How to Install a Double DIN in a 99–02 GMT800 (Silverado, Sierra, Tahoe, Suburban, Yukon)
If you’re still running the factory 1.5-DIN radio in a 1999–2002 GMT800, a double-DIN swap is one of the cleanest interior upgrades on the truck — CarPlay/Android Auto, Bluetooth, navigation, and a backup camera without butchering the dash. But it is not a plug-and-play swap. Here’s how to do it the right way, and the one dash cut nobody warns you about.
Heads up: some of the part links below are affiliate links. They cost you nothing extra and help keep FullSizeChevy running.
99-02 GMT800 double DIN swap with a Kenwood DMX709S head unit and DNA Motoring bezel installed in the dash
Watch: 99–02 GMT800 Double DIN Install
Which trucks this covers
1999–2002 Chevrolet Silverado and GMC Sierra, plus the Tahoe, Suburban, Yukon, Yukon XL, Avalanche, and Escalade on the same early GMT800 dash. 2003–2006 GMT800 trucks are different — see the note at the end.
Why it’s not a direct swap
The 1999–2002 trucks came with a 1.5-DIN (“DIN-and-a-half”) opening — bigger than the GMT400 single-DIN, but still not a true double-DIN.
Factory 1.5 DIN dash on a 1999-2002 GMT800 Chevy Silverado before the double DIN swap
The 2003–2006 refresh did get a factory double-DIN, but the dash layout changed and the HVAC controls sit lower on the 99–02 trucks. A 03–06 bezel will not line up on a 99–02 dash without relocating the HVAC controls — don’t go down that road. Use a proper 99–02 double-DIN conversion bezel instead.
What you need
  • A double-DIN dash bezel made for 99–02 GM trucks. The Metra and DNA Motoring kits both fit. A black textured bezel matches the factory switch/HVAC panel best; if the shade is off, it preps and paints well with SEM interior products (a shot of 303 Protectant afterward helps keep the finish from fading).
  • A quality double-DIN head unit — I’ve run the Kenwood DMX709S.
  • A GM radio wiring harness adapter — the Metra 70-2001 fits 94–04 GM, so you plug into the factory connector instead of cutting it.
  • The factory head-unit mounting brackets (or replacements — Metra still makes them).
  • An antenna adapter (Metra 40-GM10) if you’re keeping factory AM/FM.
  • Reuse your OEM bezel clips. Aftermarket clips are flimsy and won’t hold tight — you can feel the difference.
Metra double DIN dash kit for 1999-2002 GM full-size trucks and SUVs in matte black
DNA Motoring black double DIN dash bezel for 99-02 Silverado Suburban Tahoe Sierra Yukon Escalade
GMT800 factory dash bezel clips compared to flimsy aftermarket clips
The dash cut nobody warns you about
Behind the radio opening there’s a plastic tab that will stop a double-DIN from seating. Without trimming it, the new unit won’t drop into the dash. Cut the tab flush with the dash using a Dremel, oscillating tool, or rotary tool. Move any wiring out of the way first, go slow for a clean cut, and vacuum the dust as you go so it doesn’t fall into the vents.
Plastic tab above the stereo opening on a GMT800 dash that must be cut for a double DIN to fit
Trimming the GMT800 dash tab flush with an oscillating tool for double DIN clearance
Wiring
Use the harness adapter — do not cut the factory harness. Crimp the adapter to the head-unit leads (butt connectors work; solder and heat-shrink is stronger), matching the GM radio color code. If you’re keeping the factory antenna, add the antenna adapter. Retaining the factory wiring keeps the install clean and reversible.
GMT800 factory radio harness and stereo wiring left after removing the 1.5 DIN radio
Metra 70-2001 radio wiring harness adapter for GM 94-04
GM radio wiring color code chart for 1998-2002 GMT800 and GMT400 stereo install
Install, start to finish
  1. Remove the factory 1.5-DIN radio.
  2. Trim the plastic tab flush as above.
  3. Wire the head unit through the harness adapter.
  4. Bolt the factory (or replacement) slide-in brackets to the new deck and set it at the correct height.
  5. Guide the wiring behind the deck, install the new bezel, and seat it with the OEM clips.
Finished double DIN install in a 99-02 GMT800 dash with a factory-clean OEM look
Done right, you get a full double-DIN that looks like it came from the factory — and you’re set up for front and rear cameras.
If you have an 03–06
Those trucks are already double-DIN. You’ll typically just trim a bit of the upper dash bezel for fitment — no conversion bezel needed.
Doing this swap on your GMT800? Post your year, bezel brand, and head unit in the FullSizeChevy forum — pictures help the next person.
Talk GMT800 with other owners
Open the GMT800 Forum →
