GMT800 Tailgate Rebuild Guide: Latch, Cable, Hinge & Handle (1999–2006 Silverado/Sierra)
A GMT800 tailgate takes a beating for 20-plus years, and eventually the cheap points give out: a cable snaps, a latch stops catching, the handle goes sloppy, or the driver-side hinge wears until the gate sags and rattles. The good news is that none of it is hard to fix, and the parts are inexpensive. This is the order to work through it so you rebuild the whole tailgate once instead of chasing one failure at a time.
Which trucks this covers
This applies to the 1999–2006 GMT800 Silverado and Sierra 1500/2500/3500 (and the 2007 “Classic” body). The latch, cable, and hinge design is shared across the platform, so the same parts and procedure work whether you have a work-truck 1500 or a 2500HD. For the full platform rundown, see our GMT800 buyer’s guide.
Symptoms owners notice
  • Tailgate drops or bangs down hard when you open it — usually a broken or stretched support cable.
  • Gate won’t latch on one side, pops open over bumps, or you have to slam it — worn latch.
  • Handle feels loose or won’t release both sides evenly — worn handle or bent actuator rods.
  • Gate sags at the driver’s corner, rubs the bed, or rattles — worn hinge/pivot.
Diagnose before you buy parts
Open the tailgate and watch what actually fails. If it slams down, check both cables — a stretched cable looks fine until you compare it to the good side. If it won’t stay shut, work each latch by hand with the gate off the truck; a good latch snaps crisp, a worn one feels notchy or won’t hold. If the gate sags, grab it at the corner and lift; play at the hinge pin tells you the hinge is done. Replace what’s actually worn — you don’t always need every part, but on a high-mile truck it’s usually worth doing the set while it’s apart.
Parts used in the rebuild
These are the exact parts used in the video build. Dorman makes correct-fit replacements for the GMT800 tailgate, and the SHALL magnetic nut driver makes the latch bolts far easier to handle inside the gate skin.
Some of the links above are affiliate links. If you buy through them it costs you nothing extra and helps support FullSizeChevy. Prefer OEM GM parts where you want a factory match — the Dorman parts listed are the ones used in this build.
Rebuild in the right order
1. Support the gate and pull the access panel
Open the tailgate and support it level — a helper or a strap makes this a lot easier and keeps a broken cable from letting it drop on your hand. Pop the inner access cover so you can reach the latch bolts and the actuator rods.
2. Handle and actuator rods
The center handle drives two rods, one to each latch. Disconnect the rods, note how they clip in, and check them for bends and worn ends. A sloppy release is usually the handle or the rod clips, not the latches.
3. Latches (both sides)
Unbolt each latch through the access opening — this is where the magnetic nut driver earns its keep, because dropped hardware disappears inside the gate. Swap the driver (38666) and passenger (38667) latches, reconnect the rods, and confirm both catch crisply by hand before you reinstall anything.
4. Support cables
Replace both cables (38536) as a pair even if only one broke — the other is the same age and stretched. Route them the same way they came out so the gate stops level and doesn’t over-swing.
5. Hinge
If the gate sagged, replace the worn hinge (38642). Get the gate lined up in the bed opening before you fully tighten so the panel gaps are even and it doesn’t rub.
On fasteners: snug the latch and hinge hardware firmly and check that everything operates smoothly — do not guess at a torque number. If you want a spec, verify it against GM service information for your exact year and model before final tightening.
Verify after the repair
  • Both latches catch and hold with a normal push — no slamming needed.
  • The gate stops level and doesn’t swing past horizontal (cables doing their job).
  • No sag at the driver’s corner and even gaps to the bed sides.
  • Handle releases both latches evenly.
Common mistakes to avoid
  • Replacing one cable. Do both — the survivor is next.
  • Skipping the access-panel hardware check. Dropped bolts inside the gate are a real headache; use a magnetic driver.
  • Forcing a worn latch to “work.” If it feels notchy off the truck, it’ll fail on the road.
  • Tightening the hinge before aligning the gate. You’ll end up with uneven gaps and rubbing.
FAQ
Why does my GMT800 tailgate slam down when I open it? A broken or stretched support cable. Replace both cables as a set.
Can I fix just the latch that won’t catch? You can, but on a 200k-mile truck both latches are usually worn — doing the pair saves a second teardown.
Is the tailgate the same across 1999–2006? Yes, the GMT800 latch/cable/hinge design carries across the platform, including the 2007 Classic.
Related GMT800 guides
Discuss it on the forum
What failed first on your GMT800 tailgate — cables, latches, or the handle? Post your year, mileage, and what you replaced (photos welcome) in the FullSizeChevy forum.
Watch the full rebuild
If you sweat the details on your GMT800/GMT900, you'll like the gear. Built for Silverado, Sierra, Tahoe, Suburban, and Yukon owners who actually do the work.
Shop FullSizeChevy Gear →
Talk GMT800 with other owners
Open the GMT800 Forum →
