What Does AG2 Mean? The Power Passenger Seat
Front passenger seat of a Chevrolet truck showing the adjuster switch on the outboard side of the cushion
AG2 is the RPO code for the power front passenger seat adjuster.
If you are reading a label and trying to work out which seat moves under power, AG2 is the passenger side and AG1 is the driver’s. That is the whole distinction, and it is worth being certain about before you buy a seat or a switch.
Where AG2 is documented
1997 “Adjuster, passenger seat, power, multi-directional” GM VPPS option master
2007 “Passenger Power Seat” 2007 Electrical Utilities / SUV body builder manual, RPO list
2019 “Seat adjuster, front passenger 6-way power” — unverified, see below Single uncorroborated source
We also hold an undated GM master entry describing AG2 as a “6-way power adjuster, split bench, passenger”, which lines up with the 2019 wording.
Honest limits on this one
AG2 is a thinner code than AG1 in our records, and we are going to say so rather than pad it out.
We checked GM’s 2015, 2016, 2017 and 2018 Silverado specification guides for AG2. It does not appear with a description in any of them — only as a bare code in a Service Parts Identification list. So for that whole span of trucks we can tell you the code existed on labels and nothing more than that from GM’s own pages.
The 2019 entry is unverified in our database — it comes from a source we have not been able to corroborate against a second GM document. Treat the “6-way” detail as probable rather than established. The 1997 and 2007 wordings are the ones we can stand behind.
What is solid across every record we hold: AG2 is a powered front passenger seat adjuster, and it has meant that consistently since at least 1997.
What AG2 rules out
  • It does not mean the driver’s seat is powered. That is AG1, and the two are independent.
  • It does not mean heated. Heat is a separate code.
  • It does not tell you the seat type. A powered passenger adjuster appears on both bench and bucket configurations depending on the truck.
How to check yours
  1. Decode AG2 for your model year, and run the whole label so you see whether AG1 is there as well.
  2. Find the Service Parts Identification label — usually inside the glove box lid, or in the centre console or driver’s door jamb on 2007 and later trucks.
  3. Check the passenger cushion for a switch pack on its outboard side. A manual passenger seat has a lever or bar instead.
  • 2007 Chevrolet / GMC Electrical Utilities and SUV body builder manual, Regular Production Option list
