What Does AG1 Mean? The Power Driver Seat
Power seat adjuster switch pack on the side of a Chevrolet truck driver's seat base
AG1 is the RPO code for the power driver seat adjuster.
It is the code that tells you the driver’s seat moves on a motor rather than on a lever and a slide rail. It says nothing about the passenger side — that is AG2, and the two get confused constantly because they sit next to each other on a label and differ by one character.
Where AG1 is documented
1997 “Adjuster, front seat, power, multi-directional, driver” GM VPPS option master
2007 “Driver Power Seat” 2007 Electrical Utilities / SUV body builder manual, RPO list
2015 “(AG1) driver 10-way power seat-adjuster with power lumbar” 2015 Silverado 1500 Special Service 5W4 specification guide
2016 “AG1 SEAT ADJUSTER, Driver 10-way power, Included and only available with (AZ3) front 40/20/40 split-bench cloth seat” 2016 Silverado 1500 Special Service 5W4 specification guide
2017 “AG1 SEAT ADJUSTER, Driver 10-way power, Included and only available with (AZ3)…” 2017 Silverado 1500 Special Service 5W4 specification guide
2018 “AG1 SEAT ADJUSTER, Driver 10-way power, Included and only available with (AZ3)…” 2018 Silverado Special Service specification guide
The wording moves from “multi-directional” in the nineties to a specific 10-way in the later trucks. That is not GM being vague early on — the hardware genuinely gained axes of movement over twenty years. A 1997 AG1 seat and a 2018 AG1 seat are both powered and are not the same part.
AG1 is not an option you add — it comes with a specific seat
This is the most useful thing on this page, and it is easy to get backwards.
On the 2015–2018 trucks, GM does not sell AG1 as an upgrade you bolt onto whatever seat you have. Its own guides say AG1 is “included and only available with (AZ3) front 40/20/40 split-bench cloth seat”. AZ3 is the cloth bench with the power driver seat; AG1 is the adjuster that comes inside it.
Two things follow:
  • If the label has AE7 — the manual bench — it does not have AG1, and the factory did not offer one on that seat.
  • If you are hunting a donor seat, AZ3 is the code to search for, not AG1. GM also ties it to trim: “Requires (H2R) Dark Ash or (H0U) Jet Black seat trim.”
One place GM contradicts itself
Worth knowing before you order parts. In the 2017 and 2018 guides the AG1 line says driver 10-way power — but the AZ3 description a page earlier in the same document says AZ3 “Includes 6-way power driver and 2 way front passenger seat adjuster”. The 2015 and 2016 guides say 10-way with power lumbar in both places.
We are not going to guess which one is right. If the number of ways matters for what you are buying, count the switch positions on the actual seat rather than trusting either line.
What AG1 rules out
  • It does not mean both seats are powered. Driver only. For the passenger seat the label needs AG2 as well.
  • It does not mean heated. Heat is a separate code.
How to check yours
  1. Decode AG1 for your model year, and run the whole label so you see whether AZ3 and AG2 are there too.
  2. Find the Service Parts Identification label — usually inside the glove box lid, or in the centre console or driver’s door jamb on 2007 and later trucks.
  3. Check the seat base. A powered driver’s seat has a switch pack on the outboard side of the cushion; a manual one has a bar under the front edge.
  • 2007 Chevrolet / GMC Electrical Utilities and SUV body builder manual, Regular Production Option list
  • 2015, 2016, 2017 Chevrolet Silverado 1500 Special Service (5W4) specification guides, GM Upfitter
  • 2018 Chevrolet Silverado Special Service specification guide, GM Upfitter
