This is a real-world exhaust sound clip and full setup breakdown from a 2007 Chevy Avalanche 5.3L Vortec (GMT900). No studio mic, no edited rev clip — just the truck running with a MagnaFlow 5×8 oval, 14-inch body muffler (PN 12219) behind stock manifolds and gutted cats. If you are trying to figure out what a 5.3 actually sounds like with a single 14-inch MagnaFlow before you spend money, start here.
Watch the clip first, then read the setup below it.
If you want the short answer, this setup lands right in the middle — more truck than stock, but still livable every day.
Louder than stock, but not a headache
Deeper tone — the gutted cats and 14-inch body drop it down
Cleaner than a straight pipe — there is still a muffler doing real work
Not obnoxious at cruise or in a parking lot
Better for a daily driver than a loud glasspack or open exhaust
A solid middle-ground setup if you are not chasing the loudest possible truck
Full Setup Breakdown
Why the stock manifolds matter
This truck still runs the factory cast manifolds, not long-tube or shorty headers. That is a big reason the tone stays controlled instead of getting raspy. Cast manifolds flow less and hold sound back compared to headers, so the exhaust note coming out the back is deeper and rounder. If you want a daily-driver sound, leaving the manifolds alone is the easy way to keep it from getting tinny.
What gutted cats do to the sound
The catalytic converters on this truck are gutted — the internal substrate is removed but the cat bodies stay in the pipe. That opens things up and lets more of the real engine note through, which is where most of the added depth and volume come from on this setup. Note that gutting cats is an emissions modification — see the warning further down before you copy it.
Why the MagnaFlow 5×8 keeps the tone controlled
The MagnaFlow 12219 is a 5×8 oval body, 14-inch long straight-through case. The larger oval body and the 14-inch length give the sound somewhere to settle, so it stays deeper and more controlled instead of loud and droney. A smaller or shorter muffler would let more noise through. This is the part doing the most work to keep the truck daily-friendly.
Why the factory pipe was adapted to a 3-inch muffler
The factory piping on this truck is roughly 2.75 inches, and the MagnaFlow 12219 is a 3-inch center/center muffler. To bolt the two together cleanly, the setup uses 2.75-inch to 3-inch adapters. This is a fitment step, not a power step — the adapters just let the larger muffler mate to the smaller factory pipe without hacking the system apart.
What the 4-inch rolled tip actually changes
The 4-inch rolled rear tip is mostly about exit style and appearance. A bigger tip can soften the edge of the sound slightly and fill out the exhaust opening visually, but it is not the main reason this truck sounds the way it does. The muffler, the gutted cats, and the manifolds drive the tone. The tip is the finishing touch.
MagnaFlow 5×8 vs 4×9 vs 4-Inch Round: Which Should You Run?
The muffler is where you actually choose how loud and how aggressive the truck gets. Here is how the three common choices compare for a 5.3.
MagnaFlow 5×8 Oval
Best daily-driver choice
Controlled tone, deeper than stock, not obnoxious. The most livable of the three and the least likely to get annoying on a long drive or at idle in traffic. This is what is on the truck in the clip.
4×9 Oval Muffler
Louder middle-ground choice
More volume than the 5×8 but still a real muffler, so it stays muffled rather than open. Good pick if you want noticeably more sound without going all the way to a glasspack.
4-Inch Round / Glasspack-Style
Aggressive choice
Louder and sharper, with more cold-start bark. Also the most likely to drone on the highway. Pick this only if you actually want the loud, raspier setup and can live with the cruise noise.
Downstream O2 Non-Foulers: Where They Go (and Where They Don’t)
With the cats gutted, this setup uses spark plug non-foulers on the downstream/post-cat O2 sensors only to move those sensors out of the direct exhaust stream. The rules that matter:
Non-foulers go on downstream/post-cat O2 sensors only.
Do not install them on the upstream/pre-cat sensors.
The upstream sensors are used for fueling — the PCM reads them to trim the air/fuel mixture, so they need to see real exhaust.
The downstream sensors monitor catalyst efficiency, which is what you are addressing after gutting the cats.
Emissions warning: Gutted cats and O2 sensor modifications may not be legal for road use in your area. Check local laws before copying this setup.
Parts Used in This Setup
These are the parts on the truck in the clip. Pick OEM-equivalent or quality exhaust components — cheap mufflers and adapters are where this kind of setup usually goes wrong.
Some links may be affiliate links. If you buy through them, FullSizeChevy.com may earn a small commission at no extra cost to you.
Running a Different Exhaust? Post Your Setup
Running a different muffler on your 5.3, 4.8, 6.0, or 8.1? Post your setup in the FSC forum thread. Include your truck, engine, muffler, pipe size, cats/no cats, single or dual exit, and whether it drones.
