OBS Door Rod Clip Part Numbers: OEM Door Handle Rod Clips for Chevy & GMC Trucks
Your OBS truck’s door handle flops when you pull it, but the door doesn’t budge. Or the lock knob wiggles loose and the rod is rattling around somewhere inside the door. Nine times out of ten, the culprit is a part smaller than a nickel: a broken OBS door rod clip. These little plastic retainers hold the metal linkage rods onto the handle, lock, and latch. When one cracks or falls off — and after 25-plus years, they do — the handle moves but nothing it’s supposed to move goes with it.
The frustrating part is finding the right one. People search “door panel clips” when they actually need door rod clips, dealers call them by five different names, and half the part numbers floating around forums are for a different door, a different side, or a different truck entirely. This guide sorts out the naming, gives you the part numbers we can actually verify, and — just as important — tells you which numbers to double-check before you spend a dime.
Quick Answer
On OBS Chevy and GMC trucks, these parts are commonly called door handle rod clips, door rod guides, latch rod clips, lock rod retainers, or linkage clips. One OEM GM part number seen on GM Genuine packaging is 15053341, labeled as a Guide, Front Side Door Locking Rod (a door handle rod guide). It’s cataloged broadly for 1985–2007 GM vehicles, so treat it as a strong lead rather than a guaranteed fit. Always verify by VIN, door position, cab style, and left/right side before ordering.
What Are OBS Door Rod Clips?
Inside every door on your truck is a set of stiff metal rods. One runs from the outside handle to the latch. Another runs from the inside handle to the latch. More rods tie in the lock knob and the key cylinder. Those rods have to stay connected at both ends or nothing works — and that’s the clip’s entire job. An OBS door rod clip snaps over the end of a rod and holds it into the hole on the handle, lock, or latch so that pulling the handle actually pulls the rod.
They are not door panel clips. That’s the single most common mix-up, so it’s worth saying plainly: door panel clips hold the interior trim panel to the metal door skin. Door rod clips live behind that panel and hold the linkage rods to the mechanism. Different part, different shape, different job.
When a rod clip breaks, the rod pops off its connection. The handle still swings freely because it’s no longer fighting the latch — but the latch never gets the message, so the door stays shut. That “handle moves, door won’t open” feeling is the classic symptom.
Known OEM GM Door Clip / Rod Clip Part Numbers
Here’s where honesty matters more than a long list. Below are real GM and aftermarket numbers, split by how well we can confirm them. The only one confirmed straight off a GM Genuine package (from the photo that prompted this article) is 15053341. The others are genuine GM catalog parts or community-reported numbers — useful leads, but you must match them to your specific door before ordering.
Part NumberDescriptionLocation / UseConfirmed StatusNotes
15053341GM Genuine Guide, Front Side Door Locking Rod / door handle rod guideFront side door locking/handle rod guide✅ Confirmed from GM Genuine package photo + GM catalogSupersedes older number 15592648. Cataloged for 1985–2007 GM. Verify exact OBS/GMT400 fit by VIN and door position.
84244710GM Genuine Front Side Door Outside Handle Rod ClipOutside (exterior) handle rod⚠️ GM catalog part — verify fitmentGM catalog fitment shows Express/Savana vans; confirm it matches your OBS door before ordering.
16606936 (cross-ref 16633853)GM Genuine door lock rod clip, ~10mm head, fits 5/32″ (4mm) rodLock/linkage rod⚠️ GM catalog part — verify fitmentCommon multi-purpose GM clip. Match rod diameter and clip shape to your truck.
10399379GM Genuine Side Door Locking Rod ClipSide door locking rod⚠️ GM catalog part — verify fitmentConfirm year/model/door before ordering.
15958253GM Genuine door lock rod clipLock rod⚠️ GM catalog part — verify fitmentConfirm year/model/door before ordering.
25640501Retainer clip (needs ~2 per door)Door handle rod retainer🟡 Community-reported (GMT400 forum)Reported by owners, not package-verified here. Confirm before ordering.
16632192 / 16632193Door handle rod bushingsHandle rod bushing🟡 Community-reported (GMT400 forum)Bushings, not clips — listed for completeness. Verify.
Dorman assortment kits; Shark Ind. 91005 (62-pc); GM cross-refs 4234830 / 12337868Aftermarket door/lock rod clip assortmentsMixed sizes🔵 Aftermarket assortmentGood for missing clips or matching by shape/size. Quality varies.
