GMT400 Interior Swap Guide for OBS Builds
A clean GMT400 interior swap can change the whole truck faster than almost any exterior mod. You can have fresh paint and good wheels, but if the seat foam is dead, the dash is cracked, and every plastic panel rattles, the truck still feels tired. Get the inside right, and even a rough old OBS starts feeling like something you want to drive every day. Mint OBS interiors just hit different, which is why you’ve likely landed on this page.
That is why interior swaps are so common in the GMT400 world. The trucks are simple, parts are still out there, and GM gave us enough shared architecture to make a lot of combinations possible. But possible and bolt-in are not the same thing (luckily we have companies still making OBS brackets). Some swaps are easy weekend work, others turn into a wiring job, bracket job, and trim mismatch all at once. Luckily, there is a wealth of knowledge online, and tons of parts trucks out there.
What a GMT400 interior swap usually means
Most guys say “interior swap” and mean one of three things.
  • The first is a direct replacement using better factory GMT400 parts from a Escalade or Denali SUV (my favorite!).
  • The second is a factory-plus upgrade, where you keep the basic GMT400 layout but add nicer buckets, a console, upgraded door panels, or a later steering wheel.
  • The third is a cross-platform mix using parts from GMT800, vans, or other GM vehicles to modernize the cab.
For most builds, the best move is still a factory-based GMT400 interior swap. It keeps the truck looking right, saves fabrication time, and avoids the weird look that happens when one part is too modern for the rest of the cab. A loaded Escalade or Denali-style feel inside an OBS truck hits different when it still looks like GM could have built it that way.
Start with your cab and trim level
Before you buy a single seat, figure out exactly what truck you have. Regular cab, extended cab, and crew-cab SUV-based interiors all bring different challenges. Bench-seat trucks can be converted to buckets, but the floor pan, seat brackets, and console mounting points may not match what you expect. Door panel swaps can also get tricky if your truck started life with manual windows and locks.
Trim level matters too. Base work-truck interiors are usually the easiest place to start and the hardest to match. If you are swapping in nicer panels, a center console, and power accessories, the cheap part is often the donor interior itself. The expensive part is making every switch, harness, and trim piece work together without looking hacked.
If your goal is a clean OEM-style upgrade, buy the most complete donor setup you can. Seats, console, brackets, door panels, carpet sections, lower dash trims, switches, and the wiring pigtails matter. Chasing one missing bezel or one seat-side trim panel after the fact is where projects stall out.
Seats are the biggest win
If the budget is limited, start with seats. They change comfort, driving position, and overall appearance more than anything else. A worn-out bench with collapsed foam will make a good truck feel beat, while a solid set of factory buckets from a higher-trim GMT400 can make the cabin feel finished. If you are simply after seat covers and cushions to rebuild your worn out seats, I would recommend checking out  The Seat Shop.
The easiest seat upgrades are still within the GMT400 family. Tahoe, Yukon, Suburban, Silverado, Sierra, and OBS Escalade and Denali seats can work well depending on year and cab layout. If it came out of a GMT400, it will bolt in. If you choose to go with newer seats; you may need brackets from OBS Outpost. Some assemblies bolt in cleaner than others, and really it would be up to your individual preference and parts availability. If you are not sure what seat to go with – definitely check out OBS Outpost and the gallery. I think my personal favorite is the K2XX seat swap!
Power seats are worth it if you already have the wiring or do not mind adding it. If not, manual tracks are simpler and usually more reliable in an older truck. Leather looks great, but cloth often ages better in trucks that actually get used. It depends on whether you are building a cruiser, tow rig, or clean street truck.
OBS Escalade console installed in a GMT400 cab
Dash swaps can go smooth or go sideways fast
A dash replacement is common because GMT400 dashes crack. Everybody knows it. The sun gets them, the plastics get brittle, and then one day the truck has a spiderweb across the pad. This is especially true for the northern trucks. The dashes always seem to break where the heat comes out by the windshield!
A same-generation dash swap is usually straightforward if you stay close to your original year range. That said, even inside GMT400 production there were changes in airbag design, gauge cluster style, HVAC controls, and wiring. The more complete your donor dash is, the better. Pad only, full shell, and shell with harness are three very different jobs. If your HVAC knobs are cracked or faded, you do not need a full dash swap to fix it – our OBS HVAC knob swap guide covers an easy upgrade using Chevy Express and GMC Savana knobs.
If you are trying to swap in a later-style dash or mix GMT400 and GMT800 pieces, slow down and be realistic. It can be done, but now you are into custom mounts, trim gaps, steering column alignment, ducting issues, and electrical work. That kind of swap is cool when done right, but it is not the move if you just want the truck back on the road next weekend.
Console and floor shifter conversions
This is one of the most popular GMT400 interior swap goals, especially for trucks coming from a split bench or basic bench setup. A full-length center console changes the whole vibe of the cab. It gives you storage, cupholders that do not feel like an afterthought, and a more finished look. My favorite to this day would be the OBS Escalade Console, shown below. They can be hard to find nowadays; but it is possible to find complete donors.
OBS Escalade console removed from a donor vehicle
The fit depends on cab layout, seat spacing, and whether your truck is 4×4 or 2WD. 2WD is an easy fit and won’t have any clearance issues; 4×4 depends if it is electronic column-shift or floor-shift for 4×4. If you have a manual floor shift and want to put a full length console one, you can swap to a NBS (99-02) floor shift lever and plastic cover.
