Published August 2, 2026 · Updated November 12, 2026 · How we source this
Best LS Engine by Goal: Pick the Right Swap Donor for Your Chevy or GMC Truck
“Which LS is best?” is the wrong question — the right one is “best for what?” A junkyard iron 5.3 is the best budget swap and a terrible choice for a 600-hp street truck; an LS3 is the opposite. This guide picks by goal, and every pick names the exact RPO, the controller and transmission that go with it, and the mistake that bites people. Once you’ve chosen, verify the specific engine with the donor-identification guide and check the deeper compatibility in the Gen III vs Gen IV guide.
How to read this: displacement, block material and the electronics era for each pick are verified against GM and corroborating sources. Where a value depends on the exact year (throttle type, AFM on some 5.3s), it’s called out — confirm it on your actual donor before buying.
Quick answer: displacement vs goal
| Your goal | Start with | Why |
| Cheapest running swap | 5.3L LM7 (iron, Gen III) | Everywhere, cheap, simple wiring |
| Budget torque / towing | 6.0L LQ4 or LQ9 (iron, Gen III) | Iron 6.0, loves cam + boost, nearly indestructible |
| Big naturally-aspirated power | 6.2L LS3 or L92 (rec-port heads) | 400+ hp stock, best-flowing factory heads |
| Lightest weight | 5.3L aluminum (LM4/L33) or LS1 5.7 | Aluminum block saves ~100 lb over iron |
| Modern drivability + 6-speed | Any 58x Gen IV + 6L80E/6L90E | Electronic throttle, six-speed auto |
| Simplest wiring | 1999–2002 cable-throttle Gen III | No drive-by-wire pedal/TAC to integrate |
4.8 vs 5.3 vs 6.0 vs 6.2 — the honest version
- 4.8L (LR4 / LY2 / L20): the forgotten LS. Same external size as a 5.3, revvy, cheap — but less torque and fewer of them around. Fine for a light, budget build; rarely the best value once you compare to a 5.3.
- 5.3L (LM7, L59, LM4, L33 Gen III; LMG, LC9, LY5 Gen IV): the default swap engine. Cheapest, most plentiful, plenty of power with a cam and tune. Watch the AFM split: Gen III 5.3s (LM7 etc.) have no AFM; many Gen IV 5.3s (LMG, LC9, LY5) do, and AFM lifter failure is their #1 issue — plan a delete if you use one.
- 6.0L (LQ4/LQ9 Gen III iron; L96/LY6 Gen IV iron; LS2 aluminum): the torque king of the budget world. The iron 6.0 is the go-to for towing and boost. The Gen IV iron 6.0s (LY6/L96) add VVT and rectangular-port heads.
- 6.2L (LS3, L92, L94, L99): the power tier. Rectangular-port heads make 400+ hp stock. Aluminum, more expensive, worth it when power is the point.
Best LS by goal
Goal: cheapest reliable swap → 5.3L LM7
Pick: LM7 (5.3L, iron, Gen III), ideally a 1999–2002 cable-throttle unit. Pair with: 4L60E + P01/P59 PCM. Why: it’s the most plentiful and cheapest LS, and the pre-2003 cable throttle makes the wiring dead simple in an older truck. Trap: don’t overpay for a “5.3” that’s actually a 4.8 LR4 — confirm displacement. The LM7 has no AFM, so ignore AFM-lifter horror stories; they don’t apply to it.
Goal: budget torque & towing → 6.0L LQ4 / LQ9
Pick: LQ4 (base) or LQ9 (higher compression), both 6.0L iron Gen III. Pair with: 4L80E for real towing + P59. Why: the iron 6.0 makes strong low-end torque, takes a cam and tune to 400+ hp easily, and shrugs off boost. Trap: LQ9 is not a “rectangular-port head” engine — its advantage over the LQ4 is flat-top pistons (higher compression) and cam, both use cast-iron cathedral-port heads. Don’t pay an LQ9 premium expecting better heads.