Placeholders for future additions (update as data is confirmed): community-confirmed part numbers, dealer diagram numbers, Dorman replacement numbers, and aftermarket assortment kit numbers will be added as OBS owners verify specific year/model/door fitment and as GM parts diagrams are pulled by VIN.
OBS / GMT400 Fitment Warning
The OBS / GMT400 platform covers a lot of trucks, and GM did not use one universal rod clip across all of them. Likely candidates for the parts above include:
  • 1988–1998 Chevy C/K 1500, 2500, 3500
  • 1988–1998 GMC Sierra C/K
  • 1992–1999 Chevy Tahoe / GMC Yukon
  • 1992–1999 Chevy / GMC Suburban
  • 1999 “classic body” trucks where applicable
Do not assume one clip fits every OBS truck. Front doors and rear doors differ. Two-door and four-door cabs differ. Interior-handle, exterior-handle, lock-rod, and latch-rod clips can all be different shapes and rod diameters. A number that’s perfect for a driver’s front door on a 1996 K1500 may be wrong for the rear door of a 1997 Suburban. Match the part to your door, not to the platform in general.
Common Names People Search For
Part of why this is confusing is that everyone calls it something different. If you’ve searched any of these, you’re in the right place: OBS door rod clip, OBS door handle rod clip, Chevy door handle rod clip, GMC door handle rod retainer clip, door handle rod holder clip, door latch rod clip, lock rod clip, linkage retainer clip, front side door guide, GM door rod guide, and door handle linkage clip. They’re mostly describing the same family of small plastic retainers — the trick is figuring out which rod on which door.
Door Rod Clips vs Door Panel Clips
This deserves its own section because searching the wrong term sends you down the wrong aisle. Door panel clips are the push-in fasteners (often Christmas-tree or barrel style) that hold the interior trim panel onto the door. If your trim panel is sagging or popping off, that’s a panel clip. Door rod clips are behind the panel, holding the metal linkage rods to the handle, lock, or latch. If your handle or lock isn’t working, that’s a rod clip. Same door, completely different parts — and they’re not interchangeable.
Symptoms of a Broken Door Handle Rod Clip
You’re probably dealing with a failed rod clip if:
  • The door handle moves but the door won’t open
  • The lock knob moves loosely or flops
  • The key cylinder turns but doesn’t unlock the door
  • The exterior handle does nothing
  • The interior handle does nothing
  • A rod is hanging loose or rattling inside the door
  • You can see a clip that’s cracked, brittle, or missing entirely
Any one of these points at the linkage, not the latch itself. Before you condemn (or buy) a whole latch or handle, pull the panel and look at the clips.
How to Verify the Right Clip Before Buying
Five minutes of checking saves you a return. Here’s the practical order:
  1. Remove the door panel (see our door panel removal guide if you haven’t done it before).
  2. Take a clear photo of the broken clip and exactly where it sits on the rod.
  3. Identify which rod it’s for: interior handle, exterior handle, lock rod, or latch rod.
  4. Note the door: front or rear.
  5. Note the side: driver or passenger.
  6. Compare the rod diameter and the clip’s shape — a lot of GM clips look similar but fit different rod sizes.
  7. Pull up the GM parts diagram by your VIN (a dealer parts counter can do this in seconds).
  8. Cross-check the GM part number, any aftermarket number, and the physical shape before you commit.
Match all three — number, shape, and rod size — and you’ll get it right the first time.
Where to Buy OBS Door Rod Clips
  • GM dealer parts counter — best for pulling the correct number by VIN, even if you buy elsewhere.
  • eBay — strong for OEM/NOS clips that are otherwise discontinued. [Insert eBay link to GM 15053341]
  • RockAuto — good pricing on Dorman and OE-style clips. [Insert RockAuto link if available]
  • LMC Truck — OBS-specific catalog, often shows the clip in the door diagram. [Insert LMC Truck link if available]
  • Amazon — assortment kits when you need mixed sizes fast. [Insert Amazon affiliate link to door rod clip assortment]
  • Dorman assortment kits — a box of common GM clip styles; great insurance.
  • Salvage yards — free-to-cheap donor clips, though old plastic may be just as brittle as yours.
Some links above are affiliate links; buying through them supports FullSizeChevy at no extra cost to you.
