Can GMT400 Fit 33s? What Really Works
If you’re staring at your truck and wondering can GMT400 fit 33s, the short answer is yes. The real answer is that some GMT400s fit 33s clean, some fit them with light rubbing, and some turn that simple tire upgrade into a weekend of trimming, torsion crank, and wheel swap drama.
That matters because a GMT400 can look dead right on 33s. The stance gets tougher, the wheel wells fill out, and you keep enough sidewall to still look like a truck instead of a mall crawler. But fitment on these trucks is all about the combo, not just the tire number printed on the sidewall.
Can GMT400 fit 33s without a lift?
Sometimes, yes. But don’t treat that as a blanket rule for every OBS Chevy or GMC.
A stock-height 2WD GMT400 usually has a better shot at fitting a true 33 with the right wheel specs than a 4WD truck with tired torsion bars, sagging springs, or aggressive offset wheels. The biggest problem usually isn’t the tire diameter by itself. It’s where the tire sits during a turn and how much room it has at the rear of the front fender, lower valance, and inner wheel well.
A lot of guys say they are running 33s when what they really have is a 285/75R16 or a 275/70R18 that measures a little under or a little over 33 inches depending on brand. That’s why two trucks with the “same” size can behave totally differently. One all-terrain might run narrow and short. Another mud tire in the same advertised size might be chunkier and rub everywhere.
If your GMT400 is bone stock, the safest expectation is this: 33s can fit, but you may need to accept some rubbing at full lock or over bumps unless your wheel setup is conservative.
What decides if 33s will clear?
The tire size is only one piece of the puzzle. Wheel width and backspacing matter just as much.
A 33×10.50 tire is a lot easier to live with than a 33×12.50. That extra width changes everything. A narrower tire stays tucked in, clears suspension parts better, and usually avoids the heavy outer-fender contact that comes with wide rubber on low-backspacing wheels.
Backspacing is the part people overlook. A wheel pushed too far outward looks aggressive, but it swings the tire into the fender harder during turns. A wheel tucked too far inward can hit suspension components. The sweet spot depends on whether you’re running factory-style wheels, aftermarket alloys, or old-school steelies, but the general rule holds up – the more aggressive the wheel offset, the more likely 33s become a rubbing problem.
Suspension condition matters too. A GMT400 with worn front springs, sagging leafs, or soft torsion bar settings won’t hold the tire in the same place as a fresh truck. Two trucks with identical tire and wheel specs can fit differently just because one sits half an inch lower than it should.
Best tire sizes if you want the 33-inch look
If you want the look of 33s without turning your truck into a clearance project, there are a few sizes that usually make the most sense.
A 285/75R16 is the classic move. On many GMT400s, it gives you that 33-inch stance without the bulk of a 12.50-wide tire. It’s a strong middle ground for guys who still use the truck and don’t want constant rubbing every time they back into a parking spot.
A true 33×10.50R15 or 33×10.50R16, if you can find the setup you want, is another smart choice. It keeps things tall without going unnecessarily wide. For a GMT400 that sees street miles, that narrower footprint often works better than chasing the fattest tire you can stuff under it.
A 33×12.50 is where things get more conditional. Can it be done? Absolutely. Will it fit every stock-height GMT400 cleanly? Not even close. That’s the size where lift, trimming, and wheel specs start making or breaking the deal.
2WD vs 4WD GMT400 fitment
This is where conversations get messy, because people lump all GMT400s together when they don’t all sit the same.
A 2WD truck can sometimes fit 33s more easily depending on front suspension geometry and wheel setup, especially if you’re using a reasonable-width tire. But if it’s lowered even a little, all bets are off. A lowered 2WD OBS will run out of room fast.
A 4WD truck has the advantage of a factory-taller stance, but IFS trucks are sensitive to tire width and wheel offset. Cranking the torsion bars can help gain some room up front, but that isn’t free lift. It can stiffen the ride and change angles, and it’s not the same as building the front end correctly.
SUVs like the Tahoe, Yukon, and Suburban bring their own little quirks too. Weight, rear ride height, and front-end condition all affect how the truck carries the tire. Same platform, different realities.
Will you need trimming or a leveling kit?
A lot of GMT400 owners end up needing just a little help, not a full suspension overhaul.
If you’re running a modest 33 on a sensible wheel, a small torsion adjustment on a 4WD or a mild leveling setup can be enough to get things under control. Often the rubbing happens at full steering lock or when the front end compresses into a driveway or dip. In that case, a little extra height and a little trimming at the plastic or valance area can solve it.
If you’re trying to run 33×12.50s on wide wheels with aggressive offset, expect more work. That’s usually where trimming becomes part of the package. You might clear at ride height and still catch the fender during a turn. Street fitment and real-world fitment are not always the same thing.
This is also where being honest about the truck’s job matters. A pavement truck that only sees normal driving can tolerate a fitment setup that would be annoying on a hunting rig, tow rig, or trail truck. If the suspension cycles harder, the tire needs more room.
The wheel setup that usually works best
For most GMT400 owners, the best setup is not the most extreme one. That’s the truth.
A moderate-width wheel, conservative backspacing, and a tire closer to 285 width than 12.50 width usually gives the best balance of stance, steering, and clearance. That setup keeps the tire from hanging way outside the truck, which helps with rubbing and keeps road spray and scrub radius from getting out of hand.
Once you go chasing a deep-lip wheel with a lot of poke, 33s become harder to manage. It might look killer parked, but if it chews the fender every time you turn into a gas station, it gets old fast.
What about gearing, power, and drivability?
Fitting 33s is one question. Living with 33s is another.
Most GMT400 trucks can handle 33s without becoming miserable, especially if the truck already has decent torque and isn’t geared too tall. But you’ll feel the difference. Acceleration can soften up, braking can feel a little lazier, and the speedometer will be off unless corrected.
If you have a smaller V8, a tired 4L60E, or highway gears, 33s may expose weaknesses that smaller tires didn’t. That doesn’t mean don’t do it. It just means tire fitment isn’t only about physical clearance. It’s also about whether the truck still drives the way you want.
So, can GMT400 fit 33s and still work like a truck?
Yes, if you build the combo instead of chasing a number.
A GMT400 on 33s can look perfect and drive right when the tire width, wheel specs, ride height, and intended use all line up. If you want the easiest path, stay with a narrower 33, avoid wild wheel offset, and be realistic about whether you’re okay with minor rubbing or small trim work. If you’re set on wide 33s with an aggressive stance, plan for more than just bolting tires on.
That’s the good part about these trucks. There isn’t one answer, because there isn’t one kind of GMT400 owner. Build it for how you use it, keep the culture alive, and your truck will tell you pretty quick whether 33s were the right call.
Open the OBS / GMT400 Forum →
