The 3.0L Duramax diesel option in the T1XX Silverado has made the diesel-vs-gas question real for half-ton buyers for the first time. Previously it was academic — the Duramax was only in heavy-duty trucks. Now you can actually cross-shop the 3.0L I-6 diesel against the 6.2L EcoTec3 V8. Here’s the honest answer.
The 3.0L Duramax: What It Is
The 3.0L Duramax LM2 is a turbocharged inline-6 diesel producing 277 hp and 460 lb-ft of torque (2020+ specs). It’s paired exclusively with the 10-speed Hydra-Matic 10L80E. EPA fuel economy ratings: 23 city / 33 highway / 26 combined for 2WD — making it one of the most fuel-efficient full-size trucks available. Maximum tow rating: 9,300 lbs in properly equipped configuration.
The 6.2L EcoTec3: What It Is
The 6.2L L87 naturally-aspirated V8 produces 420 hp and 460 lb-ft of torque — exactly the same torque as the diesel but with 143 more horsepower and a completely different character. Paired with the 10-speed 10L80E. EPA ratings: 15 city / 20 highway / 17 combined for 2WD (4WD: 14/19). Maximum tow rating: 13,400 lbs with Max Trailering Package. See: 5.3L vs 6.2L comparison.
Fuel Cost Over 100,000 Miles
The diesel’s fuel economy advantage is real — roughly 9 MPG better highway. At 15,000 miles/year and current fuel prices (assuming diesel ~$0.30/gallon premium over regular unleaded): the Duramax saves approximately 125 gallons per year = $475/year at $3.80/gallon gas and $4.10 diesel. Over 100,000 miles at that rate: approximately $3,000 in fuel savings. The diesel commands a $2,500–4,500 new-truck price premium. The fuel savings roughly break even over the truck’s life — which means the decision should be made on criteria other than fuel savings alone.
All of that assumes EPA-rated economy. If you already own one, run your last few tanks through the Fuel Mileage Calculator first — the payback math only holds if your real number matches the sticker.
Towing: Where the 6.2L Wins
The 6.2L tows 13,400 lbs to the diesel’s 9,300 lbs — 44% more maximum capacity. For buyers regularly towing above 9,000 lbs, this isn’t a close call. The 6.2L also maintains speed on grades better under heavy loads (more horsepower reserve), runs cooler under sustained high-load towing, and has simpler emissions hardware. If towing is primary use, the 6.2L is the correct engine.
Fuel Economy: Where the Diesel Wins
For highway drivers who rarely tow but rack up miles, the diesel’s 33 MPG highway vs the 6.2L’s 20 MPG is significant. A 50,000 miles/year highway driver saves 650+ gallons annually — over $2,400/year at current prices. The economics flip entirely in favor of the diesel at high mileage. Fleet buyers and long-haul drivers who rarely tow heavy loads make a legitimate case for the diesel.
Maintenance Cost: The Diesel Penalty
Diesel maintenance is more expensive than gasoline: diesel oil changes cost more (more capacity, specialized oil), DEF (Diesel Exhaust Fluid) requires regular top-off ($15–30/gallon, ~1 gallon per 2,500 miles), and the emissions system (DPF, SCR, EGR) requires periodic maintenance and eventual replacement ($2,000–4,000 when components fail). A diesel fuel filter change is more involved than a gasoline equivalent. Over 150,000 miles, diesel maintenance typically costs $3,000–6,000 more than an equivalent gasoline engine.
Reliability: Early Track Record
The 3.0L Duramax is a relatively new engine in the half-ton application (introduced 2019). Early owner reports are generally positive but the long-term track record doesn’t exist yet — there are no 200,000-mile 3.0L Duramax Silverados to study yet. The 6.2L EcoTec3’s architecture is derived from the proven LS family with decades of high-mileage data. For buyers who keep trucks past 150,000 miles, the 6.2L’s longer proven reliability track record is a real advantage.
The Verdict
Buy the 3.0L Duramax if: You drive 20,000+ miles/year primarily on the highway, rarely tow above 8,000 lbs, plan to keep the truck 10+ years and want the best fuel efficiency, or the emissions-compliant diesel operation is important for your use case (fleet, commercial).
Buy the 6.2L EcoTec3 if: You regularly tow above 9,000 lbs, want a proven high-mileage powertrain, prioritize horsepower and performance feel, want lower maintenance complexity, or are keeping the truck under 10 years. The 6.2L is also simply a more enjoyable engine — 420 hp delivers a driving experience the diesel can’t match.
The honest take: For most half-ton buyers who tow occasionally and drive moderate miles, the 6.2L is the better all-around choice. The diesel makes a compelling case only for specific high-mileage or fleet use cases where the fuel savings math actually works out.
For T1XX platform info: T1XX complete guide. For towing capacity by year: Silverado towing capacity guide.
Keep going: find every K2XX guide, known problem and fix in the K2XX Hub and the T1XX Hub.
Talk K2XX with other owners
Post your truck, your build, or the problem you are chasing. Real K2XX owners in the FSC forum will tell you what actually worked on theirs.
Open the K2XX Forum →K2XX Gear
Shop all K2XX gear →Find every repair, buying, maintenance, and troubleshooting guide in the K2XX Owner’s Hub.
