The 6.2L EcoTec3 already sounds good from the factory — deep, authoritative, distinctly V8. A quality exhaust takes that further: more volume, better tone, and measurable power gains when paired with a tune. Here’s what actually works on the 6.2L without turning your daily driver into an obnoxious drone machine.
What to Expect from a 6.2L Exhaust Upgrade
On a stock, untuned 6.2L, a cat-back exhaust adds 8–15 hp and improves exhaust tone substantially. After a tune that optimizes for the reduced backpressure, gains of 15–20 hp are realistic. Headers (long-tube) add 20–35 hp on top of that but require a tune and are not emissions-legal in all states. The intake + exhaust + tune combo is the foundational performance package for any 6.2L build — see our 6.2L intake guide and Silverado tuning guide.
Best Cat-Back Exhausts for the 6.2L Silverado
1. Borla S-Type Cat-Back — Best Overall Sound
Borla’s S-Type is the gold standard for Silverado exhaust tone. The 6.2L S-Type produces a deep, aggressive V8 note at wide-open throttle that mellows to a mild rumble at cruise — no drone on the highway. Built from T-304 stainless steel with a lifetime warranty. Available in single-exit (stock outlet location) or dual-exit rear configurations. Pricing: $600–750. The S-Type is the most recommended cat-back on 6.2L GMT800, K2XX, and T1XX trucks across every Silverado forum.
2. Flowmaster American Thunder — Best Value
The Flowmaster American Thunder delivers serious exhaust note at a price point ($380–450) well below premium brands. The chambered muffler design produces the classic Flowmaster rumble — more aggressive than the Borla, more polarizing in daily driving. If you want maximum noise for minimum cost, American Thunder delivers. Some highway drone is present at certain RPM bands — acceptable for most, annoying for some. Check fitment carefully: the 6.2L K2XX and T1XX have different outlet configurations.
3. MBRP 3-Inch Cat-Back — Best for Performance/Towing
MBRP’s 3-inch aluminized steel cat-back has the largest diameter of mainstream cat-back options for the 6.2L — this matters for high-output builds and for towing where sustained high-RPM operation is common. The larger diameter reduces exhaust backpressure more aggressively than 2.5-inch systems. Sound is moderate — more of a performance rumble than a show exhaust. Pricing: $350–500. Best paired with a performance tune.
4. Corsa Sport Cat-Back — Best for No Highway Drone
Corsa’s Reflective Sound Cancellation technology uses sound wave cancellation to produce an aggressive exhaust note under throttle while virtually eliminating highway drone. If you commute significant highway miles in your 6.2L Silverado and want the best of both worlds — aggressive sound when driving hard, quiet cruise — the Corsa Sport is the pick. Premium price ($750–900) but genuinely unique technology.
Headers for the 6.2L Silverado
Long-tube headers replace the factory cast-iron exhaust manifolds and deliver the biggest exhaust-side power gains — typically 20–35 hp on the 6.2L. They require a full tune (mandatory with long-tubes), may require removal of the O2 sensors for installation clearance, and are not CARB-legal in California. Popular brands: Kooks, American Racing Headers, and Hooker BlackHeart. Pricing: $800–1,400 for headers alone. Factor in tune cost when budgeting. Short-tube headers ($300–500) are a middle ground — more legal, less power gain, easier installation.
K2XX vs T1XX Fitment
The 2014–2018 K2XX and 2019+ T1XX 6.2L have different exhaust routing and outlet configurations. Most brands offer separate K2XX and T1XX part numbers — always verify before ordering. The T1XX also has a different ground clearance profile that affects some cat-back systems. For K2XX details: K2XX complete guide. For T1XX: T1XX complete guide.
For the 5.3L equivalent: Best exhaust for 5.3L Silverado. For the complete 6.2L mod overview: 6.2L cold air intake guide and tuning guide.
Keep going: find every K2XX guide, known problem and fix in the K2XX Hub and the T1XX Hub.
Talk K2XX with other owners
Post your truck, your build, or the problem you are chasing. Real K2XX owners in the FSC forum will tell you what actually worked on theirs.
Open the K2XX Forum →K2XX Gear
Shop all K2XX gear →Find every repair, buying, maintenance, and troubleshooting guide in the K2XX Owner’s Hub.
