AE7 is the RPO code for GM’s front 40/20/40 split bench seat — the three-across bench with a fold-down centre section, adjusted by hand rather than by a motor.
It is one of the steadier codes GM uses. We hold records for it from 1991 through 2022, and across that span the hardware it names has not changed: a split bench, 40% driver side, 20% centre, 40% passenger side, manual. GM’s 2015 specification guide puts it bluntly — the AE7 seats are manual and power is not available on them.
Where AE7 is documented
| Year | How GM described it | Source |
| 1991 | “Seat, front split, driver, passenger” | GM VPPS option master |
| 2015 | “Front 40/20/40 Split-Bench 3-passenger… Seats are manual (power not available)” | 2015 Silverado 1500 Special Service 5W4 specification guide |
| 2016 | “Front 40/20/40 Split-Bench 3-passenger. Driver and front passenger manual recline with outboard head restraints” | 2016 Silverado 1500 Special Service 5W4 specification guide |
| 2017 | “OPTIONAL – CLOTH MANUAL SPLIT BENCH (AE7) Front 40/20/40 Split-Bench 3-passenger” | 2017 Silverado 1500 Special Service 5W4 specification guide |
| 2018 | “OPTIONAL – CLOTH MANUAL SPLIT BENCH (AE7) Front 40/20/40 Split-Bench 3-passenger” | 2018 Silverado Special Service specification guide |
| 2021 | “Front 40/20/40 split bench with arm rest storage and vinyl trim” | GM Fleet order guide |
| 2022 | “Seats, front 40/20/40 split-bench” | GM Silverado T1XX documentation |
AE7 does not tell you the material
This is the part that catches people out, and it is worth being precise about because the obvious reading is wrong.
In the same specification guide, for the same model year, GM lists AE7 twice:
- as the optional cloth manual split bench, and
- as the vinyl split bench that is standard on the WT work-truck model — “STANDARD – Vinyl Split-Bench (AE7) on WT Model (Vinyl not available on LS model)”.
Same code, same year, cloth or vinyl depending on which truck it came on. So AE7 tells you the seat’s shape and that it is manual. It does not tell you what the seat is covered in. For upholstery, seat covers or matching an interior you need the trim code off the same label — H2R is dark ash cloth on these trucks, H2Q and H2G are vinyls, H0U is jet black.
What AE7 rules out
- It is not a power seat, and on these trucks it cannot become one. GM’s 2016, 2017 and 2018 guides all list the power driver adjuster (AG1) as “included and only available with (AZ3) front 40/20/40 split-bench cloth seat”. AZ3 is a different seat code from AE7. If the label says AE7, the bench is manual and the factory did not offer a power adjuster on it.
- It is not bucket seats. AE7 means the truck left the factory with a bench and a centre section, not two separate seats and a console.
- It does not tell you about the rear seat. That is its own code.
- The centre section may have been deleted. GM sold two seat-delete options derived from AE7 — 9S1 and 9U3, both described as an AE7 bench “with the 20% centre section removed”. A truck with AE7 plus one of those codes has two outboard seats, not three.
How to check yours
- Decode AE7 for your model year, and run the whole label so you also see the trim code that tells you which material your bench came in.
- Find the Service Parts Identification label — the block of three-character codes. On most full-size Chevy and GMC trucks that is inside the glove box lid; on 2007 and later it may be in the centre console or on the driver’s door jamb.
- Count the seats. A bench with a fold-down centre is AE7’s shape. Two outboard seats with a gap means a 9S1 or 9U3 delete.
What we know and what we do not
We hold records for AE7 from 1991 to 2022. The 1991 and 2021 entries are the ones GM’s own masters confirm directly; the 2015–2018 wording above was read verbatim out of GM’s Silverado 5W4 specification guides. The years between 1991 and 2015 are thinner — AE7 was almost certainly available across that span, but we are not going to tell you it was on a truck in a year we cannot point at a document for. If you have a factory build sheet or window sticker for a year we do not list, that is worth posting on the forum.
- GM VPPS option master, November 2002
- 2015, 2016, 2017 Chevrolet Silverado 1500 Special Service (5W4) specification guides, GM Upfitter
- 2018 Chevrolet Silverado Special Service specification guide, GM Upfitter
- GM Fleet order guides, 2021–2022
