L-specific kit uses an oversized oiled or dry cotton gauze filter in a sealed heat shield that isolates the intake from engine bay temperatures. The included MAF housing is a perfect fit with no sensor adaptation needed. Gain: 15–25 hp with a tune. Pricing: $350–420. The S&B is a lifetime filter — cleanable and re-oilable, so there’s no ongoing filter cost.
2. Airaid MXP Cold Air Intake — Best for Daily Drivers
The Airaid MXP uses a dry synthetic filter that doesn’t require oiling — important because over-oiled filters can contaminate the MAF sensor and trigger lean codes including P0172/P0175. The MXP’s sealed intake tube and heat shield are well-built. Compatible with the 6.2L on 2014–2021 applications. Pricing: $320–400. A safe choice if you don’t want to worry about filter oiling interval.
3. Volant Cold Air Intake — Best for Oiled Filter Preference
Volant uses a closed-box design with a conical oiled filter and a positive-seal box that eliminates hot air recirculation from the engine bay. The Volant’s strong point is its sealed box design — consistently cooler intake temps than open-element intakes. For 6.2L Silverados that see hot summer driving or towing in heat, the Volant’s temperature advantage is meaningful. Pricing: $350–450.
4. K&N 57-Series Cold Air Intake — Best Brand Recognition
K&N is the most recognized name in air filtration. Their 57-Series for the 6.2L is a proven fitment. The K&N red oiled filter is their signature. However, K&N’s filter oil has historically been more likely to contaminate MAF sensors than competing brands — use the MAF-safe filter oil and don’t over-oil. Pricing: $280–360.
What to Avoid
Avoid cheap Amazon/eBay “short ram” intakes under $80. These put a filter directly on the throttle body with no heat shield — you’re pulling hot engine bay air rather than cool outside air. You’ll actually lose power in some conditions. Buy a name-brand, closed-box intake with a proper heat shield or avoid it entirely.
Installation Notes for 6.2L Trucks
Most 6.2L intakes are 30–60 minute installs — remove the factory airbox and intake tube, install the new sealed box and intake tube, reconnect the MAF sensor harness, and secure the filter. No cutting or drilling required on quality kits. After installation, clear any existing codes and let the ECM adapt for 100–200 miles before evaluating gains. Then get a tune to maximize the investment.
K2XX vs T1XX Fitment
Confirm fitment before buying — the 2014–2018 K2XX 6.2L and the 2019+ T1XX 6.2L have different engine bay layouts and intake routing. Most brands offer separate part numbers for each. S&B, Airaid, and Volant all have K2XX and T1XX-specific kits. For K2XX platform details: K2XX complete guide. For T1XX: T1XX complete guide.
For the 5.3L equivalent, see: Best cold air intake for 5.3L Silverado.
Complete the 6.2L mod trio: Best exhaust for 6.2L Silverado and How to tune a Silverado.
Keep going: find every K2XX guide, known problem and fix in the K2XX Hub and the T1XX Hub.
Talk K2XX with other owners
Post your truck, your build, or the problem you are chasing. Real K2XX owners in the FSC forum will tell you what actually worked on theirs.
Open the K2XX Forum →
Find every repair, buying, maintenance, and troubleshooting guide in the K2XX Owner’s Hub.