Should You Buy OEM or Aftermarket?
Both have a place. OEM / NOS is best when exact fitment matters — a specific handle-to-latch rod on a specific door, where shape and rod size have to be dead-on. Aftermarket assortment kits are best when the original clip is long gone and you need to match by size and shape rather than by part number. The catch with cheap clips is that some are brittle or fit loosely, which just puts you back where you started. Whichever way you go, buy extras. These clips cost almost nothing, the plastic gets brittle with age, and you will inevitably launch one across the garage while you’re working.
The Bottom Line
An OBS door rod clip is one of the cheapest parts on the truck and one of the most satisfying to fix — a two-dollar clip turns a dead door handle back into a working one in minutes. The only real work is identification: confirm which rod, which door, and which side, then match the part number to the physical clip. Start with the one number we can confirm off the package, GM 15053341, use the table above as leads for the rest, and verify by VIN before you order. Got a confirmed number for your year and door? Drop it in the FullSizeChevy forum thread on door handle rod clips so we can keep building out the list.
Frequently Asked Questions
What is an OBS door rod clip?
It’s a small plastic retainer inside the door of an OBS (Old Body Style) Chevy or GMC truck that holds a metal linkage rod onto the handle, lock, or latch. When you pull the handle, the clip keeps the rod attached so the latch releases. If the clip breaks, the rod pops off and the handle moves without opening the door. They’re cheap, but you have to match the right one to the right rod and door.
What is GM part number 15053341?
15053341 is a GM Genuine part labeled Guide, Front Side Door Locking Rod — essentially a front side door handle/lock rod guide clip. It’s the number confirmed off the GM Genuine package in this article and supersedes older number 15592648. GM catalogs it broadly for 1985–2007 vehicles, so it’s a strong lead for OBS trucks, but you should verify exact fitment by VIN, door, and side before ordering.
Are door rod clips the same as door panel clips?
No. Door panel clips are the push-in fasteners that hold the interior trim panel to the door skin. Door rod clips live behind the panel and hold the metal linkage rods to the handle, lock, and latch. They look different, install differently, and do completely different jobs. If your handle or lock isn’t working, you need a rod clip — not a panel clip.
Why does my OBS Chevy door handle move but not open?
Almost always a broken or missing door handle rod clip. The clip has let go of the rod that connects the handle to the latch, so the handle swings freely but no longer pulls anything. The latch never releases and the door stays shut. Pull the door panel and inspect the rods and clips before replacing the latch or handle — the fix is usually a two-dollar clip.
Do all OBS Chevy trucks use the same door handle rod clips?
No. Front and rear doors differ, two-door and four-door cabs differ, and interior-handle, exterior-handle, lock-rod, and latch-rod clips can all use different shapes and rod sizes. A clip that fits a driver’s front door on one truck may be wrong for a rear door or the other side. Always verify by VIN, door position, cab style, and left/right side.
Can I reuse old door rod clips?
Sometimes — if the clip is intact and the plastic isn’t cracked or brittle. On trucks this age, the plastic is usually compromised, so reusing an old clip often means doing the job twice. If you already have the panel off, replace any clip that looks questionable. They cost almost nothing, so it’s cheap insurance to swap them while you’re in there.
Where can I buy OEM OBS door handle rod clips?
Start at a GM dealer parts counter to pull the correct number by VIN. For discontinued clips, eBay is strong for OEM/NOS. RockAuto and LMC Truck carry OE-style and Dorman clips, and Amazon assortment kits are handy when you need mixed sizes fast. Salvage yards work too, though donor plastic may be just as brittle. Buy a few extras whichever route you choose.
What should I search for if I cannot find the part?
Try the other names for it: door handle rod clip, door latch rod clip, lock rod clip, rod retainer clip, door handle rod guide, or “front side door guide.” Search the GM number (like 15053341) plus your year and model. If that fails, search for a “GM door rod clip assortment” and match by rod diameter and clip shape rather than by exact number — assortment kits cover most OBS rod sizes.
Fitment disclaimer: Part numbers in this article are provided as research leads. Only 15053341 is confirmed from GM Genuine packaging; other numbers are GM catalog or community-reported and may apply to different doors, sides, cab styles, or model years. Always verify by VIN, door position, cab style, and left/right side before ordering.
Open the OBS / GMT400 Forum →
