GM Transfer Case Pump Rub: The $100 Fix That Saves a $1,500 Case (1998–2007)
Opened NP246 transfer case rear half showing pump rub wear ring
There’s a failure on 1998–2007 GM 4×4 trucks and SUVs that ruins transfer cases quietly, from the inside: pump rub. The internal oil pump slowly wears a hole through the rear case half, the fluid escapes, and by the time most owners notice the leak, the case — and often what’s inside it — is done. A $1,000–2,000 repair, caused by a design quirk a roughly $100 kit prevents.
If you own a 4WD GMT800 (or an early GMT900 with the carryover case), this is one of the highest-value preventive jobs on the truck, and it piggybacks on a fluid change you should be doing anyway.
Quick Answer
  • What happens: the aluminum oil pump assembly vibrates against the magnesium rear case half and slowly wears through it. Fluid leaks out; the case is scrap.
  • Affected: 1998–2007 GM trucks/SUVs with New Process/New Venture cases — the auto-shift NP246 (Auto Trac) is the famous one; related NP cases of the era share the weakness.
  • Not affected: mid-2007+ GMT900 trucks with BorgWarner transfer cases — GM changed suppliers and this failure went away.
  • The fix: a pump housing brace / “pump rub” saver kit that stops the pump from working against the case, installed while the case is open for a fluid service.
  • The factory anti-rattle clip is not enough — it wears or breaks, which is how the problem got its reputation.
Trucks and Years Affected
  • 1999–2006 (+2007 Classic) Silverado, Sierra, Tahoe, Suburban, Yukon, Avalanche 4WD — GMT800, NP-series cases
  • 1998 GMT400 4WD trucks with the same era NP cases
  • Early GMT900 units built with carryover NP cases; 2007.5+ BorgWarner-equipped GMT900s are exempt
  • Push-button Auto Trac (NP246) trucks are the classic pump-rub story; if your 4WD is the floor-shift manual-lever setup, you have a related NP case — the wear mechanism family is the same, so inspection is still worth it
Not sure which case you have? The transfer case has an ID tag on the rear half. Check it before ordering a kit — kits are case-specific.
Symptoms Owners Notice
  • Usually nothing until it’s too late — that’s the trap. The wear happens inside, out of sight.
  • Fluid seeping or dripping from the rear of the transfer case (often mistaken for a seal leak)
  • A wet rear case half with no obvious seal source
  • Whine, bind, or 4WD faults after fluid loss — by this stage damage is usually done
Why It Happens
The oil pump rides on the mainshaft inside the rear case half. The pump housing is aluminum; the case is magnesium — softer. Normal driveline vibration works the pump against the case wall in the same spot, year after year. GM’s countermeasure was a small spring-steel anti-rattle clip on the pump, but the clip itself wears or breaks, and the pump goes back to machining its way through the case. High-mileage highway trucks — constant RPM, constant vibration frequency — are heavily represented in the failure stories owners have collected.
How to Check Yours
  1. Look first. Crawl under with a light and inspect the rear case half around the output area. Wetness, a worn shiny ring visible through thin metal, or an actual weep hole = stop driving it and plan the repair.
  2. Check fluid condition and level. Dark, glittery, or low fluid in a case that’s supposedly sealed is a warning. The NP246 takes GM Auto-Trak II fluid — if what drains out doesn’t look like what went in, investigate.
  3. Open it during a fluid service. The definitive check is eyes-on with the rear case half off: you’ll see the wear pattern where the pump contacts the case, from barely-marked to nearly-through.
  4. Mileage guidance from owner-collected reports: trucks have holed cases anywhere from around 100K to never. There’s no safe threshold — which is why the cheap preventive fix exists.
The Fix: Pump Brace / Saver Kits
  • What they do: brace or replace the pump housing contact points so the pump can no longer work against the magnesium case. Well-known options include the Merchant Automotive pump upgrade kit and Adapt-A-Case-style saver plates.
  • When to install: during a transfer case fluid change, with the rear case half opened — the kit adds modest parts cost and some labor to a service you should be doing anyway.
  • If the case is already worn but not holed: installing a kit stops further wear. Some plates are designed to cover/reinforce a case that’s thin but intact — read the kit maker’s guidance for how much wear is too much.
  • If it’s already holed: you’re shopping for a case half or a replacement case, then installing a kit in the replacement so it never happens again. Some owners have JB-Weld stories on small holes; treat those as get-home fixes, not repairs.
  • Refill with the correct fluid — Auto-Trak II for the NP246. Wrong fluid in an Auto Trac case causes its own problems.
Parts and Tools
  • Pump rub kit matched to your case’s ID tag
  • Correct fluid (Auto-Trak II for NP246; verify for your case)
  • Drain pan, RTV or gasket per kit instructions, torque wrench, hand tools
  • Transmission jack (or a helper) if you drop the case rather than working in place — most DIYers find the job an afternoon with the case out
Common Mistakes
  • Assuming a rear leak is “just a seal” on these cases. Check the case wall before you throw a seal at a pump-rub hole.
  • Skipping the kit during a fluid change on an affected case — the case is open anyway; that’s the cheap moment.
  • Wrong fluid in an Auto Trac case. The NP246 wants Auto-Trak II, not generic ATF.
  • Buying a used case and installing it bare. The used case has the same design; brace it before it goes in.
  • Panicking a BorgWarner-era GMT900 owner. Mid-2007+ BW cases don’t have this failure — know which case you have before spending anything.
When to Stop and Diagnose Further
If the case is already low on fluid and making noise or binding in 4WD, don’t just patch and refill — internal components may already be damaged, and a braced case full of debris is still a failing case. That’s the point to open it fully, inspect the chain, pump and bearings, and price a rebuild versus a replacement honestly.
FAQ
What is transfer case pump rub?
On 1998–2007 GM NP-series transfer cases, the aluminum internal oil pump vibrates against the softer magnesium rear case half and slowly wears a hole through it. The fluid escapes and the case is ruined.
Which trucks have transfer case pump rub?
1998–2007 GM 4×4 trucks and SUVs with New Process/New Venture cases — the NP246 Auto Trac is the best-known. Mid-2007+ GMT900s with BorgWarner cases are not affected.
How much does the pump rub fix cost?
Kits generally run in the $60–150 range plus fluid. A holed case means a used or rebuilt case at $1,000–2,000+ installed. That’s the whole argument for doing it preventively.
Can I drive with pump rub?
Until the wear becomes a hole, you won’t know anything is wrong — that’s the danger. Once fluid is leaking from the case wall, every mile risks running the case dry.
What fluid does the NP246 transfer case take?
GM specifies Auto-Trak II fluid for the NP246 Auto Trac case. Don’t substitute generic ATF.
Stop pump rub before it starts
Pump rub is the rare failure you can completely design out of your truck for about $100 and an afternoon: open the case at fluid-change time, look at the wear, install a brace kit, refill with the right fluid, done for the life of the truck. If you own a 99–07 GM 4×4 with an NP case and you don’t know what your pump contact area looks like, put it on the list.
Related drivetrain guides: Chevy 4WD not engaging (encoder motor and TCCM), 4L60E common problems, and the GMT800 owner’s hub.
Opened your case — caught it early, or found the hole? Post your case ID, mileage, and photos of the wear in the FullSizeChevy forum.
Talk GMT800 with other owners
Open the GMT800 Forum →
