GMT400 / OBS Fuel Filter Replacement (1988–1998 Chevy & GMC)
The fuel filter is one of the cheapest, most-overlooked parts on an OBS truck, and a clogged one causes real drivability problems — hard starts, hesitation, power loss under load. On the GMT400 (1988–1998 C/K trucks) it’s an inline canister on the frame rail, not buried in the tank, so it’s a straightforward job with the right prep.
Short version: the GMT400 fuel filter is an inline metal canister mounted on the driver-side frame rail, generally between the fuel tank and the engine. Relieve fuel pressure first, catch the spill, and mind the thread fittings.
https://www.youtube.com/watch?v=Mivlggnlqy8
Trucks, years and engines
  • GMT400 / OBS: 1988–1998 Chevrolet and GMC C/K full-size trucks and related SUVs
  • Applies to the TBI and Vortec gas engines of this era (4.3 V6, 5.0, 5.7, 7.4)
Part reference: the OEM inline filter is ACDelco GF652A, which covers these trucks up to 2002. Always confirm the correct filter for your exact year, engine and emissions configuration before buying — fitment can vary, and diesel and later returnless setups differ.
Symptoms of a clogged fuel filter
  • Hard starting, especially warm
  • Hesitation or stumble under acceleration
  • Loss of power towing or climbing
  • Engine feels like it’s “running out” at higher rpm
  • In bad cases, stalling
These symptoms overlap with a weak fuel pump, a failing pressure regulator, and (on 1996–1998 Vortec 5.7 CSFI trucks) a leaking spider injector assembly. Don’t just throw a filter at a no-start. Check fuel pressure before deciding.
Diagnosis before you replace
GMT400 fuel path diagram showing driver-side frame-rail filter location, ACDelco GF652A.
Tank to engine, with the inline filter clamped to the driver-side frame rail. The arrow on the filter body points toward the engine.
  1. Check fuel pressure with a gauge on the test port. Compare against the spec for your engine and year.
  2. A clogged filter typically shows as pressure that drops off under load or won’t build — but a weak pump looks similar. The filter is the cheap first step; verify pressure to separate the two.
  3. On 1996–1998 Vortec 5.7, rule out CSFI fuel system issues if you have a hard-start/no-start rather than a simple filter clog.
Tools and supplies
  • Correct replacement filter (verify part)
  • Line wrenches that fit the filter fittings (flare-nut style to avoid rounding)
  • Fuel-rated safety glasses and gloves
  • Drain pan and rags — fuel will spill
  • Fire extinguisher within reach
Replacement process
  1. Relieve fuel system pressure. Pull the fuel pump fuse (or relay) and crank/run the engine until it stalls, then crank a couple seconds more. This is the step people skip and regret.
  2. Disconnect the battery negative before working on fuel fittings.
  3. Locate the filter on the driver-side frame rail. Wire-brush the fittings so wrenches seat cleanly.
  4. Support the filter and loosen the fittings with the correct line wrenches. Expect residual fuel — have the pan ready.
  5. Note the flow direction arrow on the old filter and install the new one the same way. Backwards is a real mistake here.
  6. Start the new fittings by hand to avoid cross-threading, then tighten to spec.
  7. Reinstall the fuse/relay, reconnect the battery, cycle the key a few times to prime, then check for leaks before starting.
Torque and exact fitting specs vary by year and hardware — follow the service manual or the values with your replacement part. Do not guess on fuel fittings.
Common mistakes and bad advice to avoid
  • Not relieving pressure. These systems hold pressure; a fitting can spray fuel. Do it right.
  • Installing the filter backwards. Match the flow arrow to the direction of fuel travel (tank to engine).
  • Rounding the fittings with an open-end wrench. Use flare-nut/line wrenches.
  • Replacing the filter to fix a no-start without checking pressure. Could be the pump, regulator, or CSFI. Diagnose first.
Verify after replacement
  • No leaks at either fitting after priming and after the engine warms
  • Fuel pressure back in spec under key-on and running
  • Drivability symptoms (hesitation, power loss) resolved
  • No fuel smell around the frame rail
FAQ
Where is the fuel filter on a GMT400?
Inline on the driver-side frame rail, between the tank and engine. It’s not in the tank on these trucks.
What filter do I need?
ACDelco GF652A is the OEM inline filter, and it covers these trucks up to 2002 — confirm the exact fitment for your year and engine before buying.
How often should I change it?
On a truck this age, if you don’t know when it was last done, do it now, then on a sensible interval. A clean filter is cheap insurance for the pump.
My truck won’t start — is it the filter?
Maybe, but check fuel pressure first. On 1996–1998 5.7 Vortec, also consider the CSFI system.
Discuss this in the FullSizeChevy forum
Post your year, engine and the fuel pressure numbers you’re seeing. Real readings help other owners separate a clogged filter from a dying pump.
Related on FullSizeChevy
Open the OBS / GMT400 Forum →
OBS GMT400 Chevy Truck T-Shirt – Bold Shield (1988-1998 Silverado) | Heritage Badge Price range: $28.86 through $35.61
OBS GMT400 Chevy Silverado T-Shirt – ’95 (1988-1998 Silverado) | Heartbeat of America Price range: $28.86 through $35.61
OBS GMT400 Chevy Truck T-Shirt – Vintage Bowtie Shield (1988-1998 Silverado) | Heritage Badge Price range: $28.86 through $35.61
OBS GMT400 Chevy Truck T-Shirt – Ice Blue City (1988-1998 Silverado) | GMT400 Crew Price range: $28.86 through $35.61
OBS GMT400 Chevy Truck T-Shirt – White City (1988-1998 Silverado) | GMT400 Crew Price range: $28.86 through $35.61
OBS or DIE Poster | 1988–1998 Chevy Silverado GMT400 Truck Garage Wall Art | OBS Truck Enthusiast Decor Price range: $34.18 through $112.27
OBS GMT400 Chevy Truck T-Shirt – Red City (1988-1998 Silverado) | GMT400 Crew Price range: $28.86 through $35.61
OBS or DIE | FSC Car Air Freshener$12.05
OBS GMT400 Chevy Truck T-Shirt – Full Size or Nothing (1988-1998 Silverado) | Fullsize Monster Truck Series Price range: $28.86 through $35.61
OBS GMT400 Chevy Truck T-Shirt – Classic Red Shield (1988-1998 Silverado) | Heritage Badge Price range: $28.86 through $35.61
Built Not Bought Chevy Garage Sign | Full Size Chevy Truck Poster | Mechanic Shop Wall Decor | Truck Builder Garage Art Price range: $34.18 through $112.27
FullSizeChevy White & Red Truck Sun Shade | FSC Windshield Sunshade for Chevy Trucks | Interior Heat Protection$49.86
