Cheap mods that kill daily annoyances before they become big problems
Your truck’s daily quirks aren’t just annoyances—they’re warning signs. Left unchecked, a rattling door hinge or dim headlights can turn into costly repairs. That’s where smart, cheap mods under $50 come in to save the day. These quick fixes for Squarebody, GMT400/OBS, GMT800, and GMT900 trucks stop problems before they grow. Jump into the master list thread at FullSizeChevy forum. Post your under-$50 fix, part numbers, and photos. Ask questions. Get answers. Build the list with us.
Quick Fixes for Common Truck Issues
Keep those small issues from snowballing into big headaches. Here are some simple fixes to address common nuisances in your Chevy or GMC truck, all without breaking the bank.
Door Hinge and Striker Bushings
Ever hear that creak every time you open your truck door? It’s annoying, right? Replacing worn door hinge pins and bushings can solve this. If left alone, the door might not close properly, leading to more costly fixes.
Swap out the old pins and bushings with new ones. You can grab a set for under $20. A simple re-alignment of the door will ensure smooth swinging. This not only stops the noise but saves your door latch from unnecessary wear. For a detailed walkthrough, check out the FullSizeChevy forum where fellow enthusiasts share tips and tricks.
Headlight Relay Harness Upgrade
Dim headlights making night drives a challenge? A headlight relay harness can boost your lights. Many older trucks don’t deliver enough power to the headlights due to voltage drop.
Installing a relay harness ensures full voltage reaches the headlights. This results in brighter, more reliable lights. You’ll notice a world of difference for less than $50. This upgrade not only makes driving safer but also adds a modern touch to your trusty old truck.
For OBS owners who want more out of high beams specifically, the OBS / GMT400 4-Hi headlight mod keeps the low beams lit when you switch to high so all four bulbs run together. Same wallet-friendly category, real visibility improvement when wired correctly.
Hood Bumpers and Latch Adjustment
Does your hood rattle at high speeds? It might be time to check those hood bumpers. Over time, they wear out, causing that annoying noise. A quick replacement can solve this.
Adjusting the hood latch and replacing the bumpers can keep the hood snug. Say goodbye to rattles and enjoy a quieter ride. It’s a simple mod, but it makes a big difference. Learn more about quick fixes on the FullSizeChevy forum.
Essential Electrical Mods Under $50
Electric issues can seem daunting, but they’re easy to tackle with the right mods. Let’s dive into essential electrical updates that keep your truck reliable and efficient.
Big 3 Ground Refresh
Your truck’s electrical system might need a boost. A Big 3 upgrade involves replacing three key ground wires: engine to chassis, battery to chassis, and battery to engine.
This refresh improves overall electrical performance. Better grounds mean smoother starts and consistent power to all systems. Kits are available for under $50, making it a worthy investment to avoid electrical gremlins. For more details, visit the FullSizeChevy forum.
Wiper Pulse Board Solutions
Frustrated by erratic wipers? It could be the wiper pulse board. These boards can wear out, causing unpredictable wiper behavior.
Swapping it out is straightforward. With a new board, your wipers will work like a charm. This fix is perfect for GMT400/OBS models, where wiper issues are common. Check out the FullSizeChevy forum for more on this upgrade.
Blower Motor Resistor Fix
Facing issues with your blower motor settings? It’s likely the blower motor resistor. When it fails, you lose fan speed control.
Replacing the resistor restores all fan speeds, ensuring comfort in any weather. It’s a quick and cheap fix, costing less than $30. Stay cozy or cool, depending on the season, with this simple upgrade.
Must-Do Maintenance Tips
Routine maintenance keeps your truck running smoothly. Here are some maintenance tips that are easy on the wallet and essential for longevity.
Caliper Slide Pin Service
Braking issues can often be traced back to neglected caliper slide pins. Over time, they can seize, causing uneven pad wear or brake noise.
Regularly cleaning and lubricating the pins ensures your brakes work effectively. Use high-temp brake grease for the best results. This simple service can prevent costly brake repairs down the road.
Tailgate Cables and Latch Care
A sagging tailgate is not only inconvenient but can also be unsafe. Inspect your tailgate cables regularly. If they’re frayed or broken, it’s time for a replacement.
New cables cost around $20 and are easy to install. Ensure the latch is clean and lubricated for smooth operation. Proper tailgate function is crucial, especially when hauling heavy loads.
Column Shifter Cable Bushing Replacement
Is shifting becoming a chore? The column shifter cable bushing might be the culprit. Over time, the bushing can wear out, leading to sloppy shifts.
Replacing it with a new bushing restores crisp, smooth gear changes. It’s a simple fix that makes driving your truck more enjoyable. For more maintenance tips, swing by the FullSizeChevy forum.
The longer you wait, the more these small issues can grow. Dive into these mods and maintenance tips to keep your truck running at its best. Join other truck enthusiasts on the FullSizeChevy forum to share your experiences and learn from others.
