5 Upgrades That Make Your Full-Size Chevy Feel Tight, Clean, and Finished (Squarebody to GMT900)
Steering slop, rattles, and sloppy pedal feel are the silent killers of any FullSizeChevy build. You’ve got a Squarebody, GMT400, or GMT900 rig that’s solid, but it just doesn’t feel locked in. Fixing that takes more than just guessing—these five upgrades tighten steering, silence noise, sharpen pedal feel, and clean up every creak. Ready to tighten yours up? Hit forum.fullsizechevy.com. Search “Tighten-Up Checklist” and drop your year/trim. We’ll post exact part numbers, torque specs, and alignment targets for your platform. Start a build thread, post pics, and we’ll help you dial it in step by step.
Steering Refresh and Upgrades
Getting your steering right is the first step to a better driving experience. Steering slop can make your truck feel like a boat in rough waters. Let’s dive into how you can change that.
Tackle Steering Slop
You’ve probably felt it: that loose steering that makes you second-guess your alignment. The good news? You can tackle this. Start with your idler arm and pitman arm. These parts often wear out and cause play in your steering. Replace them with high-quality options like the Moog Problem Solver series. Also, don’t overlook the tie rod ends and center link. These parts ensure that your steering inputs translate directly to your wheels. If you’ve done all this and still feel the slop, consider adding an idler arm support bracket. It’s an extra step, but it makes a noticeable difference.
Intermediate Shaft and Rag Joint Delete
The intermediate shaft and rag joint can be weak links. The rag joint, in particular, can degrade over time, leading to more play. Swap it out for a rag joint delete kit. This upgrade replaces the rubber joint with a solid connection, giving you more precise steering. It’s a small change with significant benefits. While you’re at it, check out the intermediate steering shaft. If it’s worn, it might be time for an upgrade. A new shaft can reduce vibrations and improve feedback. Your truck will feel more responsive, making every drive more enjoyable.
Borgeson and Jeep XJ Shaft Swap
For those looking for a top-tier upgrade, consider the Borgeson steering shaft. It’s a direct fit for most models and offers a major improvement in steering feel. Think of it as setting your steering on rails. If you’re on a budget, the Jeep XJ shaft swap is a great alternative. It’s a popular mod among truck enthusiasts for a reason: it’s cost-effective and delivers tangible results. Once installed, you’ll notice tighter steering and reduced play. It’s one of those upgrades that will have you wondering why you didn’t do it sooner.
Tighten Up Your Ride
tight chassis
With your steering sorted, it’s time to focus on the rest of the ride. A tight chassis makes for a better driving experience and cuts down on those annoying rattles and squeaks.
Body and Cab Mount Solutions
Body mounts are critical to how your truck feels on the road. Over time, the factory mounts can degrade and cause your truck to feel loose. Swapping them for polyurethane bushings is a game-changer. They offer better durability and a firmer ride. You’ll feel a noticeable improvement in how your truck handles. Pay attention to cab mounts and bed mounts as well. These are often overlooked but can make a big difference in ride quality. If you’re serious about getting the most out of your truck, these upgrades can set the foundation for everything else.
Door Hinges and Strikers
Ever notice how your doors sag or misalign over time? The culprit is often worn door hinges and strikers. Replacing the door hinge pins and door strikers can bring your doors back to factory alignment. It’s not just about looks; proper alignment reduces wind noise and prevents water leaks. This is an easy fix with a significant payoff. You’ll appreciate the solid feel every time you open and close your doors. It’s one of those small details that add up to a more refined driving experience.
Sound Deadening and Sealing
Interior noise can turn a pleasant drive into a headache. Adding sound deadening is a straightforward way to improve your cabin’s acoustics. Products like Kilmat or Dynamat can make a world of difference. Apply them to the floor, doors, and roof. You’ll notice reduced road noise and a more comfortable cabin. Don’t forget about sealing: check your weatherstripping and window sweeps for wear. Replacing them can prevent leaks and further cut down on noise. Your truck will feel quieter, more insulated, and downright luxurious compared to stock.
Brake System Overhaul
Now let’s move on to the brakes. Firming up your pedal feel can give you the confidence you need when stopping your rig.
Firm Up Pedal Feel
If your brakes feel mushy or unresponsive, it’s time for a change. Start by replacing your brake lines with stainless steel options. They don’t flex under pressure, giving you a firmer pedal feel. Consider doing a bench bleed to remove any air in the system. It’s a simple procedure that can drastically improve your brakes’ performance. You’ll notice that your pedal feels more responsive, and your truck stops more predictably.
Hydroboost and Stainless Lines
For those looking to go further, a hydroboost swap is worth the investment. This system uses your power steering pump for brake assistance, offering better stopping power than the traditional vacuum booster. Pair this with stainless steel brake lines, and you’ll have a setup that can handle more demanding conditions. The difference is night and day. It’s one of those upgrades that pays off every time you hit the brakes, especially in an emergency stop.
Rear Drum Self-Adjusters
Don’t neglect the rear brakes. If your truck still runs rear drum brakes, make sure the self-adjusters are working correctly. Worn or faulty adjusters can cause uneven braking and longer stopping distances. New adjusters ensure your rear brakes stay properly aligned and effective. It’s a simple, cost-effective upgrade that can improve overall braking performance. Once everything is dialed in, you’ll have a system that responds predictably and confidently.
By tackling these key areas, you can transform your FullSizeChevy into a rig that feels tight, clean, and finished. Whether you’re driving around town or hitting the trails, these upgrades ensure your truck handles whatever you throw its way. Remember, the community at forum.fullsizechevy.com is there to help with detailed guides and expert advice. Dive into a build thread, share your progress, and learn from the collective wisdom of fellow truck enthusiasts.
Join the Forum
If you sweat the details on your GMT800/GMT900, you'll like the gear. Built for Silverado, Sierra, Tahoe, Suburban, and Yukon owners who actually do the work.
Shop FullSizeChevy Gear →
Talk GMT900 with other owners
Post your truck, your build, or the problem you are chasing. Real GMT900 owners in the FSC forum will tell you what actually worked on theirs.
Open the GMT900 Forum →
Find every repair, buying, maintenance, and troubleshooting guide in the GMT900 Owner’s Hub.