Console swaps also expose carpet differences. You may need to replace carpet, patch mounting areas, or deal with faded sections that were hidden for years. None of that is hard, but it is the kind of detail that separates a clean build from a thrown-together interior. Be prepared to have to clean the carpets when removing and installing a new console!
Our complete OBS Escalade swap guide can be found here, and you can watch the full Escalade console install video on our YouTube channel. If a full console swap is more than you want to tackle, our cupholder upgrade guide shows how to add cupholders to a factory 94-98 console by deleting the CD changer.
Door panels, power options, and wiring reality
Door panels make a huge visual difference, especially when your originals are warped, cracked, or missing clips. They are also where a lot of interior swap plans start to fight back. Manual and power doors are not always a simple plug-and-play swap. Switch placement, harness connectors, and door shell differences can all come into play.
If you are converting manual windows and locks to power, get everything from the donor. Regulators, lock actuators, harnesses, switches, boots, and the little hardware pieces all matter. Trying to piece together a power conversion from random parts usually costs more time than buying a complete setup from the start.
The same goes for mirrors and courtesy lighting. These are easy upgrades when you plan for them and annoying ones when you do not. While you are in there, it is also a great time to knock out an interior LED upgrade – swapping the dim factory bulbs for LEDs is cheap, easy, and makes the whole cab feel newer the second the doors open. A GMT400 interior swap done right is less about one hero part and more about collecting all the supporting parts before teardown starts.
Color matching is harder than people think
This is where a lot of otherwise solid swaps lose points. GM offered a lot of grays, blues, reds, tans, and transitional shades across the GMT400 years. Sun fade makes it even worse. What looked like a matching set in donor photos can turn into three different shades of gray in daylight.
If you care about a finished result, choose one path early. Either source a complete same-color interior, or accept that some dye work and refinishing will be part of the job. Mixing years and trims can still look great, but only if you pay attention to texture, sheen, and panel condition.
This is also why buying one clean donor truck is often smarter than buying ten separate pieces. Consistency matters inside the cab. You see it every time you drive. If you have to paint, please buy quality SEM Paints and do a good prep job.
What to inspect before you buy donor parts
Used interior parts can look fine in photos and still be junk in person. Seat foam breaks down. Leather shrinks. Plastic tabs snap. Console lids crack. Door pull handles get weak. Dash mounts split. A low-mile donor is great, but condition beats mileage if the truck sat in the sun for twenty years.
Look closely at mounting points, not just visible surfaces. Check seat tracks for smooth travel, inspect harness connectors for cut wires, and look under carpet for moisture or rust smell. If you are buying from a parted-out SUV, remember that rear-seat family use can beat up an interior differently than a regular-cab pickup. Wear patterns tell the real story.
The smartest way to plan the swap
Treat the project like a system, not a pile of parts. Decide whether you are chasing restoration, comfort, OEM-plus style, or a custom show-truck look. Once that is clear, the right parts list gets easier.
A practical build usually wins. Good seats, solid door panels, an uncracked dash, fresh carpet, and a clean console will transform the truck more than a complicated cross-platform experiment. Save the one-off fabrication for builds where custom is the whole point.
And document what you pull, label every connector, and bag your hardware. It sounds basic, but it saves hours. Truck guys know this already, yet every one of us has lost time hunting for one bracket we swore we set somewhere safe.
A GMT400 interior swap is one of the best upgrades you can make because it changes how the truck feels every mile, not just how it looks in photos. Build it with the same care you give the body and drivetrain, and the whole truck starts feeling worth keeping around for the long haul.
Shop FullSizeChevy Gear →
Open the OBS / GMT400 Forum →
FullSizeChevy Red Truck Sun Shade | FSC Windshield Sunshade for Chevy Trucks | Interior Heat Protection$49.86
FullSizeChevy Truck Sun Shade | FSC Windshield Sunshade for Chevy Trucks | Interior Heat Protection$49.86
OBS or DIE Poster | 1988–1998 Chevy Silverado GMT400 Truck Garage Wall Art | OBS Truck Enthusiast Decor Price range: $34.18 through $112.27
OBS GMT400 Chevy Truck T-Shirt – 2-Tone Retro (1988-1998 Silverado) | FSC Retro Price range: $28.86 through $35.61
OBS GMT400 Chevy Truck T-Shirt – Green Sunset Neon Skyline (1988-1998 Silverado) | OBS Legends Price range: $28.86 through $35.61
FullSizeChevy GMT400 Lowered OBS Wall Flag – Blacked Out Street Build Price range: $25.70 through $51.41
OBS GMT400 Chevy Truck T-Shirt – Green Neon City Sunset (1988-1998 Silverado) | OBS Legends Price range: $28.86 through $35.61
OBS GMT400 Chevy Truck T-Shirt – Black Desert Road Sunset (1988-1998 Silverado) | OBS Legends Price range: $28.86 through $35.61
OBS GMT400 Chevy Truck T-Shirt – Black Neon (1988-1998 Silverado) | OBS Legends Price range: $28.86 through $35.61
OBS GMT400 Chevy Truck Trucker Cap – Keep It Full Size, Embroidered (1988-1998 Silverado) | Keep It Full Size$31.52
OBS GMT400 Chevy Truck T-Shirt – Teal Sunset (1988-1998 Silverado) | GMT400 Crew Price range: $28.86 through $35.61
OBS or Die | OBS Coffee Mug — Classic Chevy Truck Lover Gift (11/15oz) Price range: $10.70 through $14.14