Goal: big N/A power → 6.2L LS3 or L92
Pick: LS3 (car, 6.2L) or L92 (truck/SUV, 6.2L) — both rectangular-port aluminum. Pair with: 6L80E + E38/E67 (plan a T43 for the six-speed), or a 4L80E if you keep it simple. Why: 400+ hp stock, the best-flowing factory heads in the family. The L92 adds VVT for drivability. Trap: “L92 heads” on a cathedral-port engine is a real upgrade but not bolt-on-in-isolation — it changes the intake manifold, injector height and pushrods.
Goal: lightest weight → aluminum 5.3 or LS1
Pick: LM4/L33 (aluminum 5.3, Gen III) or an LS1 (5.7L aluminum car engine). Pair with: 4L60E + P01/P59. Why: the aluminum block drops roughly 100 lb off the nose versus an iron 5.3/6.0 — noticeable in a light truck’s handling. Trap: aluminum 5.3s are less common and not much cheaper than iron; only chase one if weight genuinely matters to your build.
Goal: modern drivability + factory six-speed → 58x Gen IV + 6L80E/6L90E
Pick: any 58x Gen IV engine (LMG/LC9 5.3, L96 6.0, L92/LS3 6.2). Pair with: 6L80E or 6L90E + E38/E67 and a T43 transmission control strategy. Why: electronic throttle, better idle/cruise, and a six-speed auto that makes any of these drive like a modern truck. Trap: the six-speed is not a bolt-in for an engine-only ECM — you must plan the T43/network control. Budget for it up front.
Goal: simplest possible wiring → 1999–2002 cable Gen III
Pick: a 1999–2002 LM7 or LQ4 with the factory cable throttle. Pair with: 4L60E/4L80E + P01/P59. Why: cable throttle means no electronic pedal, no throttle-actuator module to integrate — the shortest path to a running truck in a Squarebody or OBS. Trap: 2003-and-later trucks went drive-by-wire (TAC module + electronic pedal); converting one back to cable is a hardware job, not a tune. If you want cable-simple, buy a pre-2003 engine.
By chassis: what makes sense where
Squarebody (1973–1987)
The chassis predates EFI, so you’re building the whole system. That argues for the simplest, cheapest reliable donor: a cable-throttle LM7 5.3 or LQ4 6.0 with a 4L60E/4L80E and a standalone harness. Save the electronic-throttle Gen IV complexity for a platform that has more factory infrastructure to lean on. Oil pan is chosen for your crossmember/steering/2WD-4WD clearance — not by a “front-sump” label.
OBS / GMT400 (1988–1998)
The most-documented swap platform. Same logic as Squarebody, with a huge parts ecosystem. Budget builds run the iron 5.3/6.0; performance builds drop in an LS3/L92. Wiring specifics are in the OBS wiring guide.
GMT800 (1999–2006) & GMT900 (2007–2013)
These already came with LS power, so a “swap” is usually an upgrade within the family. On a GMT800 (Gen III, mostly 24x) or GMT900 (Gen IV, 58x), match the replacement engine’s crank reluctor and controller to what the truck already has — or plan the conversion. On a GMT900 the cheapest big gain is often a cam + AFM delete on the existing 5.3/6.0 rather than a full engine swap.
Which LS engine to pick
For most people, most of the time: a junkyard iron 5.3 (LM7) is the best-value swap, and an iron 6.0 (LQ4/LQ9) is the best-value torque/boost engine. Step up to a 6.2 (LS3/L92) only when naturally-aspirated power is the goal. Then verify the exact engine before you buy — how to identify an LS donor.
Revision: draft v1 (2026-08-02). Engine facts generated from the FSC LS engine dataset (GM-verified for the major RPOs). Pricing intentionally omitted here — see the LS swap cost guide.
Keep going: plan the whole build from the LS Swap Hub, and post your shortlist in the FSC forum before you buy.
